IR Problems
Group,
I have been trying to get Infra Red Object Detection working for one
of my robots for about a week now. I have a program written so that when
ever the IR detects something it displays "object detected" on the debug
screen. I made my IR on a practice board to start off with to see if it
works, and it works great. My problem is that now I made another one exactly
like it, but instead of using a practice board, I used a PC board, and it
does not work correctly. It will detect my hand if I wave it in front of it,
but it also displays "object detected" when there is nothing there! It is
doing that every 2 1/2 seconds exactly. Still IF I put my hand in front of
it, it will throw it off and detect it, then start back in its cycle. Make
any sense? I just don't see what I have done because this board is exactly
identical to the one that works? It is not shorting to ground, and I know
the code is correct because it works with the other board. If any body could
give me a tip on what I may be doing wrong I would sure appreciate it.
Thanks in advance. -Alex Burke
PS: I am sorry if this does not make any sense what so ever...
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
>Group,
>any sense?
It MAY if there are fluorescent lights or bright sun nearby. Shield the
receptor with a tube - enough to keep out stray light, but not too deep as
to cause too much cut-off (side-vision). Why one, and not the other -
perhaps the way the receptor is angled <shrug>.
Just needs some analysis. If this isn't it, we'll go on from here.
Bruce Bates
Thanks, but I have already though of that, and does not work. Even when
I am indoors, and all the lights are turned off it still has that same 2 1/2
sec repetition going. EVEN if I cover up the detector and the emitter
altogether (except when my hand is 5in then it detects my hand)! It has to
be something in the circuit that I can not find. It is about to drive me up
the wall! I really do appreciate you trying to help me out. I think I might
just try for a third time to rebuild it and see what happens. Thanks again.
-Alex Burke
>From: Bruce Bates <bvbates@u...>
>Reply-To: basicstamps@egroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] IR Problems
>Date: Fri, 29 Sep 2000 23:50:43 -0400
>At 9/29/2000 -0500 09:57 PM, you wrote:
> >Group,
>one
>exactly
>it,
>of
>Make
> >any sense?
>could
>Regards,
>Bruce Bates
>Bruce,
Which Stamp processor ?
>-Alex Burke
> > >Group,
> >one
> >exactly
> >it,
> >of
> >Make
> > >any sense?
> >could
> >Regards,
> >Bruce Bates
I am useing the BS2SX. -Alex Burke
>Date: Sat, 30 Sep 2000 00:15:43 -0400
>At 9/29/2000 -0500 11:05 PM, you wrote:
> >Bruce,
>when
>1/2
>to
>up
>might
>again.
> >-Alex Burke
> > > >Group,
>for
> > >one
>when
>debug
>it
> > >exactly
>and it
>of
> > >it,
>It is
>front
> > >of
> > >Make
> > > >any sense?
>as
>know
>body
> > >could
>it.
> > >Regards,
> > >Bruce Bates
What does your ir system consist of?
I ask because regular 2.5 seconds sounds very fishy; could it be
2.3?
If this is the case, you may see the stamp 2.3s glitch which
occurs in certain output states (are you using a coprocessor for
detection?).
If you used a large breadboard before, stray capacitance _may_
have masked this effect.
Have a nice evening,
Paul
> >Group,
working for one
that when
debug
if it
one exactly
and it
front of it,
there! It is
front of
cycle. Make
> >any sense?
the
deep as
other -
I know
body could
it.
> Regards,
> Bruce Bates
____
