Yes, I'm interested in the best schemo for simple sound detection.
-William
To: <basicstamps@egroups.com>
Sent: Wednesday, October 04, 2000 5:08 PM
Subject: [noparse][[/noparse]basicstamps] MIC and BS-II
> RE-POSTING!!
> How does one sense sound using BS-II using a mic and lm386 (or
> better) ? Please help with any ideas!!!
> If you have better ideas, please suggest - I'm new to BS-II and
> electronics.
> Thx a lot
> Jack
One other thing, since my robot has wheels, the sound from the servos
could interfere with the sound detection. I'm not sure how to filter
that off. Your ideas are needed here.
thx
Jack
> -William
> From: <support@c...>
> > RE-POSTING!!
> > electronics.
> > Thx a lot
> > Jack
I was thinking that I could stop for a second every few cycles, check
sound and proceed. This might be a good idea. I know that Nagi's
ALIBE (miniature autonomous robot) does this too. In his application,
it was okay to pause every few cycles to detect. It might be okay
with my application as well...
Your ideas might give me another perspective...
thx
Jack
servos
filter
> thx
> Jack
> > -William
> > > RE-POSTING!!
> > > electronics.
> > > Thx a lot
> > > Jack
Depending upon your "power plant" and/or energy source, you may find that -
1) you have to, or 2) it is more desirable than you imagine at the moment.
By way of example, Alkaline batteries do REAL well, when given a chance to
recuperate. Steady current drain is NOT in their best interest
- recharagable or not.
Just my 2 cents
Bruce Bates
>thx
>Jack
>servos
>filter
> > thx
> > Jack
> > > -William
> > > > RE-POSTING!!
> > > > electronics.
> > > > Thx a lot
> > > > Jack
Thank you. How should I go about detecting sound. Please advise.
Jack
check
application,
find that -
moment.
chance to
> Just my 2 cents
> Bruce Bates
> >thx
> >Jack
> >servos
> >filter
> > > thx
> > > Jack
detection.
> > > > -William
> > > > > RE-POSTING!!
(or
and
> > > > > electronics.
> > > > > Thx a lot
> > > > > Jack
RE: [noparse][[/noparse]basicstamps] Re: MIC and BS-II
Hi Jack,
This is what I did.
I used a LM386 Op-Amp (Audio amp) and IC. Hooked them up as per the data sheet. The MIC connects to the Non-Inverting input Pin3 on the LM. The output from the LM is off of the pin5 that can be hooked up with the BS2's pin and checked for hi when sound is detected.
Now, this will basically tell you whether there is sound or not. If you want to check the level of sound, one must use ADC chip to figure that out I think.
Hope this helps
P.S:
I'm new to BS2 and electronics too. I get help and info from all the gurus who participate in this newsgroup forum and also from the tech support guys at parallax.
Jack
check
application,
find that -
moment.
chance to
> -· recharagable or not.
> Just my 2 cents
> Bruce Bates
> >thx
> >Jack
> >servos
> >filter
> > > thx
> > > Jack
detection.
> > > > -William
> > > > > RE-POSTING!!
(or
and
> > > > > electronics.
> > > > > Thx a lot
> > > > > Jack
Hey Jack,
had a typo error
Read this line ·············· "I used a LM386 Op-Amp (Audio amp) and IC."
AS
·············· "I used a LM386 Op-Amp (Audio amp) and PCB mountable MIC from radio shack"
thanks
nagi
Sent: Thursday, October 05, 2000 11:33 AM
To: 'basicstamps@egroups.com'
Subject: RE: [noparse][[/noparse]basicstamps] Re: MIC and BS-II
Hi Jack,
This is what I did.
Hope this helps
P.S:
Jack
check
application,
find that -
moment.
chance to
> Just my 2 cents
> Bruce Bates
> >thx
> >Jack
> >servos
> >filter
> > > thx
> > > Jack
detection.
> > > > -William
> > > > > RE-POSTING!!
(or
and
> > > > > electronics.
> > > > > Thx a lot
> > > > > Jack
REPOSTING - due to server error. Please ignore if already received - thanks
Hey Jack,
had a typo error
AS
thanks
nagi
Hi Jack,
This is what I did.
Hope this helps
P.S:
Jack
check
application,
find that -
moment.
chance to
> Just my 2 cents
> Bruce Bates
> >thx
> >Jack
> >servos
> >filter
> > > thx
> > > Jack
detection.
> > > > -William
> > > > > RE-POSTING!!
(or
and
> > > > > electronics.
> > > > > Thx a lot
> > > > > Jack
electronics.
Thx a lot
Jack
-William
> RE-POSTING!!
> electronics.
> Thx a lot
> Jack
thx
Jack
> -William
> > RE-POSTING!!
> > electronics.
> > Thx a lot
> > Jack
thx
Jack
servos
filter
> thx
> Jack
> > -William
> > > RE-POSTING!!
> > > electronics.
> > > Thx a lot
> > > Jack
Just my 2 cents
Bruce Bates
>thx
>Jack
>servos
>filter
> > thx
> > Jack
> > > -William
> > > > RE-POSTING!!
> > > > electronics.
> > > > Thx a lot
> > > > Jack
Jack
check
application,
find that -
moment.
chance to
> Just my 2 cents
> Bruce Bates
> >thx
> >Jack
> >servos
> >filter
> > > thx
> > > Jack
detection.
> > > > -William
> > > > > RE-POSTING!!
(or
and
> > > > > electronics.
> > > > > Thx a lot
> > > > > Jack
Hi Jack,
This is what I did.
Hope this helps
P.S:
nagi
From: Jack Olson [noparse]/noparse][url=mailto:BS2Newbie@crosscity.com]mailto:BS2Newbie@crosscity.com[/url
Sent: Thursday, October 05, 2000 9:30 AM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Re: MIC and BS-II
Jack
check
application,
find that -
moment.
chance to
> Just my 2 cents
> Bruce Bates
> >thx
> >Jack
> >servos
> >filter
> > > thx
> > > Jack
detection.
> > > > -William
> > > > > RE-POSTING!!
(or
and
> > > > > electronics.
> > > > > Thx a lot
> > > > > Jack
Hey Jack,
had a typo error
Read this line
······· ······· "I used a LM386 Op-Amp (Audio amp) and IC."
AS
······· ······· "I used a LM386 Op-Amp (Audio amp) and PCB mountable MIC from radio shack"
thanks
nagi
Hi Jack,
This is what I did.
Hope this helps
P.S:
nagi
Jack
check
application,
find that -
moment.
chance to
> Just my 2 cents
> Bruce Bates
> >thx
> >Jack
> >servos
> >filter
> > > thx
> > > Jack
detection.
> > > > -William
> > > > > RE-POSTING!!
(or
and
> > > > > electronics.
> > > > > Thx a lot
> > > > > Jack
Hey Jack,
had a typo error
Read this line
AS
thanks
nagi
Hi Jack,
This is what I did.
Hope this helps
P.S:
nagi
Jack
check
application,
find that -
moment.
chance to
> Just my 2 cents
> Bruce Bates
> >thx
> >Jack
> >servos
> >filter
> > > thx
> > > Jack
detection.
> > > > -William
> > > > > RE-POSTING!!
(or
and
> > > > > electronics.
> > > > > Thx a lot
> > > > > Jack
