Capacitance Meter — Parallax Forums
Capacitance Meter
edited 2000-10-01 22:23 in General Discussion
Hi there:
Does anyone have a schematic and program to build one of these items around a
BS2?
If so please let me know as I am interested in building one of these goodies.
For a display, I could make it really simple by making a pin into an output
which would then go into a D/A converter (or I can use the PWM command for that
pin) and just using a preconfigured digital display or even a needle movement
voltmeter to give me a voltage display that would correspond to the capacitance.
I am not looking for nuclear grade accuracy but I would like to see good
repeatability; that will allow me to use the program to fine tune the system and
then calibrate using a computer interface.
Thanks in advance.
Gerry Shand
gerry_shand@t...
    edited 2000-09-29 21:21
    > Hi there:
    > around a BS2?
    > goodies. For a display, I could make it really simple by making a pin into
    > an output which would then go into a D/A converter (or I can use the PWM
    > command for that pin) and just using a preconfigured digital display or
    > even a needle movement voltmeter to give me a voltage display that would
    > correspond to the capacitance. I am not looking for nuclear grade accuracy
    > but I would like to see good repeatability; that will allow me to use the
    > program to fine tune the system and then calibrate using a computer
    > interface.
    The Stamp Manual has all the info you need. The RCtime
    command can be used to do just what you're looking for. The trick
    is to make several 'ranges' (by using several pins) each with an
    appropriately-sized *precision* i.e. 1% tolerance resistor. That
    should make a handy little meter.
    Mark Hillier, VE6HVW
    President, HVW Technologies Inc.
    Canadian Distributors of Parallax Products and other Neat Stuff
    Tel: +403-730-8603 Fax: +403-730-8903
    http://www.hvwtech.com
    edited 2000-09-29 21:28
    The plans for a cap meter appear in Microcontroller Projects with Basic
    Stamps (http://www.al-williams.com/awce/sbook.htm). The interesting twist,
    if I recall, is that not only does it measure capacitance, but it outputs a
    voltage so you can read the result with the DVM.
    Remember that RCTime is proportional to the RC constant. So while you
    usually vary the R, you can just as well vary the C. Given that, a simple
    cap meter might be an RCTime statement, some math to do the calculations,
    and a debug statement.
    Al Williams
    AWC
    * Control 8 servos: http://www.al-williams.com/awce/pak8.htm
    > From: gerry_shand@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JtcDFMVP1mFg4ZgbvC4yuI9lmjTxJXevY_3cK95DIQ1EfobefB-mniAMlt3hs8u400SmtN0hEK9-OSQUYEEc]gerry_shand@t...[/url
    > Sent: Friday, September 29, 2000 3:14 PM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Capacitance Meter
    > Hi there:
    > items around a
    > BS2?
    > these goodies.
    > an output
    > command for that
    > needle movement
    > the capacitance.
    > the system and
    > Thanks in advance.
    > Gerry Shand
    > gerry_shand@t...
    edited 2000-09-30 01:00
    > Date: Fri, 29 Sep 2000 15:14:20 -0500
    Check the RCtime command and then use integrated PWM output
    or a PULSOUT after calculating C from the RCTIME using
    appropriate resistance for "R" - for wider range you could
    add a feature to switch "R"s electronically.
    Another possibility is to use a 555 RC oscillator and then
    PULSIN to derive C. And there are many more possibilities :-)
    Depends some on what values you are trying to measure.
    ________________________________________________________________
    YOU'RE PAYING TOO MUCH FOR THE INTERNET!
    Juno now offers FREE Internet Access!
    Try it today - there's no risk! For your FREE software, visit:
    http://dl.www.juno.com/get/tagj.
    edited 2000-09-30 16:49
    I have seen that stamp article also however it is designed for the stamp 1
    and not the stamp II I never could figure out the conversions,and never got
    the program to work on a stamp II
    >Regards,
    >Al Williams
    >AWC
    >> From: gerry_shand@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HJzD8tbyugBUfUQJtfviByZaDPeo9OfqVNLqvxk-2U1cpNNWJj7roIHkD4kS1jttyNwvNVdJ6TG0Tga84LU]gerry_shand@t...[/url
    >> Hi there:
    >> items around a
    >> BS2?
    >> these goodies.
    >> an output
    >> command for that
    >> needle movement
    >> the capacitance.
    >> the system and
    >> Thanks in advance.
    >> Gerry Shand
    >> gerry_shand@t...
    Sincerely
    Kerry
    Admin@M...
    WWW server hosting
    [url=Http://mntnweb.com]Http://mntnweb.com[/url]
    Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
    CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
    --So you think you need more memory... the LEM went to the moon on 16K,how
    much do you REALLY need?
    edited 2000-09-30 17:32
    Must be a different one. The one I'm talking about is on page 199 of the
    book and it uses RCTIME -- a Stamp II command (the I uses POT instead).
    The program uses Gausfit to calculate a polynomial to convert counts to uF.
    Of course, the resulting polynomial was:
    .0000008*x**3 - .0005262967*x**2 + .5838454*x + .4225229
    This takes some trickery to calculate on the Stamp (and no, I didn't use a
    PAK I or II although that certainly would be one option).
    There is probably a Stamp I version floating around somewhere else (maybe an
    old SOM project or something).
    Al Williams
    AWC
    * Control 8 servos at once! http://www.al-williams.com/awce/pak8.htm
    > From: Kerry Barlow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dhCSdiVLL2ZBS31UMPQ4sMDs__pIewD0boBHGylYKppS9p_EZ3AHV0EBOBRS6BLFxOI1zg4QfGjmTgvN]admin@m...[/url
    > Sent: Saturday, September 30, 2000 10:50 AM
    > Subject: RE: [noparse][[/noparse]basicstamps] Capacitance Meter
    > never got
    > interesting twist,
    > it outputs a
    > >Regards,
    > >Al Williams
    > >AWC
    > >> From: gerry_shand@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-aE2mUeqLVJ3ThVsBCILAOoM7xtVF-cyi0kZRX6IaND5oG_3lx-euKbdiZOa6sm72DCfDsOH7Kaw1AsX8N0]gerry_shand@t...[/url
    > >> Hi there:
    > >> items around a
    > >> BS2?
    > >> these goodies.
    > >> an output
    > >> command for that
    > >> needle movement
    > >> the capacitance.
    > to see good
    > >> the system and
    > >> Thanks in advance.
    > >> Gerry Shand
    > >> gerry_shand@t...
    > Sincerely
    > Kerry
    > Admin@M...
    > WWW server hosting
    > on 16K,how
    edited 2000-10-01 22:08
    uF.
    How come it needs gausfit? The formula is BASICally
    C=constant/R.
    Determining the constant takes o one-point calibration to account for the
    threshold of the Stamp and the tolerance of the resistor.
    Al, they had your "BASIC Stamps" book on display at the Embedded systems
    conference in San Jose CA last week, at the CMP Books booth. Good book! I
    also found an interesting new book there, "MATH Toolkit for REAL-TIME
    Programming" - Do big math on small machines. by Jack Crenshaw, a
    compilation of columns he has written for "Embedded Systems"magazine
    through the years.
    -- Tracy Allen
    http://www.emesystems.com
    "There is nothing quite so practical as a good theory" -- Williard Gibbs.
    Well, the truth of it is, I wanted to show how to do the polynomial fit. You
    can see the higher-order coefficients are very low, so ignoring them doesn't
    make much difference. In practice, stray capacitance and other effects don't
    make the fit exact, and -- as you know -- not everything has that sort of
    easy fit.
    Glad you liked the book.
    Al Williams
    AWC
    *Floating point math for the Stamp, PIC, SX, or any microcontroller at
    http://www.al-williams.com/awce/pak1.htm
