On the (specific) use of eprom''s...
Sorry i didn't clarify... What I wanted, was to use a stand alone EPROM,
setup so that all I have to do is set the address, and it will output the
data. Doing this at 60-100 Hz. (do you clock the address in?). So, the only
outside connected lines, would be the address lines... Is this possible???
Can you clock a ROM at 60-100 Hz??? If not, what is a typical clock speed????
Thanks to all,
Edward Kindler
Thanks to all,
Edward Kindler
