Creating a user interface on the B2-SX
Archiver
You could take a look at Jon Williams' June 2000 Stamp Applications in Nuts
& Volts (http://www.nutsvolts.com) if you need pointers on setting up such a
user interface using LCD & keypad. I'm sure that the transition from BS-II
to BS-2SX should be straight-forward.
Daniel McGlothin
From: fernando hood [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zF6jMrhZaUps__FpW6sVJlaoBq97kLRYasTit8AotqWJ6vC47QFyUXM3134U_bY2Kk7tPNySqpAFQQ]hoodey@h...[/url
Sent: Monday, October 09, 2000 1:35 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Creating a user interface on the B2-SX
Sound like the same question I was aksing.
I think you need an LCD terminal with Keppad.
>From: alan_correia@h...
>Reply-To: basicstamps@egroups.com
>Subject: [noparse][[/noparse]basicstamps] Creating a user interface on the B2-SX
>Date: Mon, 09 Oct 2000 12:28:42 -0000
>Hi everyone,
>I'm fairly new to this eGroups.
>I was wondering if there is a way to create a simple user interface
>on the Windows Terminal screen. I am currently using the 1.091 beta
>version (Stampw.exe).
>What i would like to do is ask a question, such as select a servo
>number between 1-4.
>The user inputs a number. I want to store in this number somewhere.
>Ask a second question, Select the range to move to?
>The user selects a number between 850 and 3050.
>Again i want to store the number.
>Using the answer to the first and second question, i wanna be able to
>move the corresponding servo and move to the desired range.
>So basically what i want to know is how to detect which numbers are
>pressed and also how to send it back to the Basic Stamp?
>Any ideas would be appreciated. I'm fairly show i connected the
>cable's up correctly in order to fit in with the RS-232 settings.
>Thanks alot.
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
Daniel McGlothin
>Hi everyone,
>number between 1-4.
>Thanks alot.
>Hi everyone,
>number between 1-4.
>Thanks alot.
