debug
Hi:
Where can I find the debug commands for programming stampplotpro?
I dont find them in the basic stamp manual.
I'm a little confused.
I have the Industrial controls manual and I have to work with what
they have. I would like to write my own programs but need a little
help from someone.
Jim
help from someone.
Jim
--- In basicstamps@egroups.com, "James Hardy" <jahardy33@h...> wrote:
> Hi:
> help from someone.
> Thanks
> Jim
anyone have a suggestion about better documentation than is in the stamp2
book?
Patty
related to the bs1, but it is the best stamp documentation around. Great
sample code and explanation of each command. Once you look at that for a
while its easy to relate it to bs2 etc.
Chris
Sent: Monday, April 09, 2001 2:21 AM
Subject: [noparse][[/noparse]basicstamps] Debug
> I am finding the debug function on the BS2 editor to be very confusing.
Does
> book?
> Patty
Sounds like a book that I could use too.
Where can one obtain a copy.
TIA
Sean
> Scott Edwards electronics make a great book called "Counterfeit", its only
> Chris
am in Australia and got it from our distributor.
Chris
Sent: Monday, April 09, 2001 7:11 AM
Subject: Re: [noparse][[/noparse]basicstamps] Debug
> Hi Chris
> TIA
> Sean
only
> > Chris
one point me to a good explanation of how to use the debug commands to help
trouble shoot programs ??
I have read what the manual says and its a little fuzzy to me.
Bob
There are two techniques that are useful when doing this kind of
debugging. One is to "look inside" your program and the other is to
"divide and conquer".
Let's say you write the following program (not a great program, but it
makes my point):
X var byte
Loop:
X=1
Gosub process_x
X=X+1
If x>10 then exit_loop
Goto Loop
Exit_loop:
Debug ?x
Now, just looking at this you may or may not see what is wrong with it.
So you might want to "look inside" and put "Debug ?x" somewhere inside
the loop. Then it will become painfully obvious what the problem is.
Divide and conquer is good when you aren't sure about the flow of your
program. This like troubleshooting an old radio. Cut it in half and
decide if the problem is in the first half, or the second half. Repeat.
Eventually you'll get such a small cut that you know where the problem
is. Let's say you have this program:
Main:
gosub setup_xmit
x=INA
gosub send_data
gosub wait_ack
pause 5000
Goto Main
When you run this, nothing seems to happen. Why? One way to tell might
be:
Main:
debug "Calling setup_xmit..."
gosub setup_xmit
debug "Returned",cr
x=INA
debug "Sending data..."
gosub send_data
debug "Returned",cr
debug "Waiting..."
gosub wait_ack
debug "Returned",cr
pause 5000
Goto Main
Now you can see what is happening:
Calling setup xmit....Returned
Sending data...
Ok, so something is hanging in send_data. Your next step is to modify
send_data so you can see the steps there until you can find the part
responsible for hanging the program.
In the bad old days, it was common to try to reserve 3 or 4 bits of I/O
for a debugging port. You could output a binary number on a logic
analyzer or LEDs to see the progress of your program like this. I
actually did a 6805 system back in the 80s that beeped out diagnostics
in Morse code on a speaker :-)
Hope that helps!
Al Williams
AWC
> From: ROBERT PHILLIPS [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FjjHgFHxMOe9UQGFfKMu9KBRafENMykdPkxOjP7sAOlQmt2uyfmVlSXmCfQW7ulPWqL6KXT0QVc]robertp@v...[/url
> Sent: Thursday, February 20, 2003 7:52 AM
> Subject: RE: [noparse][[/noparse]basicstamps] Debug
> Bob here, I am working some simple LED examples with the BOE
> kit. Can some one point me to a good explanation of how to
> use the debug commands to help trouble shoot programs ??
