BSIISX - Connecting Servo''s Correctly
Well, I didn't write the original code, but it looks fine to me. Did it
grind out your gears? Otherwise, I don't know how you would ruin the servos
no matter what pulse widths you sent it. Maybe someone else has experience
with that? I have blown servos by shorting my power and ground (I'm clumsy).
In fact, I have one crippled BOE Bot right now because I don't have any more
servos.
The idea is to send a pulse to the servo to position it. 1500uS should
center the servo. So try this (maybe even on one of the ruined servos?):
LOW 0
PULSOUT 0,XXX
where XXX is whatever results in 1500uS for your type of Stamp (150 for
Stamp I, 750 for Stamp II, and 1875 for the BS2SX). That should center it.
Then change XXX to XXX+25 and see if the servo will step a bit over. Don't
put any load on the servo, and it should stay put after the program runs
(although it won't)
All the servos I'm aware of have a stop to keep you from going too far, and
the only thing I could imagine you could do would be grind against the stop
hard enough to strip the nylon gears? I've never seen that though. Anyone
else?
Al Williams
AWC
* Connect a PS/2 keyboard to your Stamp project (or any microcontroller):
http://www.al-williams.com/awce/pak6.htm
> > > > > > > >'PROGRAM "SRVOTST1.BAS" 10/4/00
> > > > > > > >'TO TEST RC SERVOS
> > > > > > > >LOW 0
> > > > > > > >AGAIN:
> > > > > > > >FOR B2=100 TO 200 STEP 2
> > > > > > > > PULSOUT 0,B2
> > > > > > > > PAUSE 15
> > > > > > > >NEXT
> > > > > > > >FOR B2=200 TO 100 STEP -2
> > > > > > > > PULSOUT 0,B2
> > > > > > > > PAUSE 15
> > > > > > > > NEXT
> > > > > > > >'DEBUG "AGAIN"
> > > > > > > >PAUSE 1000
> > > > > > > >GOTO AGAIN
> > > > > From: Ray McArthur <rjmca@u...>
> > > > > To: <basicstamps@egroups.com>
> > > > > Sent: Saturday, October 21, 2000 1:38 AM
> > > > > Subject: Re: [noparse][[/noparse]basicstamps] BSIISX - Connecting Servo's Correctly
servos.
LOW 0
PULSOUT 0,XXX
(although it won't)
else?
Al Williams
AWC
> > > > > > > >'TO TEST RC SERVOS
> > > > > > > >LOW 0
> > > > > > > >AGAIN:
> > > > > > > > PULSOUT 0,B2
> > > > > > > > PAUSE 15
> > > > > > > >NEXT
> > > > > > > > PULSOUT 0,B2
> > > > > > > > PAUSE 15
> > > > > > > > NEXT
> > > > > > > >'DEBUG "AGAIN"
> > > > > > > >PAUSE 1000
> > > > > > > >GOTO AGAIN
