BS2 Turbine (everyone who is interested)
i will keep all of you informed. But at a small price. Im going to need help
with schematics and programs for operating systems.
Anyone know where i can get temp sensors that run into the 800deg. F
range???? And i need to create a program and schematics for it.
Also, anyone know how to use the plot lite or plot pro??? I want to color
code my data and give it labels. Any clue anyone ?
In other words your scratch my back i will scratch yours.
I first purchased a small used turbine at a salvage yard. Considering i have
a 90 eagle talon that is turbine equipped i decided to buy a turbine that i
knew. So i picked on up at the salvage yard from a mitsubitshi motor. You
can get these turbines off of plymouth lasers, talons, or eclipses. For some
reason people like to wreck these cars and there are plenty of good turbines
in the yards. I paid 35 for mine. Next you have to strip it, clean it and
keep the housing for it. You need this to create an inlet so use the one
that you paid for already. It has to be turned down. I will post pics and
more information in a couple of days. I will also post equations and
formulas for developing your own motors. Bill
[noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9X_Kz8mGbuE4oNi-qmehkBmvy-CpzJePtuRi9FyT4JD4e8ih86cemoUblS3VIvdnLsM7diybuHj-]voyagermb@h...[/url wrote:
> range????
Check out www.omega.com for thermocouple wire and assemblies. They make a
variety of different configurations and temp ranges and then using an AD594
(Type J) or AD595 (Type K) chip to an A/D converter should get the data you
need. In that temp range a type J thermocouple should get very accurate
readings. Good luck!
It is a turbo charger but a turbo charger is comprised of a turbine and a
compressor and the shaft that holds them together. (Without getting
technical!!) LOL
Thanks for the advice. next question, is it small or large these
pyrometers?????? I need a pretty small sensor. The turbine is only 9 inches
long. Bill
If you cant find a Garette these are pretty close. About
6 mm difference. You have to modify any plans that you have if you have any
plans.If not then it's close enough for the price. Bill
like an interesting project.
>From: "Mr. and Mrs. Fizer" <voyagermb@h...>
>Reply-To: basicstamps@egroups.com
>To: <basicstamps@egroups.com>
>Subject: [noparse][[/noparse]basicstamps] BS2 Turbine (everyone who is interested)
>Date: Thu, 28 Sep 2000 11:30:06 -0500
>help
>have
>some
>turbines
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
Can you give me the name and adress of the wrecker.
Are these the equvalent of Garette T25 Turbos?
>help
>have
>some
>turbines
aspirated and I have turbocharged it. I built an extra injector
controller using the BS2. When I say the price you payed for the
turbo my mouth dropped. I am not from the states. Thats why I wanted the
name and address of the wrecker. I would purchase extra turbos to use as
spare parts.
>Subject: Re: [noparse][[/noparse]basicstamps] BS2 Turbine (everyone who is interested)
>Date: Thu, 28 Sep 2000 16:18:55 -0500
>Fernando,
converting a turbocharger into a stand-alone gas turbine engine.
They are:
<http://www.gas-turbines.com/hobby/nye.htm>
<http://www.cbjet.clara.co.uk/dtt/dttmk2.html>
HTH
Patrick
At 03:32 PM 9/28/00 -0500, you wrote:
>Well yes aunt Bea,
>technical!!) LOL
The links below are awsome!
>From: Patrick Murphy <pmurphy@w...>
>Date: Sat, 30 Sep 2000 10:10:12 -0500
>If I may jump in, I did a search and came up with two web sites regarding
>They are:
>HTH
>Patrick
> >Well yes aunt Bea,
>a
> >technical!!) LOL
measures between 300 - 1400 deg F. The sensors tap into the casing of the
turbo. I am sure you can read the sensor with the BSII and an ADC.
What kind of fuel do you propose to use?
l0 long.
