Need a 10-15 min. Timer with pin status checks
What is the datatype of b4? Sounds like it is a byte and is wrapping around
when the number of iterations is more than 255. That would explain why the
for loop never finishes.
If you want to go from 1 to 400, b4 needs to be a word instead of a byte.
From: Scott Manson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5xef-E0hfPOopSpIOBth8Sy_lgv895N5T_W9DstXt1kPA6EWfVqRzC0A6aW3v8tygm4nn7RCr2J7WAqH]bigorlando@h...[/url
Sent: Wednesday, October 25, 2000 3:06 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Need a 10-15 min. Timer with pin status checks
The following is part of the code. For some reason, If I set the 2nd line
to a value of 400 or more (ex: for b4= 1 to 400), then the loop here
recycles and never times out and goes to the start of my program.
However, with the value of 200, it works fine.
Any ideas or any other more efficient way of accoplishing what the code
below does?
Also, this is a Basic Stamp 1 Rev. D
warmdown:
let pin3 = 0 'turn off LED
for b4 = 1 to 200 'initialize countdown timer
let indicat = 1 'turn on LED 1
let pin3 = 1 'turn on LED 2
pause 500 'used as a 1/2 sec. delay/ achieves flashing LED
let indicat = 0 'turn off LED 1
let pin3 = 0 'turn off LED 2
if switch1 = 0 then scan 'If switch active, goto scan sequence
pause 500 'other 1/2 sec. delay/ achieves flashing LED
next
let lighton = 0 'after timeout, turn off LED 1
let indicat = 0 'after timeout, turn off LED 2
goto start 'return to start of program
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
below does?
warmdown:
next
Scott -
It's possible the Stamp is being reset (brownout due to 2 x leds). Place
DEBUG "Start" as the first line of the program, and see if it prints more
than once. Additionally, B4 is a byte variable whose value can not exceed
255 (&H'FF'). You need to use a word variable (w4) for numbers which exceed
255. I diidn't study what the routine did carefully, but if you want to
DECREMENT it (countDOWN), you need For b4 = .
1 to 200 step -1 or b4 = 200 to 1 (without the step). Also, branching to
SCAN will bypass the next, unless you carefully re-enter the loop.
Just a few observations.
Bruce Bates
>below does?
>warmdown:
> next
below does?
warmdown:
next
above 255 using b4. I will try using a word instead as you suggested.
Thanks for the tip!!
-Scott-
wrapping around
why the
byte.
> From: Scott Manson [noparse][[/noparse]mailto:bigorlando@h...]
checks
2nd line
code
> below does?
> warmdown:
> next
___
