i2c and timing — Parallax Forums
i2c and timing
edited 2000-09-28 22:05 in General Discussion
hello all!
I think i have a timing problem, but am not sure. What i do is the
following, I have a i2c chip, pcf8583 from philips with 8 registers in byte
format, address of the registers are 0 to 7. All the registers are readable,
But only two at a time, and this is not according to specs of the chip.! so
if i start at address 0, I can read only address 0 and 1, if i start at
adress 2 i read only address 2 and 3, rest of the info i get is garbage. Can
this be happening because of timing difficulties?
I use the shiftin command to get my data, And the bs2 gives an acknowledge.
Any information is welcome!!
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
    edited 2000-09-25 21:45
    At 9/25/2000 +0000 02:25 PM, you wrote:
    >hello all!
    Check here:
    http://www.phanderson.com/stamp/i2c/8574.html
    Although this is a different unit, many of the principles are the same,
    including addressing, and I'd presume timing.
    Hope that helps.
    edited 2000-09-27 01:35
    Hi Pieter,
    I am also playing with a pcf8583 and am having a few small problems.
    I seem to get all other i2c chips to work (eeproms rtc's etc), but am
    having problems reading from pcf8583.
    If you were to email me your BS2 program I could have a look and see
    what's going on for you. Perhaps we'll both be able to work it out.
    You should probably send a connection diagram or pinout that your
    using between the 8583 and the bs2.
    You can send prog to simon @ dataweb.com.au (no spaces).
    Simon.
    PS. One thing I have had i2c problems before with is the resistors on
    the i2c bus. For some chips only 12k resistors will work, and on
    other chips only 10k resistors will work. Perhaps you could play
    around with those values. Anyway, i'd still appreciate a copy of the
    code.
    --- In basicstamps@egroups.com, "Pieter-Jan van Diepen"
    <diepenpj@h...> wrote:
    > hello all!
    in byte
    readable,
    chip.! so
    start at
    garbage. Can
    acknowledge.
    ___
    edited 2000-09-28 21:34
    On PCF8583 datasheet (page 22), the formula for the resistors is: R=Trise/C
    bus.
    On a french book application of this chip, a recommandation is specified to
    wire a solid aluminium condensator of 4.7µF between VDD and VSS.
    Maybe an help to solve problem ?
    C. Souche
    edited 2000-09-28 21:42
    Have also a look at recent email exchanges on this group, subject 24LC32 for
    portion of code.
    C. Souche
    I can resend the code if need be.
    MH
    To: <basicstamps@egroups.com>
    Cc: <Csouche@a...>
    Sent: Thursday, September 28, 2000 4:42 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: i2c and timing
    for
    > portion of code.
    > C. Souche
