speed telemetry
I want to find the instaneous speed in MPH as I do inline skating.
A magnet could be place in the front wheel (about 80mm dia) with a
pick sensor over the wheel. Convert digital to analog and transmit to
a wrist computer to read out velocity.
Anyone smart enough to figure out how to do this?
Another way would be to buy a bicycle cordless unit and figure out
how to increase the transmission distance from 17in to about 6 ft. I
suppose.
Your thoughts. Anyone for hire?
suppose.
balance is a consideration on a small wheel, balance the wheel with 2
magnets at opposite ends of a wheel diameter, and count every other pulse.
I'd go this route instead of optical.
Dennis
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Wednesday, November 01, 2000 9:39 AM
Subject: Re: [noparse][[/noparse]basicstamps] speed telemetry
>You might look into an optical pickup rather than a magnet, as it will
>probably be easier and you wont have to put a wheel out of balance with a
>magnet.
>--Dan
>From: <healer4u@m...>
>To: <basicstamps@egroups.com>
>Sent: Wednesday, November 01, 2000 7:04 AM
>Subject: [noparse][[/noparse]basicstamps] speed telemetry
>> suppose.
magnet.
--Dan
> suppose.
Ray McArthur
Sent: Wednesday, November 01, 2000 3:18 PM
> DigiKey sells some very small magnets for use with Hall effect sensors.
If
> Dennis
> From: Dan Gustafson <dankgus@e...>
> >magnet.
> >--Dan
> >> suppose.
Industral tachometers often are use with a small reflective spot, say
1/4 inch to 1 inch on a 2 inch round shaft. Then count the
reflections as revolutions. The application is simple.
As regards calibration, you might be able to use a known speed like a
(are you ready for this?) a belt sander! Just don't use sandpaper!
Dave
will
with a
> magnet.
> --Dan
transmit to
ft. I
> > suppose.
