measuring project lifetime of a battery
How can I measure how long my breadboard project will last with a fresh 9V
battery? Obviously I can let it run until the battery is dead and use the
time lapsed as an educated guess, but there must be a much more scientific
way of estimating the lifetime.
TIA for any suggestions,
/* Andrew */
Andrew Tucker
Software Engineer
Aegis Software
206-447-4175 x120
mailto:andrewt@a...
/* Andrew */
Andrew Tucker
Software Engineer
Aegis Software
206-447-4175 x120
mailto:andrewt@a...
hobbiest. The biggest problem is that it is a non-linear function. As the
voltage decreases from the battery, current demand from the circuit
increases. With that in mind, as the battery gets drained it loses charge
exponentially faster. Some battery manufacturers have graphs of this and you
can make an estimate. But you'll have to know at what point (voltage) your
circuit will stop operating. Also, don't forget at this lower voltage, your
circuit is demanding more current to run. So it's also important to figure
out if the battery can supply that much current at the lower voltage. I
apologize this is not very straight forward, but since the function is not
linear it is much more difficult to calculate mathmatically than we would
like.
If you want more info on the bench set up I did to test our batteries, just
contact me offline.
Jason Linscott
PCB Layout/Engineering Technician
ILX Lightwave
jlinscott@i...
(303) 516-8877
From: Andrew Tucker [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lAz540qnx1lzaNPV691ILZxbu3jfCrN0cSEKYQmleNgNbShqNDaaElJtBFsBm7sCn4cUGogWXFFvyxc]andrewt@a...[/url
Sent: Monday, October 30, 2000 11:27 AM
To: 'Basic Stamp List'
Subject: [noparse][[/noparse]basicstamps] measuring project lifetime of a battery
/* Andrew */
Andrew Tucker
Software Engineer
Aegis Software
206-447-4175 x120
mailto:andrewt@a...
Hi Andrew,
As a rough estimate, you divide the amp-hour capacity of the battery by the
average current drain of your project. That gives you the number of hours.
A standard 9 volt alkaline battery has a capacity of 500 milliamp hours.
(A 9 volt lithium version is 1100 milliamp hours, a NiCAD much less) So if
you have a BS2 drawing 8 milliamps continuously, you can expect about
500/8=62.5 hours. (Your milage may vary!)
Using the NAP or SLEEP commands, the average current can be lower and
lengthen the battery life. On the other hand, if your BS2 is driving LEDs
or external power hogs, the average current will be higher and the battery
life lower. The average current is estimated by factoring in the
proportion of time your system operates at each discrete current level.
-- Tracy Allen
http://www.emesystems.com
The best way I have used to predict battery run-time is to download battery
life curves from the internet, and estimate the run time based on current
consumption. The curves are available from various manufacturers; just
search under the name (e.g. Duracell).
Keep in mind that this method is better than taking actual measurements from
experiments unless you discharge THOUSANDS of batteries and average the
data, because every battery is slightly different, and has a slightly
different storage time versus temperature history, making every battery you
buy perform differently.
In addition, even if you had a battery of know quality, the actual use
conditions vary slightly, so performance would vary slightly anyway.
An estimated run time can be made, then, as I always do, set the run time
specification for your device to be a safe amount LESS THAN the predicted
value.
Chuck
To: 'Basic Stamp List' <basicstamps@egroups.com>
Date: Monday, October 30, 2000 1:27 PM
>/* Andrew */
>Andrew Tucker
>Software Engineer
>Aegis Software
>206-447-4175 x120
>mailto:andrewt@a...
