[Re: [basicstamps] Basic Stamp II]
Lincoln,
I am very interested, and I thank you for your reply. I am building a zero
crossing detector with a transformer a diode and an op amp, but this may not
be the best way. I am familiar with the electronics, but I am not familiar
with microprocessors and programming, but I am learning. Any help on the way
the program code should be wrote would also be greatly appreciated.
Josh
Lincoln Worsham <liworsha@g...> wrote:
jbw0592@n... wrote:
> I am trying to build an automatic dawn simulator. I want it to start
> gradually brightening a light over a period of 30 minutes, where it
> will reach it's peak brightness. I have the Basic stamp 2 starter
> kit, a DS1302 real time clock, and a triac. The plan is that when the
> clock hits a given time the microprocessor will start slowly
> adjusting the firing angle to the triac which will step up the
> voltage given to the light. My problem is that I am not sure how to
> handle the programming. Any help on what commands I should use in
> order to control the triac would be greatly appreciated.
> Thanks,
> Josh
> jbw0592@n...
you will probably want to look at setting up an opto-daic to fire the
triac, i have built dimmer packs before and the way i did it was to have
the basic stamp give a value to an eight bit d/a chip, that fed the
analog dimmer packs, the analog dimmers consisted of a compairitor with
one input tied to a ramp circuit that was triggered and the ac zero
crossing, the other would be the analog control signal, the compairitor
fired an opto-diac which fired 4 trac's in parallel to get a channel
rating of 2.4kw, if your interested i can did up the part numbers
lw
____________________________________________________________________
Get your own FREE, personal Netscape WebMail account today at
http://home.netscape.com/webmail
Josh
> Thanks,
> Josh
> jbw0592@n...
lw
