Messy code
hello all: I have a light seeking robot. currently it has a CDS cell on each
side at a 45 degree angle foward. When I detect light on the left I rotate
the robot towards the light. I use some code to detect the light intensity
differance between the 2 cells,and rotate the robot faster,if it is a higher
value differance between left and right,then he rotates slower as the light
gets more centered,and intensity differential is less.
Currently I use a jillion IF statments to determine how fast to
rotate,based on the light intensity differential, there must be a better
way then to use all these IF statements, I need a large group for left and
right, and hate to waste code space.
Currently I have the following code,it works fine,but is wasting program
space,and it has to be duplicated for the right sensor as well.
I have not filled the Stamps memory yet,but dont want to throw it away
needlessly either<S>
I thought of a lookdown table,but am confused on there useage,they are so
much greek to me. I did read the manual many times
Intensity = leftCDS - RightCDS
if intensity < 300 go to forward 'light is centered so drive forward
if intensity < 500 then leftdelay1
if intensity < 600 then leftdelay2
if intensity < 700 then leftdelay3
etc etc etc many lines of these IF statments
leftdelay1
delay = 1 ' delay speed to be used in servo turn
goto LEFT ' go to the subroutine that turns robot left
leftdelay2
delay = 2
goto LEFT
LEFT
etc etc code, that turns the robot and has a delay associated with turn speed
for x = 1 to 10 * delay
servoleft etc etc
servoright etc etc
next
delay = 0 'reset delay speed
and then of course all the right light checks and IF statments repeated.
thankyou all very much
Sincerely
Kerry
Admin@M...
WWW server hosting
[url=Http://mntnweb.com]Http://mntnweb.com[/url]
Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
--So you think you need more memory... the LEM went to the moon on 16K,how
much do you REALLY need?
leftdelay1
leftdelay2
delay = 2
goto LEFT
LEFT
servoleft etc etc
servoright etc etc
next
Sincerely
Kerry
Admin@M...
WWW server hosting
be), you might consider this:
branch (intensity-300)/100,[noparse][[/noparse]forward,leftdelay1,leftdelay2...]
This will take your intensity and convert it from 300 -> 0, 400 -> 1, 500 ->
2, etc.
Then the branch statement will do what you want. If you want to catch, say,
300 and 400, just use the same label twice:
branch (intensity-300)/100,[noparse][[/noparse]forward,forward,leftdelay1,....]
Also put something after the branch in case nothing matches.
branch ....
goto top_loop ' or wherever
How's that?
Al Williams
AWC
* 8 channels of PWM: http://www.al-williams.com/awce/pak5.htm
> From: Kerry Barlow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4TWhneK0gaU3_k8nE869AL-SQNFEyIgLhmqP-fMyXm7mU3wtqZmZa4Ao0Dty_w4qllhVwnq0F1JrjA3u]admin@m...[/url
> Sent: Wednesday, October 18, 2000 11:52 AM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Messy code
> cell on each
> is a higher
> the light
> leftdelay1
> leftdelay2
> delay = 2
> goto LEFT
> LEFT
> with turn speed
> servoleft etc etc
> servoright etc etc
> next
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
> on 16K,how
There's not too many ways to make it neater unless a language like
Visual Basic is used. But try this:
'With the BSII:
lookdown intensity,<[noparse][[/noparse]300,400,500,600,etc...],result
delay=result+1
Lookdown will return the first position it is in the list that it is
less than.
DJ
cell on each
rotate
intensity
a higher
the light
better
left and
program
away
are so
forward
> leftdelay1
> leftdelay2
> delay = 2
> goto LEFT
> LEFT
turn speed
> servoleft etc etc
> servoright etc etc
> next
repeated.
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
16K,how
Why do you need conditional branching statements at all? Would it work to
simply use the value from intensity to get delay?
Something like
delay = intensity / 100 - 4
Guess you'd still need one If statment for forward, but it seems to me you
bot doesn't need to make nearly as many decisions based on intensity as it
is doing now. It just needs to get a value.
Greg R.
To: <basicstamps@egroups.com>
Sent: Wednesday, October 18, 2000 12:51 PM
each
higher
light
> leftdelay1
> leftdelay2
> delay = 2
> goto LEFT
> LEFT
speed
> servoleft etc etc
> servoright etc etc
> next
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
16K,how
Here's a short routine that takes care of forward, right and left and
intensity. The intensity values seem to be equally spaced
(500,600,700,...?) for different delays, so there is no need for a lookdown
table. As Greg pointed out, simple mathematical formula will do. The
direction is determined by the sign of the difference between the two
photocell signals, and the delay is determined by the absolute value of the
intensity. There is no need to repeat everything for left and right.
intensity var word
sign var bit
delay var byte
intensity = leftCDS - RightCDS ' difference, negative if rightCDS>leftCDS
sign = intensity.bit15 ' direction? sign=0 means left is greater
intensity = abs intensity ' absolute value of intensity
if intensity<300 then forward ' light is centered so drive forward
delay=intensity/100 min 5 - 4 ' formula for delay
branch sign [noparse][[/noparse]LEFT,RIGHT] ' now have all info for either right or
left.
If the intensity values are not evenly spaced, then use a lookdown table in
place of the formula:
lookdown intensity,<[noparse][[/noparse]300,550,690,777,926,1987,7257,10460,32768],delay
' delay from 1 to 8 (arbitrary table entries)
The "<" before the table qualifies the relation to be satisfied. The delay
can never come out =0, because at this point in the program, intensity>300.
The final 32768 catches all of the highest possible values of intensity
from 10460 to 32768. On the Stamp, the absolute value of a number will
fall in the range 0<=intensity<=32767.
I hope that helps,
-- Tracy Allen
http://www.emesystems.com
each
rotate
intensity
higher
light
and
so
> ..snip...
