Help for Newbie on Security - PIR sensors 12VDC - X10 commands
???????? Cannot anybody help me not even a little ????????????????
--- In basicstamps@egroups.com, veld@i... wrote:
> I just started with the Basic Stamp 2SX Starter Kit and would like
to
> use the stamp for the following setup:
> use a photolight sensor for controling light and darkness
> use PIR sensor(s) for security as well as light control through x10
> commands.
> How do i have to connect eg the PIR sensor (working with 12VDC) to
> the stamp to check the status of that PIR and to supply the 12V
power
> Is there a complete security system available for:
> wired PIR sensors and contacts, working with 220V/240V AC and able
to
> output statuses of sensors to the Basic Stamp ??
> Is more specific info available on the web ??
> Thanks
to
> commands.
power
to
> Thanks
There are a couple of problem for some of us, with what you are attempting.
In the US our mains are 110 V, so we are generally unfamiliar with X-10 &
220 V. One resourse you might want to check is: [noparse][[/noparse] http://www.x10.com ] and
specifically the X-10 faq which may be found at; [noparse][[/noparse]
http://www.x10.com/support_x10faq.htm ] .
Another resource in Scandanavia which DOES discuss 220 V mains is High Tech
Horizons. Their website is [noparse][[/noparse] http://www.hth.com ] - which discusses their
"S.N.A.P." protocol.
Hope that gets you started.
Bruce Bates
>to
> > commands.
>power
>to
> > Thanks
