phone — Parallax Forums
phone
edited 2000-10-24 15:28 in General Discussion
Hello list,
Problem:
I want a mobile (cell-) phone to dial a number (in telephone memory) if
a STAMP is giving the order.
Why:
Someone is stealing (or breaking into) my car and I want to prevent that.
Question:
Is there anybody out there who knows the protocol to control a mobile phone
and the connections?
Daan van Marum
dvm@b...
the Netherlands
Amsterdam
    edited 2000-10-23 20:14
    yOn Mon, 23 Oct 2000, Daan van Marum wrote:
    > Hello list,
    > Problem:
    > Why:
    > Question:
    The easiest way is probably going to be getting an async rs-232 interface
    (the motorola analog phones have specialized boxes that do this ; newer
    PCS devices have direct cable connections.). At this point the stamp just
    ends up generating 9600 baud AT commands.
    Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
    Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
    email: lamont@a... WWW: http://www.serv.net
    "...There's no moral, it's just a lot of stuff that happens". - H. Simpson
    edited 2000-10-24 03:57
    Dan,
    I have looked into this idea myself, I think it's a
    great one. Motorola makes a encoder/decoder chip, I
    think they focus on it in the September issue of Nuts
    and Volts, this will interface with the Stamp.
    However, I am not sure it is the most efficient way to
    do so. The idea I would like to utilize is once you
    have dialed up the stamp you could use a fuel cut-off
    switch to progressively slow the car down and/or turn
    it off. I have even more ideas with this, however,
    one thing at a time. Your welcome to contact me if I
    can assist you further or if you would like to share
    your thoughts on the development of this.
    Hope this has helped,
    Todd
    __________________________________________________
    Do You Yahoo!?
    Yahoo! Messenger - Talk while you surf! It's FREE.
    http://im.yahoo.com/
    edited 2000-10-24 05:33
    I did just this a couple of years ago. I was responsible for instrumenting
    a research site that was located 30 + miles from my office. In brief, I had
    a datalogger monitoring flow and various other parameters in a drainage
    tile. When a rainfall event caused the tile to start flowing, the data
    logger kicked on a water sampler and also went to a subroutine which
    powered up a cellular phone, paused several seconds to allow for a
    connection, then activated a speed dial button which dialed the number of
    my pager. It worked very well, the toughest part was opening the phone and
    locating suitable points to solder jumper wires to. I just located each set
    of traces which were completed by the buttons, attached wires and ran to
    the outside of the phone where they were terminated with relays.
    It worked very reliably, it was truly an awesome thing, when a thunderstorm
    would pass over my apartment, head towards my research site, and twenty
    minutes later, my pager would go off.
    This was useful so i would then know what time to arrive at my research
    site to collect the samples.
    Even managed to have the concept published
    Inexpensive automated paging system for use at remote research sites
    Soil Science Society of America Journal, June-July, 1998, Vol. 62 No. 3,
    pp. 600-601
    good luck, hope this makes sense, I'm needing some sleep badly,
    Steve
    edited 2000-10-24 06:00
    Hi!
    do u have any link that i could see this? I can't find it on the internet...
    Thanx! Takis
    > pp. 600-601
    > Steve
    I've attached it here. It's in a word perfect document. not in the best of
    shape, but should do.
    Steve
    At 10:00 PM 10/23/2000 -0700, you wrote:
    >Hi!
    >Thanx! Takis
    >> pp. 600-601
    >> Steve
