Heat Sensor needed
At 10/27/2000 +0000 04:52 AM, you wrote:
>Hi all,
>I am building a microporcessor controlled robot which is capable of
>extinguishing a flame (flame from a candle). I need a heat sensor which is
>capable of detecting the flame. I called several local stores but they do
>not carry heat sensors. Is there any other type of device that I can use?
>Are there any web sites were that sell a heat sensor?
>Thanks,
>Sherrie
>_____________________
Hi Sherrie -
Here is one supplier:
[noparse][[/noparse] http://www.acroname.com/robotics/parts/R1-442-3.html ]
and a hack can be found here in the PDF of the "Marshall" robot:
[noparse][[/noparse] http://www.mil.ufl.edu/imdl/papers/IMDLFall1996.html ]
This hack uses a PIR detector, usually used to detect people witin a room.
The hack reduces the sensitivity, and addresses other matters as well.
Hope that gets you started.
Bruce Bates
>____________________________________________________
>Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
>Share information about yourself, create your own public profile at
>http://profiles.msn.com.
>Hi all,
>Thanks,
>Sherrie
Hi Sherrie -
Bruce Bates
Sherrie
_________________________________________________________________________
reliable to find the candle. Those that used IR sensors seem to get
confused from other IR sources. Hammamatsu is the name that comes to mind.
At 04:52 AM 10/27/00 GMT, you wrote:
>Hi all,
>Thanks,
>Sherrie
Larry G. Nelson Sr.
mailto:L.Nelson@i...
http://www.ultranet.com/~nr
various hot objects such as light bulbs etc. an
Ultra Violet flame detector is appropriate - possibly
not necessary for your project if only a candle is
the target you can just look for light - depends on
the milieu.
Date: Fri, 27 Oct 2000 04:52:27 GMT
is
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
