BS II counter/totalizer programming ?
Hi to all:
I am trying to use a BS II to control a parking garage entry door.
The setup has 6 inputs (card reader, three loop detectors, manual
open/close) and 5 outputs (open door, close door, alarm, red light.
green light). All of the I/O's are dry contact relays.
In this control sequence, it is critical for the controller to
monitor the activity of cars going in and out of the garage to
prevent (1) the door from closing on top of a car, and (2) to prevent
cars from getting stuck behind a closed door while on the garage ramp.
This is done by means of a software counter or "totalizer" in the
program. What I'm trying to do is to setup this software counter so
that it will start at 0, increment by one each time an input relay
for a entry or exit loop detector pulls it's corresponding stamp pin
low, and decrement the counter by one when a car crosses the
nesessary loop detector that indicates that it has entered or left
the garage. The code will then need to prevent the door from closing
anytime the software counter is not "0".
I am a novice BS II porogrammer, but have the code and circuitry done
to read the inputs and control the output relays. I am puzzled
though at how to setup a software counter in PIC basic. The counter
variable does not have to remain in EPROM, but if that's the best way
to do it, it's no problem.
IF anyone has done a similar counter/totalizer in PIC Basic and could
help me, it would be much appreciated !
John Lawson
Anchorage, AK
John Lawson
Anchorage, AK
To: <basicstamps@egroups.com>
Sent: Saturday, October 21, 2000 10:32 AM
Subject: [noparse][[/noparse]basicstamps] BS II counter/totalizer programming ?
> Hi to all:
Seeing as we have lots of lawyers in this country, I would suggest you
wire this in hardware to prevent the motor from going down on
something/someone. If your controller goes south, you still need the
safety. A relay, either supplemental or in direct control of the motor's
reversing circuit would prevent you from taking on unnecessary litigation
should something go wrong, and Murphy says that they will.
>From: <lawson@g...>
> > Hi to all:
>something/someone.
FWIW - This is often accomplished by using a closed end "rubber" tube with
a pressure sensor at one end. If this is for oneself, that's one thing, if
it is For Sale (commercial product) that is an ENTIRELY different matter.
Other methods entail detected the stopping of the drive screw or drive
chain prematurely, and light beam break detectors. No method is "fool
proof" but one should exercise "due diligence" in conjuring up such a
device, and in its design.
Warnings such as that given, ARE VERY appropriate..
Bruce Bates
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ba7HdsOW__7OGi_a6wx6-wgNcoXgLOzIGlPOZIa5u8lzRYwPECL3Rc6qpiyUmqKD-Pe6cUk54neys-Qs2Lg]bvbates@u...[/url
Sent: Saturday, October 21, 2000 3:06 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] BS II counter/totalizer programming ?
At 10/21/2000 -0700 02:37 PM, you wrote:
>From: <lawson@g...>
> > Hi to all:
>something/someone.
Bruce Bates
The door is fully protected by a safety strip on the bottom of the door
(which is hard wired to the door operator for instant reverse) and an
infrared photobeam directly in front of the door 12" above ground level
(which if the beam is broken will also reverse the door automatically as
well).
The software counter/totalizer is necessary because of the length of the
entry/exit ramp (over 50' long) and the location of the entry and exit loop
detectors. The BSII application that I'm working on would replace a 23 year
old Gould PLC that is failing. The existing ladder logic and counter
program in the PLC has worked well for many years - I'm just trying to
duplicate it.
Any ideas for how to implement a counter in PIC Basic ?
Thanks !
John Lawson
From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7iY53cjo7KTu588SBxB9FDL5YpA6ObwJygrs_BCbipR1aAxvQIE7Cmt2Z8sOWsq137vbS9ch5d4rZ5n4z0hXpQE]bvbates@u...[/url
Sent: Saturday, October 21, 2000 2:06 PM
>From: <lawson@g...>
> > Hi to all:
>something/someone.
Bruce Bates
> snip..
loop
>detectors.
Hi John,
It's not clear to me from reading, how are the 3 loops set up in relation
to the gate and the entry and exit?
But supposing for simplification that there is one "entry" and one "exit",
and you want to count how many cars are "inside". Here is code for a
simple state machine to do it:
' the entry and exit loops will be connected to P0 and P1
' pull low when active
xcount var word ' how many are inside
dets var nib ' will hold current state of sensors
det0 var nib ' will hold previous state of sensors
detx var nib ' will hold changes in state of sensors
loop0 var detx.bit0 ' loop 0 state change 1=entry
loop1 var detx.bit1 ' loop 1 state change 1=exit
dets0=inA ' initialize
sensing:
dets=inA ' read nibble port A, current state
detx=dets^det0&det0 ' compute change in states
det0=dets ' previous state=current state
if loop0+loop1=0 then sensing ' changed?
xcount=xcount+loop0-loop1 ' new count
debug dec xcount,cr ' show it
goto sensing ' repeat
That's bare bones. You have to be sure that the signals from the loops are
well debounced in hardware or software. Also, you have to have some means
of recovery in case something goes wrong. Maybe a car backs stops and
backs up over the sensor again. Oops. Or you have negative cars. Or it's
like the San Francisco airport, always under construction, and nobody knows
where anything is.
The state machine approach is usually very fast in execution as it treats
all the sensors in parallel. The present state is XOR'd with the previous
state to detect a change in state, and that is AND'd with the previous
state to limit it to changes from 1-->0 in each bit. That change bit stays
high for one iteration of the loop, to increment or decrement the counter.
-- Tracy Allen
http://www.emesystems.com/BS2misc.htm#directional <-- more state
machines
