Byte handling
I have the following byte data captured using SERIN.
DATA(0)=49 (ASCII 1)
DATA(1)=52 (ASCII 4)
DATA(2)=50 (ASCII 2)
I would like to do query these 3 bytes at once. The basis of the
query is
"If FREQ = 142 then do_lamp"
where FREQ is the ASCII equivalents of the 3 bytes..it represents
14.2MHZ as seen in the serial data from my radio.
I've managed to do it with a bunch of "IF..Then" statements and
queried each byte but I am looking for a shorter and smoother way.
I do have it working just fine but if there is a better way, there is
always room to learn more.
Jay
query is
Jay
Well, there are a few options. The best way would be to rewrite your SERIN
so that it didn't read it as bytes:
serin x,y,[noparse][[/noparse]blah..., dec3 freq,....]
This would read the 3 bytes in as an integer. Then you could do just what
you want:
if FREQ=142 then...
However, maybe thereis a reason you can't do that.
How about (data is a reserved word, so I'll use xdata):
FREQ=xdata(0)-$30*100+(xdata(1)-$30*10)+xdata(2)-$30
if FREQ=142 then ....
I think I got the parens right. Keep in mind the BS2 does math right to
left. So the idea is to -$30 from each byte (convert "0"-"9" into 0-9). Then
multiply the first digit by 100, the second digit by 10, and add all the
digits together.
Al Williams
AWC
*8 channels of PWM: http://www.al-williams.com/awce/pak5.htm
> From: Jay Kobelin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EpYVjZ165yxwMTmfyI-JjVNIsBmUFu7OhQ00A-M_t23rDoJVnDUQk7cQxNAjfMsQjVfLI8JV_deBrA]pcb4u@e...[/url
> Sent: Sunday, October 08, 2000 1:50 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Byte handling
> query is
> Thanks
> Jay
be used like this so make it dataa or something
if you add them like your thinking then if one number goes up by 1 and
another goes down by one you get the same value
if data(0) = 49 and data(1) = 50 and data(2) = 51 then do_lamp
> query is
> Thanks
> Jay
Bingo!!
The process of subtracting $30 works....now, could you briefly describe why
"0" becomes 0 and the use of the multipliers. I have always dealt with high
level English programming and never got involved with the bytes .. I let the
compiler do that!!
Thanks a bunch..
I tried going another byte to test the 10khz bit (1426 where the 6 would be
the next byte) using 1000 as a multiplier, then 100, etc...but that didn't
work.
(where 1=10 MHZ, 4=mhz, 2=200khz, 6=60khz or a final frequency readout on
the radio of 14.26mhz)
Jay
To: <basicstamps@egroups.com>
Sent: Sunday, October 08, 2000 12:04 PM
Subject: RE: [noparse][[/noparse]basicstamps] Byte handling
> Hi Jay,
> you want:
> if FREQ=142 then...
Then
> digits together.
> Regards,
> Al Williams
> AWC
> > From: Jay Kobelin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aFAP08MmlfZW_do13otfeXz2Nm30JCkbD5G9NNO79U1ehjEqvx39p8pbZGvuOQLrAMd7u_n3UfYN6TKJWA]pcb4u@e...[/url
> > query is
> > Thanks
> > Jay
x-$30 is 0 to 9.
Now for multiplying, remember somewhere a long time ago, we learned that:
4235 is really
4 * 10**3 + 2 * 10**2 + 3 * 10**1 + 5 * 10**0 (where ** is exponentiation)
So:
4*1000 + 2*100 + 3*10 + 5*1 (10**0 is 1)
And therefore:
4000 + 200 + 30 + 5 = 4235.
Of course, the Stamp does math left to right, not in the usual order, so we
have to add parenthesis.
You should have been able to get it to work for 1000 just by moving
everything over one:
xdata(0)-$30*1000 + (xdata(1)-$30*100) + ....
You can also take advantage of the fact that 10*10 is 10 squared and
10*10*10 is 10 cubed, etc, and write a clever loop:
FREQ=0
for i=0 to lastdigit
FREQ=FREQ*10+xdata(i)-$30
next
This will do any number of digits up to last digit. Consider 4235 in the
xdata buffer.
On the first loop, FREQ=4
Next time, it will equal 40+2 or 42
Then 420 + 3 or 423
Finally 4230 + 5 or 4235, the correct answer.
Al Williams
AWC
*Measure 8 pulse channels at once: http://www.al-williams.com/awce/pak7.htm
> From: Jay Kay [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=V2fVThkEzzPsJ3EF5t2p0BCnghHP6VC-xdf9bxbkAbS6xBFaZi26kgrA5HohM1sjotW7ZYd3ice8yw]pcb4u@e...[/url
> Sent: Sunday, October 08, 2000 4:41 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Byte handling
> Al,
> Bingo!!
> describe why
> dealt with high
> .. I let the
> compiler do that!!
> Thanks a bunch..
> 6 would be
> work.
> Jay
> From: Al Williams <alw@a...>
> > Hi Jay,
> your SERIN
> just what
> > you want:
> > if FREQ=142 then...
> Then
> > digits together.
> > Regards,
> > Al Williams
> > AWC
> > > From: Jay Kobelin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=V2fVThkEzzPsJ3EF5t2p0BCnghHP6VC-xdf9bxbkAbS6xBFaZi26kgrA5HohM1sjotW7ZYd3ice8yw]pcb4u@e...[/url
> > > query is
> > > Thanks
> > > Jay
four positions...
Thanks Al...your support is welcomed
Jay
Sent: Sunday, October 08, 2000 4:08 PM
> Well, "0" is $30, "1" is $31.... "9" is $39. So if x is "0" to "9" then
> x-$30 is 0 to 9.
> 4235 is really
> So:
> And therefore:
we
> FREQ=0
> next
> xdata buffer.
> Then 420 + 3 or 423
> Regards,
> Al Williams
> AWC
> > From: Jay Kay [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZdHUL-7VFZ_W3SiXO64iOfZDlR4xCQRtoMZ7ujQzAuN8EYsg69uOwzTqah34gOR5OlNWaCkqA-JxC1rq]pcb4u@e...[/url
> > Al,
> > Bingo!!
> > describe why
> > dealt with high
> > .. I let the
> > compiler do that!!
> > Thanks a bunch..
> > 6 would be
didn't
> > work.
on
> > Jay
> > > Hi Jay,
> > your SERIN
> > just what
> > > you want:
> > > if FREQ=142 then...
to
0-9).
> > Then
the
> > > digits together.
> > > Regards,
> > > Al Williams
> > > AWC
> > > > From: Jay Kobelin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZdHUL-7VFZ_W3SiXO64iOfZDlR4xCQRtoMZ7ujQzAuN8EYsg69uOwzTqah34gOR5OlNWaCkqA-JxC1rq]pcb4u@e...[/url
> > > > query is
is
> > > > Thanks
> > > > Jay
