BSIISX - Connecting Servo''s Correctly
Ah, I tried the new code but I still get an error message.
The message says:-
Error exptected ':' or end-of-line.
And on the ninth line down, B2 is highlighted?
Does this make any sense to anyone?
To: <basicstamps@egroups.com>
Sent: Saturday, October 21, 2000 4:22 PM
Subject: Re: [noparse][[/noparse]basicstamps] BSIISX - Connecting Servo's Correctly
> I have tried this code to test my servo on a BS2SX but it is coming back
> with a message saying incorrect variable?
> > > >'PROGRAM "SRVOTST1.BAS" 10/4/00
> > > >'TO TEST RC SERVOS
> > > >DIRS=%11111111
> > > >LOW 0
> > > >AGAIN:
> > > >FOR B2=100 TO 200 STEP 2
> > > > PULSOUT 0,B2
> > > > PAUSE 15
> > > >NEXT B2 (incorrect variable)
> > > >FOR B2=200 TO 100 STEP -2
> > > > PULSOUT 0,B2
> > > > PAUSE 15
> > > > NEXT B2
> > > >'DEBUG "AGAIN"
> > > >PAUSE 1000
> > > >GOTO AGAIN
> From: Ray McArthur <rjmca@u...>
> Sent: Saturday, October 21, 2000 1:38 AM
> > Nick:
> > You can use any Stamp pin and write your code for the pin you use. In
the
> > example code I sent, pin zero is driving the servo as determined by the
> > statement
> > PULSOUT 0,B2
> > Ray McArthur
> > From: Nick Messenger <nick@m...>
> > Sent: Friday, October 20, 2000 3:27 PM
> > > I'm new to Stamps and just trying to learn how to connect up two hobby
> > > servos to a BSIISX and program them with a simple code that I could
> > > understand even though I have never used PBasic language before.
> > > Does anyone have a short code that I could use to do this?
> > > If the red wire goes to +5 volts.
> > > The Black goes to gnd.
> > > And the White goes to your Stamp pin, can somebody tell me from my
> diagram
> > > below, which is the Stamp pin.
> > > TX PWR
> > > RX GND
> > > ATN RES
> > > GND +5v
> > > P0 P15
> > > P1 P14
> > > P2 P13
> > > P3 P12
> > > P4 P11
> > > P5 P10
> > > P6 P9
> > > P7 P8
> > > From: Jason 1 <plugger2@s...>
> > > Sent: Friday, October 20, 2000 5:38 AM
> > > > Original message from: "Ray McArthur" <rjmca@u...>
> > > > >Nick:
> > > > >The red wire goes to +5 volts.
> > > > >Black goes to gnd.
> > > > >White goes to your Stamp pin.
> > > > >I advise a 1K resistor in series to the stamp pin, it doesn't
effect
> > > > the
> > > > >servo and provides protection to the Stamp.
> > > > >Here is BS1 code that I have used to cycle servos back and forth.
I
> > > > am not
> > > > >familiar with the SX, so you will have to convert the code. Pay
> > > > special
> > > > >attention to the PULSOUT...the SX probably uses different units of
> > > > time.
> > > > >This program generates 1 to 2 millisecs with a BS1, (Pulsout
> > > > 100=10us*100=1
> > > > >millisec). Also, check on the Pause statement, I don't know if
it's
> > > > the
> > > > >same for the SX. For the BS1, Pause 15 is a 15 millisec delay.
Also
> > > > make
> > > > >sure your power supply can support the current drain of a servo.
> > > > Many
> > > > >problems show up on this list because the power supply bogs down
when
> > > > the
> > > > >servo moves, resulting in a Stamp reset.
> > > > >Hope this helps,
> > > > >Ray McArthur
> > > > >'TO TEST RC SERVOS
> > > > >DIRS=%11111111
> > > > >LOW 0
> > > > >AGAIN:
> > > > > PULSOUT 0,B2
> > > > > PAUSE 15
> > > > >NEXT B2
> > > > > PULSOUT 0,B2
> > > > > PAUSE 15
> > > > > NEXT B2
> > > > >'DEBUG "AGAIN"
> > > > >PAUSE 1000
> > > > >GOTO AGAIN
The message says:-
> > > >'TO TEST RC SERVOS
> > > >DIRS=%11111111
> > > >LOW 0
> > > >AGAIN:
> > > > PULSOUT 0,B2
> > > > PAUSE 15
> > > > PULSOUT 0,B2
> > > > PAUSE 15
> > > > NEXT B2
> > > >'DEBUG "AGAIN"
> > > >PAUSE 1000
> > > >GOTO AGAIN
> > Nick:
the
> > statement
> > PULSOUT 0,B2
> > Ray McArthur
> diagram
> > > TX PWR
> > > RX GND
> > > ATN RES
> > > GND +5v
> > > P0 P15
> > > P1 P14
> > > P2 P13
> > > P3 P12
> > > P4 P11
> > > P5 P10
> > > P6 P9
> > > P7 P8
> > > > >Nick:
> > > > >Black goes to gnd.
effect
> > > > the
I
> > > > am not
> > > > special
> > > > time.
> > > > 100=10us*100=1
it's
> > > > the
Also
> > > > make
> > > > Many
when
> > > > the
> > > > >Hope this helps,
> > > > >Ray McArthur
> > > > >'TO TEST RC SERVOS
> > > > >DIRS=%11111111
> > > > >LOW 0
> > > > >AGAIN:
> > > > > PULSOUT 0,B2
> > > > > PAUSE 15
> > > > >NEXT B2
> > > > > PULSOUT 0,B2
> > > > > PAUSE 15
> > > > > NEXT B2
> > > > >'DEBUG "AGAIN"
> > > > >PAUSE 1000
> > > > >GOTO AGAIN
