Looking for a sensor
Archiver
I'm trying to make a speedometer for a scooter and need to find a good
sensor to attach to the Stamp. The sensor will need to pick up to 20
revolutions of the wheel per second at full speed. The tires are solid
rubber so I can wedge something reflective or a magnet in its side. I was
looking through catalogues but only found light sensors and phototransistors
but from the specs I can't figure out how fast they are. Does anybody know
of a sensor that detects magnetism or metal? and are there other types of
sensors I could use?
Thanks in advance,
Alex
Thanks in advance,
Alex
Bicycle speedometers use a magnet on the wheel and a magnetic reed switch on
the fork. Radio Shack has reed switches that may be sensitive enough. You
will need to debounce the reed switch output.
Ray McArthur
phototransistors
know
You could use a reed switch if the clearances are small enough. reed
switches are switches triggered by magnetic current. As the magnetic field
goes by, the reed switch turns on. Bill
PS to my last post:
20 closures per sec may be pushing the speed of a reed switch... they are
cheap enough to buy and test. If they are too slow, consider a Hall-effect
IC.
Ray McArthur
phototransistors
know
if I recall right. Just have the magnet pass thru it to get a pulse
Jay
To: <basicstamps@egroups.com>
Sent: Monday, October 02, 2000 6:36 PM
Subject: [noparse][[/noparse]basicstamps] Looking for a sensor
> Hi,
phototransistors
know
> Thanks in advance,
> Alex
I think I'll try a hall effect transistor. It looks as though the reed
relays are larger and slower than the transistors.
Thanks for all your help.
Alex
From: Jay Kay [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=R8lawAbVAT7SEGGN6uWckgsW3LzIP1MeXRH9PTxTKBPLgUvvJWA9pZGA_UyvPGd3mngq3iUFMsznLVUV]pcb4u@e...[/url
Sent: Monday, October 02, 2000 10:21 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Looking for a sensor
Try looking at Hall effect transistors..they are used in car's distributors
Jay
> Hi,
phototransistors
know
> Thanks in advance,
> Alex
From: Alejandro Fubini [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Dg9TVN2pA96b0RnLRiSKB7_jJCteTRaSiLp_XN1kIaV0TBu0xH6PfeOTOEsYR2ZC853122_Zot0gGHH8zqV-o1BD]alex@f...[/url
Sent: Tuesday, October 03, 2000 10:50 AM
Subject: RE: [noparse][[/noparse]basicstamps] Looking for a sensor
Alex
From: Jay Kay [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=w6T3eA1fkoEVtJfxK9rdocNgnUT3qY10cbaGv7C_facmx4FP8-U6VjqdEurSPhWnyPAMRqGCkGHTU81O]pcb4u@e...[/url
Jay
> Hi,
phototransistors
know
> Thanks in advance,
> Alex
