Serial Communication during Runtime -- Multiple Stamps
Hello:
I will be using 8 BS 2 stamps, each doing relatively simple tasks
(switching on and off leds) under the control of my computer. My
intention is that the computer will communicate during runtime with
the stamps via the serial connection. I would like to connect all the
stamps to the same serial port (basically in parallel) and the send
information to all of them and have each one listen out for its own
"name". Following the name will be a code describing what it needs to
do (i.e. switch on led ). For example I might send something like:
B,5
which means Stamp No. B, switch on LED 5.
Will this work the way I hope it will? I know there was a problem
with
doing this on the BS 1, because there was the danger of shorting the
serial connection to ground, but it seems it should be okay for the
BS2 since it has separate serial pins. Also, I don't need the stamps
to communicate back to the computer. Are there any precautions I
should take, or should it all work just the way I think it will (ha!
as if it ever does....)
Thanks for any advice
B,5
with
I just wonder, if all you are doing is switching leds, perhaps
eight stamps would be overkill in terms of money and energy. If you use
any kind of serial latch, you require but one stamp. You would not have
the problem you are trying to solve.
Unless you are doing this just to figure out how; then please
disregard the latter comments...
Have nice evening,
Paul
On Wed, 20 Sep 2000, Chundle Chundle wrote:
> Hello:
> B,5
> with
If serial data exchange between multiple stamps is required, your going
to have to build a 'simple serial network' that all the stamps can attach
to. Research RS-485 for your simple net. Each stamp, once attached to the
net, will have to constantly watch all messages, filtering for messages sent
specifically to it, and then act on the message. This is a bit complex, but
well documented if you search some. Start with ( and maybe end with! It's
that good! ) Jan Axelsons' Serial Port Complete book (
http://www.lvr.com/spc.htm ). She has provided a project ( including
examples for Stamps ) to do just this. Good Luck!
Bill Mrozinski - DCS
"Paul J. Csonka" wrote:
> Good day,
> Have nice evening,
> Paul
> > Hello:
> > B,5
> > with
use.... A few questions, however:
1. what is the "inverted mode", and is this different from normal
serial communication? I was under the impression that serial
communication is generally "inverted".
2. the resistor you mention -- does this need to be in series to the
input pin, and will all 8 need the resistor or will it be enough to
put it at the serial cable connector before branching out to the 8?
If
you have a moment perhaps you could explain what exactly it's there
for!
Thanks so much for your help!
Chundle
> HI,
> YES, its possible and simple to transmit to some different BS2-IC ,
all
> connected to PCs TXD-line in "inverted mode". (Take care for the
needed
> resist 22 kOhm in BS2-IC serial input pin).To adress one of the the
> BS2-IC you should use the WAIT modifiers in SERIN-statement for
> recognicing the aligned message.
> Try this program
> recstr var byte(3)
> loop: serin 12,16468,[noparse][[/noparse]WAIT ("B"),DEC recstr]
> if recstr = 51 then LED5ON
> if recstr = 50 then LED5OFF
> if recstr = 41 then LED4ON
> if recstr = 40 then LED4OFF
> 'if recstr (any actions aligned to received recstr)
> 'if ...
> goto loop
> LED5ON: high 5 'LED 5 ON (LED + resist from pin to GND)
> goto loop
> LED5OFF: low 5 'LED 5 OFF
> goto loop
> LED4ON: high 4 'LED 4 ON
> goto loop
> LED4OFF: low 4 'LED 4 OFF
> goto loop
> '.....: actions You want
> 'goto loop
> end
> With your PC-RS232-Monitor You can switch the called pins of
BS2-IC,
> adressed with
> presetted char.
> For example, with keying "B51" + (ENTER or any nonnum.key):
> BASIC Stamp 2 , adressed with "B" , LED on pin 5 will lights on.
> Today tested,- works fine ! Klau
kzahnert@d... writes:
> Try this program
> recstr var byte(3)
> 'if ...
> goto loop
> goto loop
> goto loop
> goto loop
> goto loop
> 'goto loop
> end
You can simplify the program a bit and save a lot of typing by taking
advantage of the Stamp's method of treating its memory as an array. Like
this:
LEDs VAR Out0 ' LED outputs (index as bit)
LEDcmd VAR Byte ' serial command string
theLED VAR Nib ' selected LED
state VAR LEDcmd.Bit0 ' on if Bit0 set
Init:
DirL = %11111111 ' make them outputs
Loop:
' SERIN 12,16468,[noparse][[/noparse]WAIT ("B"),DEC LEDcmd]
' test with DEBUG terminal
DEBUG CR,"Enter an LED command: "
SERIN 16,84,[noparse][[/noparse]WAIT ("B"),DEC LEDcmd]
theLED = LEDcmd / 10
IF theLED > 7 THEN Loop
LEDs(theLED) = state
GOTO Loop
-- Jon Williams
-- Dallas, TX
>Hello:
>B,5
>with
HI,
YES, its possible and simple to transmit to some different BS2-IC , all
connected to PCs TXD-line in "inverted mode". (Take care for the needed
Try this program
recstr var byte(3)
'if ...
goto loop
goto loop
goto loop
goto loop
goto loop
'goto loop
end
With your PC-RS232-Monitor You can switch the called pins of BS2-IC,
adressed with
presetted char.
Today tested,- works fine ! Klaus Zahnert
>Fantastic! This is very similar to the program I was intending to
>If
>for!
>Chundle
>> HI,
>all
>needed
>> Try this program
>> recstr var byte(3)
>> 'if ...
>> goto loop
>> goto loop
>> goto loop
>> goto loop
>> goto loop
>> 'goto loop
>> end
>BS2-IC,
>> adressed with
>> presetted char.
HI Chundle,
the wanted answers for the two points of questions above in shortnes:
1. RS232 "inverted" mode, used in BASIC Stamps SERIN.../SEROUT
statements,also
known as "direct connection" is a solution to avoid the "normaly" used
TTL <==> RS232 level converter, like the classic MAX 232 - IC.
With RS232-specification you see
TTL HIGH <==> RS232 about -10V
TTL LOW <==> RS232 about +10V
For easy/cheapy connecting (without inserting such level converter
) two things
are to do:
1.1 invert the signal in BASIC Stamp itself
(gives the name "inverted" ) with setting the
parameter
for this, included in baudmode.
1.2 For driving a TTL -Input (clamped with inner
diodes
to about > -0.6 Volt and < 5.5Volt) you need a
simple
resist only to limit the current for clamping.
Calculate for HIGH : (10V-5.5V)/22kOhm = 0.2mA.
Because the RS232 - switching level is some
positive,
near zero, CMOS TTL-Output switches the RS232-input
with a simple wire.-
2. 2.1 With point 1.2. you see "in series",
connecting RS232 OUT to TTL IN.
2.2 It should be (!) possible to use one resist
for "some",
perhaps "all", connected BASIC Stamps, for the
used
pins all as inputs, of course.
You should calculate the current with single
resists
for each BASIC Stamp in relation to PC's RS232
inner
resist. But I think You don't use a lot of BASIC Stamps
in your little network...
Chundle, hope again this helps for you. See also to:
1. BASIC STAMP MANUAL V1.9 page 307... , 309....
2. "BASIC Stamp Second Edition" ,Kuehnel.C/Zahnert.K, ISBN 0-7506-7245-5,
year 2000
Detailed items and hints for RS232 connection PC <==> BASIC Stamp:
Chapter 7.1.1
Regards Klaus Zahnert
Thanks so much for taking the time to explain this to me. However I'm
still confused -- if the stamp (I'm using Stamp II) already has its
own dedicated serial pins (serial in being rpin 16 according to the
manual) why do I need to do any conversion, inversion or adding
resistor? In fact, I used your programme directly and just changed
the
statement to "serin 16" and it worked fine. Does what you write below
only apply to Stamp I which I understand doesn't have dedicated
serial
pins?
Thanks again so much for your patience! Also, thanks to Jon Williams
for the alternate code!
Chundle
--- In basicstamps@egroups.com, Klaus Zahnert <kzahnert@d...> wrote:
> HI Chundle,
shortnes:
> statements,also
used
IC.
converter
> ) two things
> are to do:
setting the
> parameter
inner
> diodes
you
need a
> simple
0.2mA.
some
> positive,
resist
> for "some",
for the
> used
single
> resists
PC's
RS232
> inner
0-7506-7245-5,
> year 2000
Stamp:
> Chapter 7.1.1
believe this message is directed towards the poster "Chundle Chundle"[noparse]:)[/noparse]
Paul
On Wed, 20 Sep 2000, William E. Mrozinski wrote:
> Paul,
> > Good day,
> > Have nice evening,
> > Paul
> > > Hello:
> > > B,5
> > > with
>Hello Klaus:
>the
>serial
>pins?
>Chundle
HI Chundle,
BS2-IC Pins 0...15:
Comes with CMOS-TTL-features for common use input/output.
For this you have to provide the hardware conditions (like level, direction)
to use the input/output-statements of PBASIC-language. Two of this are
SERIN.., SEROUT. You have to handle these as described in my message before.
BS2-IC rpin 16:
is a logical name (there is no "rpin16" on board). As you see from scheme,
there are the TX/RX/ATN-lines to get the dialog with PC while downloading
or debugging.But while running the program you can use TX/RX also for SERIN
16,...;
SEROUT 16, ...without any additional components. ("cable is enough") .
See to message from Jon Willims:
In his contribution he use the pin-number 16.
Take attention for baudrate 84 instead of 16468 because there are hardware
inverted signals for this (!) pin-number (with transistors on BS2-IC).
