Bigger servos?
Archiver
Look for Tonegawa Seiko Servos
SSPS-050 and SSPS-105 (world's strongest RC servos)
http://members.aol.com/ckdesign1/actuator.html
and
http://www.vantec.com
ACJacques
mcruz1@t... wrote:
> Has anyone found a place where you can buy bigger, larger Voltage
> servos with more weight/torque and speed than the ones that we all
> use for out remote control projects? I would like to find some that
> have the same logic to them, because that is what we all know using
> (pulsout commands) but can operate in an industrial enviroment as a
> Pic-N-Place application. Thank you in advance!
and
ACJacques
it while making it go forward and reverse in a short period of time. Like a
3 sec cycle time while traveling up to 2 feet in either direction...
To: 'basicstamps@egroups.com' <basicstamps@egroups.com>
Date: Monday, October 23, 2000 7:40 PM
Subject: RE: [noparse][[/noparse]basicstamps] BIGGER SERVOS?
>Different interface technique (step and direction signals) but look at the
>G320 from www.geckodrive.com It is a control package that allows you to use
>any brushed DC motor from 24 V to 80 V and up to 20 amps. Definitely an
>industrial class solution and pretty reasonable at $99 each. You still need
>to get a motor with an encoder, but you can pick them up on E-bay for $10 -
>$50 depending upon how big you need.
>Tim
>[noparse][[/noparse]Denver, CO]
>> From: mcruz1@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hYD8XbFmMugtrueeUCpigWm9GZuV8IKX50tPsgVNgiqBZbiOjzCAy07BBY008CZxc0roONy3oKX4mLCYYA]mcruz1@t...[/url
>> Sent: Monday, October 23, 2000 4:46 PM
>> To: basicstamps@egroups.com
>> Subject: [noparse][[/noparse]basicstamps] BIGGER SERVOS?
How BIG? Real BIG or only a little bit BIG? VBG
When I bought the servos for my HO scale rotary dumper
http://www.ida.net/users/tetonsl/railroad/dumper.htm at the local hobby
shop, they catalogued Expert Brand model SL820, 2.48" x 1.26" x 2.46" with
214 oz/in torque. Didn't stock them of course. Still work at 5 volts.
Wayne
Wayne Roderick P.E. (EE, ret)
CEO, Teton Short Line, (NMRA life-1721)
e-mail tetonsl@i... Pocatello Idaho, USA
Note new URL- /biz/ becomes /users/
Tim
> From: mcruz1@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FGnAcmbxcsxbeWADlnwbeK8Uosyhiu2ORdQBvaOTP3hAZU9MluNO7MUoi_HMfTRXviiPKhqHuJsjjNs]mcruz1@t...[/url
acceleration without needing to keep it at the peak torque for the whole
travel. Also, air and water cooling are not unheard of in an industrial
setting. I am using a set of these drives on my CNC machine and they are
working out great.
Tim
> Thank you, I will look into it...My concern with a DC motor
> is overheating
> of time. Like a
> From: Tim Goldstein <timg@k...>
> but look at the
> allows you to use
> Definitely an
> You still need
> E-bay for $10 -
> >Tim
torque, high speed, ball bearing, etc etc
mtrc> Has anyone found a place where you can buy bigger, larger Voltage
mtrc> servos with more weight/torque and speed than the ones that we all
mtrc> use for out remote control projects? I would like to find some that
mtrc> have the same logic to them, because that is what we all know using
mtrc> (pulsout commands) but can operate in an industrial enviroment as a
mtrc> Pic-N-Place application. Thank you in advance!
These guys all carry Tonegawa Seiko servos
http://www.ckdesigntech.com/
http://www.hobbyclub.com/framespage.htm
http://www.vantec.com/index.html
