telescoping rod
Hello group!
Thanks for your input on my previous message (first robot) your input was very helpful.
I need to locate a telescoping rod that I can control with a stamp.· Ideally, I have to be able to make the rod go up and down then lean forward at approximately a 35 to 50 degree angle.· Once I figure out the mechanism (and source for purchase) I can handle the programming end of it.· Any suggestions.·
Thanks in advance,
Peter
pgmelton@msn.com
Thanks in advance,
Peter
pgmelton@msn.com
>Hello group!
>very helpful.
>stamp. Ideally, I have to be able to make the rod go up and down then
>lean forward at approximately a 35 to 50 degree angle. Once I figure out
>of it. Any suggestions.
A power antenna for a car radio
>Thanks in advance,
>Peter
><mailto:pgmelton@m...>pgmelton@m...
auto power antenna attached to a tilting mechanism. You could get one new
from Radio Shack or used from an
auto salvage yard.
Hello group!
very helpful.
at approximately a 35 to 50 degree angle. Once I figure out the mechanism
(and source for purchase) I can handle the programming end of it. Any
suggestions.
Thanks in advance,
Peter
>Reply-To: basicstamps@egroups.com
>To: <basicstamps@egroups.com>
>Subject: [noparse][[/noparse]basicstamps] telescoping rod
>Date: Mon, 30 Oct 2000 22:10:41 -0500
>Hello group!
>very helpful.
>suggestions.
>Thanks in advance,
>Peter
>pgmelton@m...
>how about an electric automotive antenna? call j.c.whitney co. located in
>ill.
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
