Newbie Question
I am trying to do something I thought fairly basic. I am trying to
use an ir to trigger a left or right turn. The Ir triggers and jumps
to the proper place in the code, but it doesn't actually execute the
loop. Here is a snip of the code.
main:
freqout 1, 1, 38000
rightIRdet = in0
debug home, ? rightIRdet
if rightIRdet=0 then test
goto main
test:
for x=1 to 10
pulsout left_servo,850
pulsout right_servo,650
pause 20
debug ? x
loop
goto main
The debug statement never runs, and the loop doesn't execute but
once. Am I missing something?? If I say goto test, the loop
executes exactly as written.
What is my problem?
Ben
main:
freqout 1, 1, 38000
rightIRdet = in0
goto main
test:
for x=1 to 10
pause 20
debug ? x
loop
goto main
What is my problem?
Ben
Where is your next statement?
Ray McArthur
To: <basicstamps@egroups.com>
Sent: Wednesday, October 18, 2000 10:01 PM
Subject: [noparse][[/noparse]basicstamps] Newbie Question
> main:
> freqout 1, 1, 38000
> rightIRdet = in0
> goto main
> test:
> for x=1 to 10
> pause 20
> debug ? x
> loop
> goto main
main:
freqout 1, 1, 38000
rightIRdet = in0
goto main
test:
for x=1 to 10
pause 20
debug ? x
next
goto main
>Ben:
>Ray McArthur
>From: Ben Brown <ben@h...>
> > main:
> > freqout 1, 1, 38000
>> rightIRdet = in0
>> goto main
>> test:
>> for x=1 to 10
>> pause 20
>> debug ? x
> > loop
> > goto main
I'm a newbie with the stamp. I have used it for one
project, which worked great and am now using it for a
new project. This one will also work great, but I ran
into what is probably a conceptual problem on my part,
rather than on the BS2's part.
I wanted to use natural words for the output pins in
my program, so I set up the following:
OUT6=LATCH
ON CON 1
OFF CON 0
Later in the program I set:
LATCH=ON
and even later in the program did the following:
PULSOUT LATCH,5
What I've discovered is that I have to replace LATCH
with OUT6 before the pin works. Is there some easy way
of setting up the definitions so I don't have to
rewrite the code? Any ideas gratefully received.
Thanks!
__________________________________________________
Do You Yahoo!?
Yahoo! Shopping - Thousands of Stores. Millions of Products.
http://shopping.yahoo.com/
>OUT6=LATCH
>ON CON 1
>OFF CON 0
>LATCH=ON
>PULSOUT LATCH,5
Hi Elmer,
The definition statements should be:
LATCH var out6 ' as a variable alias
LATCH_pin con 6 ' as a constant
ON CON 1
OFF CON 0
Then:
output LATCH_pin ' makes pin an output
and later:
LATCH=ON ' assignment of variable
PULSOUT LATCH_pin,5 ' pin number is a constant
You have to be careful with the difference between the pin number as a
constant, or as a variable. I make that mistake all the time!
regards,
-- Tracy Allen
http://www.emesystems.com
this board. It's bugged since I started using the Stamp I couldn't
find a way around the IN / OUT words for control.
Who woulda thunk it.
Great newbie question!!
-Martin
www.selmaware.com
> >OUT6=LATCH
> >ON CON 1
> >OFF CON 0
> >LATCH=ON
> >PULSOUT LATCH,5
> Hi Elmer,
> ON CON 1
> OFF CON 0
> Then:
> and later:
as a
> regards,
> -- Tracy Allen
aquarium air pump stays on. I can build cricuits, but I am not very good at
designing them.
Thank you for any assistance...CR West
right?
To keep things simple, select a relay that can handle the voltage/current on
the CONTACTS and has, say, a 12V coil (or even a 5V coil). Unless the relay
is a solid state relay specifically meant to be driven by logic circuits,
you'll need some circuitry to drive the coil.
Since you are dealing with 120VAC, be careful. I'd use a DPDT relay so I
could break both the hot and neutral wires to the pump.
Here's how to wire the coil of the relay:
+V (5V, 12V, 6V, whatever the relay coil wants) goes to one side of the coil
(say side A). On side B, you connect the collector of a 2N2222 transistor
(assuming your relay coil is rated <100mA or so). Ground the emitter. Put a
1K resistor between the base and a Stamp pin. Take a diode (1N4001 or 1N914
or 1N4148) and put it with the banded end to side A and the non-banded side
to side B. Now when you bring the Stamp pin high, the relay will close and
start the pump. When you bring the pin low, the relay will open.
Say you power the Stamp with a normally closed momentary action pushbutton.
When the Stamp comes on, you want it to turn the pump on for 10 minutes and
then off for 5 minutes. If you push the button, you reset the Stamp so it
starts over:
' Stamp II code
PUMP con 0
i var byte
j var byte
top:
HIGH PUMP
for i=1 to 10
gosub wait1min
next
LOW PUMP
for i=1 to 5
gosub wait1min
next
goto top
wait1min:
for j=1 to 60
pause 1000
' could do extra things every second here
next
return
Not Swiss watch accurate, but probably OK for what you want.
Good Luck!
Al Williams
AWC
* Prototype with RS232 - http://www.al-williams.com/awce/rs1.htm
> From: trike62@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=v6txLOU54o_m15kZ-KGGqDeemz91BxlWJTY9JJ4qorW5mw6ItXMQFhdS1_4S6fJUIjeEO86EGQ]trike62@a...[/url
> Sent: Friday, June 29, 2001 1:50 AM
> Cc: TRIKE62@a...
> Subject: [noparse][[/noparse]basicstamps] Newbie question
> Could anyone please tell me how I could control the time and duration an
> very good at
> designing them.
> from the same email address that you subscribed with. Text in
> the Subject and Body of the message will be ignored.
i have a program loaded and running in a basicstamp 2 from a long time
ago and can't find the source code. was wondering if there is a way to
upload the code from the bs2 to the pc (or display on the screen) in the
stamp windows editor.
thanks in advance,
mark
As far as I know once the program is on the stamp it is irretrievable.
Chris Shuster
http://www.cpuman.f2s.com/
Sent: Monday, October 22, 2001 3:26 AM
Subject: [noparse][[/noparse]basicstamps] newbie question
> hi all,
> thanks in advance,
> mark
just making sure that what i buy will do what i need it to do. i am
not making a robot or anything like that. i just need to create a
program that for every pulse of a switch the ouput can produce a led
display to show an indicated display and control a set of solenoids.
i plan on creating a semi-sequential shifter for my car. my car is
currently a 5 speed standard. i want to have a switch at the front
and back of my shifter (the shifter will be disconnected from the
linkages) so that when i push the shifter forward it would hit a
switch and show on a led display what gear i am in. and also to
have a proper output to control solenoids to change the gears. all
this is possible with the basic stamp 2? how about the basicx-24? i
also need this to work in -30 degree celcius weather too (it gets
pretty cold in canada during the winters). i know the basic stamp
has an industrial version but how about the basicx-24? i need all
the help i can get! thank you!
conrad andres
Can I program "Basic Stamps" in "C/C++" or I must
use only PBASIC?
thanks
/kmk
The Basic Stamp is an interpreter chip and can only be programed in pbasic.
If you want to use a chip that
can be programed in any other language, you will have to find one the uses
complied code. Compiled code is code
written in an other language and compiled to Assemble Code. These types of
chips are cheap, but the compiler
usually cost several hundred dollars. I am not sure if C/C++ is an interpreter
or a compiler if it is a compiler
look for a PIC chip that can be programed with C/C++. I am learning about the
Basic X-24 chip and the Atom chip,
I am not sure which one I read about but it uses compiled code. It is also
compatible to the Basic Stamp
Have Fun !!
Dale Fleischmann
kmk wrote:
> Hello all
> use only PBASIC?
> thanks
> /kmk
What is the theory of operation with the parallel interface to the Stamp I
board for programming it? This looks to be one of the wierdest connect
schemes I've seen. No doubt a clever trick of some kind.
i have just bought a Basic 2 stamp and need some advice when it comes to serial
comms.
On the web site WWW.MILINST.COM there is a 'On screen Display' unit or video
overlay circuit that you can drive with serial commands from a stamp.
I want to purchase this but are unsure what commands i would need to send it to
make it work. There is a data sheet but i am new to this and do not want to
waste my money purchasing it if it is to difficlt
So if someone can help can they give me a few examples of code that would put
the words 'How are you' on the screen for an example
Thanks for any help you give
Wayne
PS if you dont want to help please dont flame me!
drive this. It's serial. 2 pin; Txd/Rxd; 2400, 4800, 9600, 19200, and
38400 baud, 8N1. All the commands you send serially to the BOB are
documented in the application guide available on
http://www.decadenet.com/ BS2 specific code is show in this example;
http://www.decadenet.com/pub/awbob.pdf
By the way, XBOB is now shipping and superceeds the BOB3.
--- In basicstamps@yahoogroups.com, WLMOATE@A... wrote:
> Hi
comes to serial comms.
or video overlay circuit that you can drive with serial commands from
a stamp.
to send it to make it work. There is a data sheet but i am new to
this and do not want to waste my money purchasing it if it is to
difficlt
would put the words 'How are you' on the screen for an example
> Wayne
It should be fairly easy to talk to it. You'd just use the Stamps "Serin" and
"Serout"
commands
Infact, I might go and buy one. Although, at $210 NZ + postage, it may be a
while...
Cheers,
Ben.
Quoting WLMOATE@A...:
> Hi
> to serial comms.
> video overlay circuit that you can drive with serial commands from a
> stamp.
> send it to make it work. There is a data sheet but i am new to this and
> do not want to waste my money purchasing it if it is to difficlt
> Wayne
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
serial comms.
to make it work. There is a data sheet but i am new to this and do not want
Wayne
http://www.milinst.com/gemodules/6_940.pdf
There is a 12 page datasheet on the milinst site that explains all of
the commands that can be sent to the device. It's a neat little
device, I wish I had some use for one.
-selket
> Hi
comes to
> serial comms.
or video
stamp.
to send it
not want
would put
> Wayne
our air cannons and strobe flashes on the tomb scene. I was wanting
to automate this to just being able to press one button and the
sequence would time each step.Could I use a programed stamp plus
relays?
sequencer using a BASIC Stamp. Connect the outputs to proper drivers
and relays, and you're in business.
http://www.parallax.com/dl/docs/cols/nv/vol3/col/90.pdf
-- Jon Williams
-- Parallax
From: bbobbya10 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-491rwgQFE4cMrW9jbRS5zI0mIVR711A9H7gpw3T8DO2uZd2nwhjycpy9G_2NDbk1bLGc1TnF5TyS70]bbobbya10@y...[/url
Sent: Tuesday, March 09, 2004 8:36 PM
In our church productions we use manual controls(push buttons) for
relays?
can control through PBasic. You may have
to experiment a little to find the EXACT
timing you want, though.
--- In basicstamps@yahoogroups.com, "bbobbya10" <bbobbya10@y...>
> relays?
http://www.geocities.com/jimforkin2003/
jim
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=we117yDuJThbjFfYRD61tDprC5ZWPq-hqv3bNd0uZXLXoOg2mzcR4f6kzwTvFYDQhLkZz-8ltfK7FeZsLXua8tdMNQ]allan.lane@h...[/url
Sent: Wednesday, March 10, 2004 11:02 AM
Subject: [noparse][[/noparse]basicstamps] Re: newbie question
Yes. The stamp has 16 digital outputs you
> relays?
Yahoo! Groups Links
