servo motion
I have a STD PARALLAX servo that was part of a kit I received from
college. My question is, is there any way I can program the servo to
move in one direction and then reverse directions without going to
the max in each direction before changing? I am using the BASIC 2 to
do the programming with.
> Date: Tue, 24 Oct 2000 17:47:47 -0000
> From: mister@t...
> Reply-To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] servo motion
> Thanks
The way it works is you send a timed pulse of a specific length to specify
the desired position. This must be done about every 20 msecs or so.
Generally speaking, center position is set by sending a pulse of 1/2 the
maximum. Many servos use a 1 msec wide pulse, with 1 msec being full ccw,
2 msec being full cw, and 1.5 msec being center. So you experiment with
different pulse widths to find the ones that give the throw and direction
you want. Note that different servos use different timeing, so find out
what yours uses and have fun!
Further note: There is an application note for the BS1 on controlling and
testing servos, page 85 of the version 1.8 BASIC Stamp Manual.
[noparse];)[/noparse]
Jerry
Jerry A. Covington
jerry@p...
routine. The timimg depends on the version of stamo you are using,
but it is easy to do the conversion with just some data about each
stamp. Below is a routine for this:
'{$stamp bs2sx}
start:
for w1=900 to 2750 step 25
pulsout 4,w1
pause 20
next
for w1=2750 to 900 step 25
pulsout 20,w1
pause 20
next
goto start
In this example, the w1 value 900 to 2750 gives an approximate 180deg
swing, close to a second per swing. The step value determines the
rate of the swing.
A setting of about 1800 is close to the center of the servo's
physical swing.
Hope this helps!
Doug
> From: "Jerry A. Covington" <jerry@p...>
> Date: Thu, 26 Oct 2000 01:04:42 -0400 (EDT)
> Reply-to: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] servo motion
> > From: mister@t...
> > Thanks
> Jerry
> Jerry A. Covington
> jerry@p...
