BSIISX - Connecting Servo''s Correctly
You are right of course. The original code was set for 10uS steps, so 200
was 2mS. Changing to the BS2 or SX did it. So the original author was
correct, and when I "corrected" the code, I introduced the error. Hope that
didn't destroy your servos beyond repair.
Al Williams
AWC
* Control 8 servos at once: http://www.al-williams.com/awce/pak8.htm
> From: Doug Simpson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ou6B493_xMcIfyWwYcq7OgalG0DdWY_T27SX64oBx9XCgQ_jJ8LpnYR7S0a33ovSSwlZ4eQ4UPvbzQ]veewee77@a...[/url
> Sent: Monday, October 23, 2000 2:38 PM
> To: basicstamps@egroups.com
> Subject: RE: [noparse][[/noparse]basicstamps] BSIISX - Connecting Servo's Correctly
> Al Williams (and others)
> It did grind the gears. But I got it figured out (I think) tell me
> if I'm wrong in my thinking. . .
> The variable specified in b2 is a byte variable, right?
> Ok, the number is bigger than 255 which makes it out of range for a
> number bigger than 255, right?
> So, I tried using w2 instead and POW it worked! My practical range
> on the servo for smooth control is fron 900 all the way to 2750,
> which all fits into the word variable w2.
> Included is the code for a servo tester that will continuously sweep
> a servo from one side to the other at whatever rate specified by the
> "step" value, with the pulsout set to yhe pin you want to connect the
> servo to.
> The code follows:
> start:
> for w1=900 to 2750 step 25
> pulsout 4,w1
> pause 20
> next
> for w1=2750 to 900 step 25
> pulsout 4,w1
> pause 20
> next
> goto start
> Hope this helps other, too!
> Thanks,
> Doug
> > To: <basicstamps@egroups.com>
> > From: "Al Williams" <alw@a...>
> > Date: Mon, 23 Oct 2000 18:14:22 -0500
> > Reply-to: basicstamps@egroups.com
> > Well, I didn't write the original code, but it looks fine to me. Did it
> > grind out your gears? Otherwise, I don't know how you would
> ruin the servos
> > no matter what pulse widths you sent it. Maybe someone else has
> experience
> > with that? I have blown servos by shorting my power and ground
> (I'm clumsy).
> > In fact, I have one crippled BOE Bot right now because I don't
> have any more
> > servos.
> > The idea is to send a pulse to the servo to position it. 1500uS should
> > center the servo. So try this (maybe even on one of the ruined servos?):
> > LOW 0
> > PULSOUT 0,XXX
> > where XXX is whatever results in 1500uS for your type of Stamp (150 for
> > Stamp I, 750 for Stamp II, and 1875 for the BS2SX). That should
> center it.
> > Then change XXX to XXX+25 and see if the servo will step a bit
> over. Don't
> > put any load on the servo, and it should stay put after the program runs
> > (although it won't)
> > All the servos I'm aware of have a stop to keep you from going
> too far, and
> > the only thing I could imagine you could do would be grind
> against the stop
> > hard enough to strip the nylon gears? I've never seen that
> though. Anyone
> > else?
> > Regards,
> > Al Williams
> > AWC
> > * Connect a PS/2 keyboard to your Stamp project (or any
> microcontroller):
> > http://www.al-williams.com/awce/pak6.htm
> > > > > > > > > >'PROGRAM "SRVOTST1.BAS" 10/4/00
> > > > > > > > > >'TO TEST RC SERVOS
> > > > > > > > > >LOW 0
> > > > > > > > > >AGAIN:
> > > > > > > > > >FOR B2=100 TO 200 STEP 2
> > > > > > > > > > PULSOUT 0,B2
> > > > > > > > > > PAUSE 15
> > > > > > > > > >NEXT
> > > > > > > > > >FOR B2=200 TO 100 STEP -2
> > > > > > > > > > PULSOUT 0,B2
> > > > > > > > > > PAUSE 15
> > > > > > > > > > NEXT
> > > > > > > > > >'DEBUG "AGAIN"
> > > > > > > > > >PAUSE 1000
> > > > > > > > > >GOTO AGAIN
> > > > > > > From: Ray McArthur <rjmca@u...>
> > > > > > > Sent: Saturday, October 21, 2000 1:38 AM
> > > > > > > Subject: Re: [noparse][[/noparse]basicstamps] BSIISX - Connecting
> Servo's Correctly
Al Williams
AWC
> servo to.
> The code follows:
> start:
> pulsout 4,w1
> pause 20
> next
> pulsout 4,w1
> pause 20
> next
> goto start
> Thanks,
> Doug
> ruin the servos
> experience
> (I'm clumsy).
> have any more
> > servos.
> > LOW 0
> > PULSOUT 0,XXX
> center it.
> over. Don't
> > (although it won't)
> too far, and
> against the stop
> though. Anyone
> > else?
> > Regards,
> > Al Williams
> > AWC
> microcontroller):
> > > > > > > > > >'TO TEST RC SERVOS
> > > > > > > > > >LOW 0
> > > > > > > > > >AGAIN:
> > > > > > > > > > PULSOUT 0,B2
> > > > > > > > > > PAUSE 15
> > > > > > > > > >NEXT
> > > > > > > > > > PULSOUT 0,B2
> > > > > > > > > > PAUSE 15
> > > > > > > > > > NEXT
> > > > > > > > > >'DEBUG "AGAIN"
> > > > > > > > > >PAUSE 1000
> > > > > > > > > >GOTO AGAIN
> Servo's Correctly
