How do I stabilize fluctuations in a switch circuit - BUTTON will not work in t
Archiver
I am doing a fluid control application currently that uses float
switches. I used to have the circuit built strictly using AC with no
microelectronics.
The circuit basically has a manually acutated switch. When you flip the
switch into an upward position, it opens an AC valve which fills a
container until the float switch is tripped. Upon tripping the float
switch, the valve is deactivated simply because the float does not allow
sufficient AC to pass and activate the 120V Valve's coil (thus opening
the valve). You can then flip the three-position manual switch to the
down position, at which time it opens a second valve and dispenses the
liquid from the container. When the switch is in the middle, all
circuits are off.
I am trying to move this to a microcontrolled version to ensure that the
users of the application are not leaving the switch in the "down"
position and burning up expensive valves. I admit that I am a rookie
when it comes to microelectronics, however, I was a CIS major in college
- so the programming comes easy. My problem is the following:
The same float switch used in the above AC applications is supposed DC
current (it's just a switch). I'm assuming that there is some form of
magnetic switch in the stem of the switch, and the float contains
magnetic elements which "close" or "open" the switch (depending on NO or
NC operation) simply by pulling it closed via magnetic field when the
float surrounds the portion of the stem holding the switch element.
Samples of the valves are at www.madisonco.com.
I tried to do a simple circuit today with a LED and the float switch.
The program simply set the output equal to the input and the switch was
wired from Vdd to P15. When I moved the float up and down, I saw some
fluctuations in the LED but it did not turn off. Debug output also
showed that the switch appeared to be fluctuating between off and on
states.... If I applied a PAUSE 600 command in the loop that was
checking the switch - the light would randomly turn on and off.
I am assuming that this switch is reliable, however, the magnetic nature
probably "opens" and "closes" the switch rapidly CONSTANTLY (which means
BUTTON is not a sufficient solution). I even monitored PULSIN, and the
pulses from the switch vary greatly depending on how "quickly" the float
is acutated.
I tried hooking the swtich from Vss to P15 also, with similar results. I
also tried using 100,000k resistor in series with the valve to dampen the
level a little, but still the same effect occured. I was going to try
using an OP-AMP, however, I dont think that would be appropriate in this
instance, because I dont think it's a "threshold" voltage issue, it's an
issue where the reed in the switch is vibrating constantly rather than
"staying put"
Any ideas on how I can stabilize this circuit to provide accurate
results?
Bob.
________________________________________________________________
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
microelectronics.
circuits are off.
is acutated.
"staying put"
results?
Bob.
> the switch was wired from Vdd to P15.
Do you have a pulldown resistor from P15 to Vss? It won't work reliably
without it.
| switch
Vdd
o~o
;---- P15
Vss
10k
Sometimes it is a good idea to put a 0.1uf capacitor in parallel with the
resistor to knock out the switch bounce or induced noise.
-- Tracy
>microelectronics.
>circuits are off.
All switches have specific characterisitcs which must be observed in their
application. Sadly I see no such specifications on the website. However, if
a switch has silver contacts, DO NOT use it in DC applications. The contact
can weld shut if the current and voltage are high enough.
Your presumption is correct. The "switch" is called a reed switch, and the
magnet inside is circular,. Thus. when the central part of the reed switch
passes thru the magnetic flux, it actuates the switch. Just for the record
these switches are made in N.O. (normally open) and NC (normally closed)
configurations. I'd guess this was a NO switch whcih closes when the reed
switch actuates.
>is acutated.
All that is true, EXCEPT. it should reach a fully open state somewhere in
that passage through the magnetic ring. Just remember from grade school
demonstrations with magnets that the flux area is circular and opposite (in
direction; ergo - perpendicular). So there may be a LARGE area where
activity takes place. It's hard to determine how large, and how strong
without instrumentation (a gaussmeter).
>"staying put"
Try using a Schmidt trigger gate or a one-shot inline with the logic
circuitry, if you have one around. Otherwise this may indeed be a "speed"
issue.
>results?
A copy of that section of your program might help - just to check it.
>Bob.
Bruce Bates
>microelectronics.
<SNIP>
In my experience, float switches used to be mercury tilt switches. Since
mercury is now poisonous, recent designs use a metal ball that rolls into a
set of contacts when the float rises (float rolls over as it does so).
Are you using independent pins for your inputs and
outputs?...Also, are you supplying your float switch
with a +5vdc and sending that signal through a N.C.
contact within the switch to a pin on the stamp?...
Assuming you are, you should have a pull down
resistor attached to your input pin which connects
to your (0)vdc supply. This resistor is used to drain
any residual current that may remain on the pin when
your switch is opened. Without this resistor in place
you may get unpredictable results. As far as the float
switch, it should work for you...It is a magnetic reed
switch and changes states "only" when you raise/lower
the float. It doesn't pulse an output....I know you said
that you have alot of programming knowledge, but are
you sure it isn't in your program?...please don't be
insulted I am only trying to help if I can...I am
giving you some basic sample code below...If you already
know this then disregard...
start:
LOW 0
IF IN8=1 Then start2 'This is input to start cycle
goto start
start2:
pause 10
IF IN9=0 Then start 'This is input from float level
HIGH 0 'This is output for a relay to run 120vac
goto start2
I hope that maybe this will help a little bit and if you already
know this then let me know. Once again I am only trying to help.
> microelectronics.
the fact that you were previously using the circuit on 120AC may be
part of the problem. Contacts in relays and switches have a minimum
current rating as well as a maximum, the minimum also referred to as
the "wetting current". Contacts rated at 120 volts have rather high
wetting currents. Even bifurcated contacts - meaning they are
optimised for low voltage and low current, need around a milliamp to
get consistent current flow. So a pulldown resistor of 5K or less
would be called for.
Also, it's good to use contacts that are "clean" in the sense that
they've never switched 120AC, especially into inductive loads.
Arcing always occurs and some pitting and carbonizing of the
contacts results. While 120 volts AC easily breaks this resistance,
5 volts DC may not.
