How to detect a sound event?
Hi there,
I'm still looking for the easiest way (or to be more accurate, the one that use
the minimum of external components) to detect a sound event as a hand clap
etc... with the BS2.
I just want to know that there has been a noise. No quantity or quality
information needed.
Any ideas ?
Nicolas
information needed.
Any ideas ?
Nicolas
>Hi there,
>that use the minimum of external components) to detect a sound event as a
>hand clap etc... with the BS2.
An electret or carbon microphone will sense sound. The carbon transmitter
(as found in older phones) will produce electricity on it own. The others
types of mikes require separate power and/or amplification to be used with
a Stamp.
More than that, others will have to offer, but that's a start.
>information needed.
>Any ideas ?
>Nicolas
Thanks for your comments on my Cell (or Packet Radio)
interface, if you don't mind, could you elaborate more
on your concept. How would I get the Stamp to
physically connect to a cell phone, or were you
implying using packet radio to perform this? I guess
Packet certainly sounds easier.
About the Stamp detecting sound (clap), have you
thought about using a piezo transducer? You can vary
the threshold intensity to only allow for a clap (ie.,
it won't pick up every single sound that occurs).
Thanks for your help!
Todd
__________________________________________________
Do You Yahoo!?
Send instant messages & get email alerts with Yahoo! Messenger.
http://im.yahoo.com/
>Hi Bruce,
>on your concept.
I'm only aware of the PIC application which I once saw on a ham website.
Take a look here: [noparse][[/noparse] http://www.tapr.org/tapr/html/kitsf.html ].
The Stamp isn't capable of large scale data manipulation, although some
amazing things have been done when it's pressed to its limits. Some cell
phones have a direct data connection, and I believe it's used for fax
transmissions (not sure). I have a VERY OLD Radio Shack cell phone, which
is a LUGGABLE (NOT small), but has an adapter which fits between the
handset and the transceiver. The RS-232 port from the Model 100 could be
directly connected to this interface. The ROM BASIC of the TRS Mod 100
could then be used to transmit data over the cell phone in 1-9-8-7 !
My only point being - if it could be done then, I would suspect it still
can be.
> I guess
Not sure -
How are you planning on packetizing the data on a Stamp ? Unless it is a
very small amount, I would think you'd run out of RAM awfully quickly.
You have the additional problem of verifying the transmission, if
relaibility is of any concern. Please don't let this detract from your
efforts, however. Have at it !
That wan't my "project" - sorry. I suppose piezo + an op-amp might provide
enough voltage, but that is out of my league.
Sure
>Todd
Bruce
>Do You Yahoo!?
level. Once problem may be the speed at which the sounds occurs, it
may be missed as it would be a sharp spike.
I don't have the configuration handy, but an op-amp may be setup with
a few components as a peak-hold device. It will hold the highest
voltage and slowly bleed off allowing ample time to sense it (some
stereos show sound level peak bar-graphs the slowly go back down--
same idea).
Pick up the op-amp cookbook for that and other good op-amp circuits.
In these days of digital, we tend to forget how cheap, simple and
easy analog devices can be.
-Martin Hebel
Southern Illinois University Carbondale, Electronics Management
http://www.siu.edu/~imsasa/elm
and
SelmaWare Solutions
www.selmaware.com
--- In basicstamps@egroups.com, "Nicolas Fournel"
<Nicolas.Fournel@f...> wrote:
> Hi there,
one that use the minimum of external components) to detect a sound
event as a hand clap etc... with the BS2.
quality information needed.
> Any ideas ?
> Nicolas
