LCD displays...
To all stampers, Just a note to let you know that you can get very good quality serial LCD displays from www.nollet.com.au
Ron has these displays set up so that you can turn backlighting on and off with serial commands and thay are dead simple to use with stamps, bs1, bs2 and bs2sx. He has sample code and is probably the most helpful person around with stamp stuff. He also has developed a serial keypad system for use with the stamp, it takes all of the interfacing and code hungry programming away.
Give him a go, you will be glad you did.
And for all of you Aussie stampers, he is by far the best on price.
Chris
Chris
