serial transmitter
Archiver
Sending & receiving serial data between two Stamps is quite simple
with the RWS/TWS RF modules, but actually programming the Stamp
by RF would involve much more than simple wireless communications
between two Stamps.
Here's an example of controlling a robot via·wireless RF·to
show how simple this is. http://www.rentron.com/ruf-bot.htm
The Stamp requires several connections to the PC serial port to establish
a programming link.· These are RX,TX,DTR and the loop-back connection
between DSR & RTS.
Programming the Stamp via a wireless interface would require another
microcontroller that would emulate the Stamp programming software
on the receiving end, as well as another for the transmission circuit.
There's quite a bit going on between the Stamp and PC programming
connection, and a wireless device for actually programming the Stamp
would be quite a task.
Bruce Reynolds
webmaster@rentron.com
Affordable·Solutions For Stamp RF Remote Control
To: basicstamps@egroups.com
Sent: Wednesday, October 18, 2000 4:24 PM
Subject: [noparse][[/noparse]basicstamps] serial transmitter
Is it possible to send the RS232 serial signal that's used for programming the BS II by RF.
I have the TWS-434 and the RWS-434 from Renton and have been trying to find a way to
send new or updated commands to my BoEBoT without trying to catch it, to plug it into
the serial port. I'm sure there must be a way, we have a printer at work that communicates
both ways with the computer, but only works well at about 10 feet. I would like to try and
programme my BoT using a similar technique.
any help would be very much welcome.
thanks in advance
John
between two Stamps.
between DSR & RTS.
Bruce Reynolds
thanks in advance
John
thanks in advance
John
load, I would think that you could use Tracy Allen's excellent "stach"
module in conjunction with your rf link.
see http://www.emesystems.com/stachedat.htm
The stach can hold up to 15 stampII programs. You initiate program
downloads by pressing a single pushbutton. It seems you could bypass the
pushbutton with a relay which the stamp would control.
Then you could rf the number of the program you want to download to the
target stamp, and it would then control the relay to initiate the download.
Just a thought
Steve
project. It's not what I'm looking for at the moment though. My idea really
involves my BoT roving around the house when it bumps into something I
wanted it to send it's location back to the computer so I could create and
accurate map of the room. And also swap the Txer and Rxer around so that I
could send data from the computers serial port directly to the stamps serial
interface to change the onboard programme.
Thanks anyway.
John
To: <basicstamps@egroups.com>
Sent: Thursday, October 19, 2000 12:05 AM
Subject: Re: [noparse][[/noparse]basicstamps] serial transmitter
> If you will know ahead of time the alternate programs that you may wish to
download.
> Just a thought
> Steve
>Thanks for you idea, sounds really good, and I may use this as a future
You might consider a scheme where the current data is retained in onboard
memory (i.e. separate Local_Map EPROM(s) ), and these are offloaded on
excursions back to Home_Base (for re-charging, re-programming or
what-have-you). These Local_Maps can be in any simple (bit, byte or
character) format you wish, since the manipulation is pre-defined (noted
below) to occur on the PC. The Local_Maps are merged into larger grids
(Excursion_Grid_Maps, Room_Grid_Maps, Yard_Grid_Maps, etc) with subsetting
and supersetting (like words on a page, pages in a chapter, chapters in a
book, book on a shelf, shelves in a library, etc). In the end you have a
Robot Atlas of it's travels, both for historical, and future expeditionary
purposes.
You may find that is not necessary, if you use the BS-2SX or BS-2SE and use
Tracy Allen's Stache facility, as others have mentioned. Although the
intent may have been for data logging, it has MANY other uses.
Re-programming on the fly, has many downsides, and the extra errors
introduced (even if it could be done via RF) would NOT be worth the
headaches (my opinion only). Just as a simple for instance, the Stamp would
have no way to respond to a parity, CRC or ECC check. Thus. although the RF
link may be sound, other elements in that link may NOT be so. Vibration,
heat, static, and all sorts of other things can cause varios problems over
time.
>Thanks anyway.
>John
Just some additional thoughts
Bruce Bates
>From: <sargent@s...>
>download.
> > Just a thought
> > Steve
away from it just now.
I'm going to try and stick to me original idea for the moment.
Thanks anyway
john
Sent: Thursday, October 19, 2000 1:18 PM
really
and
> purposes.
serial
use
would
RF
> time.
> >Thanks anyway.
> >John
> Regards,
> Bruce Bates
wish to
the
the
> >download.
> > > Just a thought
> > > Steve
