IR Communication
IR Communication
I'm just not able to nail this thing down. I'm following the application note #11 in the Basic Stamp Manual (in the Stamp I section). I bought Radio Shack's 276-137 (GP1U52X).
I'm not able to figure why the receiver is not able to receive the values from the transmitter. I do not know if the transmitter is working at all in the first place.
Please advise, the following is what I've got.
Any help is greatly appreciated.
Thanks a lot in advance.
nagi
The Transmitter: Using one BSII.
······· 555 Timer output (p3) is connected to the base of the 2n2222 transistor, the emitter is connected to the IR emitter's cathode lead. 555's reset (p4) is hooked upto BSII's Pin 0. Also the timer is set at 40Khz. I'm not using a potentiometer. Instead, I'm using a couple of resistors that produce 40Khz (+/- 100).
······· ' 555's reset pin on BSII's pin 0
······· Low 0
······· m:
······· ······· ' 1200 baud
······· ······· serout 0, 17197, [noparse][[/noparse]"X"]
······· ······· pause 500
······· goto m
The receiver: Using the second Basic stamp II
······· pin 1 from IR Receiver is hooked up to pin 0 in BSII and with a 470R is also connected to Vdd.
······· pin 2 from IR Receiver is hooked up to Vdd
······· pin 3 from IR Receiver is hooked up to Vss
······· Code:
······· x······ var···· byte
······· m:
······· ······· serin 0, 17197, 2000, No_data, [noparse][[/noparse]x]
······· ······· debug home, dec x, "················· "
······· goto m
······· No_Data:
······· ······· debug home, "No Data······· "
······· goto m
nagi
······· Low 0
······· m:
······· goto m
······· Code:
······· m:
······· goto m
······· No_Data:
······· goto m
also a part of my BS/L book. Send me a SASE and I'll send you a PCB to try
out.
Paul
the first place.
nagi
Hey Paul,
Where can I find more info on your book ? and what is a SASE (sorry I did not get that word - I guess I took off too early from school when they were covering that section of english [noparse]:)[/noparse]
thanks Paul
nagi
From: Paul Verhage [noparse]/noparse][url=mailto:pverhage@sd131.k12.id.us]mailto[noparse]:p[/noparse]verhage@sd131.k12.id.us[/url
Sent: Monday, October 23, 2000 8:34 AM
To: 'basicstamps@egroups.com'
Subject: RE: [noparse][[/noparse]basicstamps] IR Communication
I've got a PCB designed to use the GP as an IR Proximity Detector.· It's
also a part of my BS/L book.· Send me a SASE and I'll send you a PCB to try
out.
Paul
the first place.
nagi
Caldwell, ID 83605
My book and board is undergoing beta testing. If you would like to test it,
send me $15 and I'll send you a set.
Paul
Hey Paul,
thanks Paul
nagi
nagi
I'd love to. I shall do that tonight.
Thanks yet again Paul.
nagi
Sent: Monday, October 23, 2000 8:45 AM
A SASE is a stamped, addressed envelope.· My address is 207 Crestline #3,
Caldwell, ID 83605
My book and board is undergoing beta testing.· If you would like to test it,
Paul
Hey Paul,
thanks Paul
nagi
nagi
to send an "SASE" overseas (to the US or from the US) go to your post office
and buy 1 or 2 IRCs (International Reply Coupons). Send these with your
envelope. The recipient can trade these at his post office for local
postage. One should do surface but with two you can probably send it air.
Some of the smaller US post offices don't have any idea what these are, but
they do exist and a real post office can sell them to you.
Al Williams
AWC
*Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> From: Paul Verhage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hD9PT4sr40fV6RfGWKZW180W6kfbz8_sXc-D5UQO-zJnf7ZeVdevk3YHWEIoG-A2KiryWLTmcjbIiMusBM0]pverhage@s...[/url
> A SASE is a stamped, addressed envelope. My address is 207 Crestline #3,
> Caldwell, ID 83605
> to test it,
> Paul
> Hey Paul,
> they were
> thanks Paul
> nagi
> nagi
Thanks Al.
From: Al Williams [noparse]/noparse][url=mailto:alw@al-williams.com]mailto:alw@al-williams.com[/url
Sent: Monday, October 23, 2000 8:52 AM
To: basicstamps@egroups.com
Not to butt in, but SASEs are almost impossible to use overseas. If you want
Al Williams
AWC
> Caldwell, ID 83605
> to test it,
> Paul
> Hey Paul,
> they were
> thanks Paul
> nagi
> nagi
as a followup question, I thought somebody mentioned in this newsgroup that the Radio Shack's 276-137 part had some problems and that we had to buy another part from them - somthing along the lines of "276-137B" ?
any thoughts ?
tbanks
nagi
out.
Paul
the first place.
nagi
Its worked for me in the past.
Paul
any thoughts ?
tbanks
nagi
nagi
Paul,
I have sent the SASE and the $15 this morning. Also, I had a question for you on your board and the book. Can the board be used to demonstrate the IR Tr/Rx ?
thanks
nagi
Sent: Monday, October 23, 2000 12:12 PM
The part I use is 276-137A.
Paul
any thoughts ?
tbanks
nagi
nagi
Tr/Rx ?
thanks
nagi
The board I have is actually several boards. One is for the robot
controller and the others are for various sensors. There is one sensor for
proximity sensing. The BS-2IC controls the pulsing of two IREDs. The GP
then detects the reflection of the IR beams. I haven't tried it, but it
would proably work to send small packets of data over IR with it. You will
need to play with the aiming of the IREDs and GP.
Paul
I am currently using the BS2 in a project in which a program
written in Visual Basic 6.0 communicates with the stamp, provides it
with parameters, and signals it to start a process. The computer on
which I am running it communicates with the stamp via a serial
cable. I would like to port this over to my Pocket PC, and have it
work via infared. What would I need to attach to my stamp to enable
it to communicate with the IR port on my handheld?
Bill
