converting numbers(GP2D02)
> Subject: RE: converting numbers
> Um, how about:
> y = 225-x
Yes
> So at 225, y = 0 an at 75 it equals 150. Then you could scale it up as
> you like. Assuming it is linear, you'd use y=mx+b where m is the slope
> and b is the zero offset:
No it isn't. One experimenter said squaring the output number
made it more linear.
> y=m(255-x)+b
> Does that help?
> Um, how about:
> y = 225-x
Yes
> y=m(255-x)+b
> Does that help?
"assuming it is linear" -- I was just pointing out that once you had the
range reversed you could plug it into whatever EU computation you would use.
I should have pointed out that I know nothing about the sensor itself.
Al Williams
AWC
* Run 8 servos at once! http://www.al-williams.com/awce/pak8.htm
> From: Mike DeMetz [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wUF8vHeXSVj3rYUwRwxnrIIL70TgGGzxUW4bS6BpzNOlXP86jGfHbxD7apu81l0OfjRkeH4x1JFgUaxuqg]miked@t...[/url
> Sent: Thursday, September 28, 2000 6:46 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Re: converting numbers(GP2D02)
> > Um, how about:
> > y = 225-x
> Yes
> > y=m(255-x)+b
> > Does that help?
