Control Motor Speed and count at the same time?
Can anybody tell me wether or not any of the basic stamps are capable
of allowing me to use PWM to control the speed of a DC Motor, via a H-
Bridge, and count pulses from an encoder at the same time? This is
for a two axis robot system that I would like to build.
Dan
Dan
Stamps and PAKs to do what you want. In particular:
PAK-IV - a PAK-IV (or a PAK-III) can generate PWM like the Stamp does (a
burst of proportional pulses) or count like the Stamp does. It too only does
one thing at a time, but the Stamp and the PAK-IV can both do one thing each
at a time.
PAK-V - The PAK-V generates 8 channels of 8-bit PWM at the same time without
stopping. The Stamp can send a command to the PAK-V and change the PWM rate.
It never stops or hiccups even when the Stamp sends commands (unless you
send the command to turn off a channel, of course, at which point it stops
that channel).
PAK-VII - The PAK VII can measure pulse width and count pulses (on 8
channels) in a very flexible way without intervention from the Stamp. The
Stamp simply reads the pulses when it is ready.The counts go to 16 bits.
The other alternative would be to use a counter and shift register to count
the pulses and shift them into the Stamp a bit at a time. This is more or
less what the PAK-VII is, but it also measures pulse widths and does 8
channels at once!
You can read the manuals for these at
http://www.al-williams.com/awce/doclib.htm
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce/pak1.htm
> From: mcruz1@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oDOCmv1rrGEpMgEGRJ26hEF0AD7iLnVvEgYAhdotIQrkGveOXidJxVtdJXDq6rsevTzisXPyshFR]mcruz1@t...[/url
> Sent: Sunday, October 08, 2000 9:42 AM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Control Motor Speed and count at the same time?
> Dan
