newbie asking probably the simplest question ever
On Sun, 17 Sep 2000, Eric Schettler wrote:
> The power supply is connected, and the serial cable is plugged into the
> stamp and computer. I just opened a pre-written program supplied by
> parallax. I would like to just stick that on the stamp to verify that I can
> connect to the stamp and program it. I will be writing my own programs once
> I can tell I can actually use them. What am I doing wrong? The serial
> cable is just a cable I purchased years ago for file transfer between two
> computers. Am I able to use this cable, or do I need to purchase a special
> one from parallax? So far as I can tell, I have everything hooked up
> properly. Thanks again.
> Eric
Several issues....
1- by OEM stamp 2 do you mean discrete parts ? IE,
16c57(programmed by parallax) , max232, resonator, and eeprom ( can't
remember the number ) ?
If this is the case then does it have a 5v regulator. If it does, you need
to use the 9v battery and apply it to the input of the regulator. If not,
you need to supply the stamp 5vdc.
2- The serial cable. If it is one designed to be used as a "file xfer"
cable it is probably a null modem cable with tx/rx and rts/cts rolled. You
need a straight thru cable. You can verify this with an ohm meter.
Hope this helps,
Dale Harwood [noparse][[/noparse] N4VFF ]
internet> dale@h...
ax.25> n4vff@n4vff.#cha.tn.usa.noam
#include <std_disclaimer.h>
> Eric
Several issues....
Hope this helps,
internet> dale@h...
+ to vin
- to vss
To: <basicstamps@egroups.com>
Sent: Sunday, September 17, 2000 8:53 PM
Subject: [noparse][[/noparse]basicstamps] newbie asking probably the simplest question ever
> Ok... I have tried to read the documentation on Parallax's website, but
for
> the life of me, I cannot figure out how to power up my stamp. I purchased
> an OEM stamp 2, and have two types of power supplies. One being a 4 AA
> battery holder (6 volts) and the other being a 9-volt battery connector.
> Can anyone give me any information on how I am supposed to hook this up to
> the stamp? I have the stamp connected to my own breadboard, and the
serial
> connection to my computer is build in to the OEM. All I need to know is
how
> to power the stamp so I can download a program to it! Thanks in advance!
> Eric
or the 9 v batt.
if you have a reset button use it before trying to program
Sent: Sunday, September 17, 2000 9:27 PM
Subject: RE: [noparse][[/noparse]basicstamps] newbie asking probably the simplest question ever
> Ok, thanks! I have another question now though. I am trying to send a
test
> program to the stamp, but the program says it cannot find the Stamp. I
went
> into debug mode, trying to play around and see if I could read the stamp.
> When I set the port to COM 1 (what the stamp is hooked up to), it appeared
> that the stamp was echoing everything I was typing in, and was having no
> problem with the connection. I saw both the transmission and Receiving
> lights in the debugger lighting up when I typed something in. When I set
> the connection to COM 2, I received no responce. When I typed something
in,
> I did not see the text echoing back to the screen. Can someone tell me
what
> I am probably doing wrong? I would appreciate any help sent this way!
> Eric
> From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ONs2n1i0j4QKO8Tctnhm50tdHyp2o1ptK1HJ2Fmahn0PolHAadX5SQzR-2WO3U9Qua4BFIIdFys]victorf@g...[/url
> Sent: Sunday, September 17, 2000 3:59 PM
> To: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] newbie asking probably the simplest question
> ever
> using the 9v
> + to vin
> - to vss
> From: "Eric Schettler" <schettlee@p...>
> for
purchased
to
> serial
> how
advance!
> > Eric
Eric
From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ewNVQuOXoG_upl4JF8QNDL9-yq0e2w5REhWpmiCYU6yPe3pMHLvbhklLX6CtgbDvTxZpX9e3]victorf@g...[/url
Sent: Sunday, September 17, 2000 4:31 PM
ever
you must have the power supply connected.
or the 9 v batt.
test
went
in,
what
> Eric
> ever
> using the 9v
> + to vin
> - to vss
> for
purchased
to
> serial
> how
advance!
> > Eric
what software are you using?
make sure it's for the for the stamp 2 if you have the win ver try the dos
ver see if that helps.
Sent: Sunday, September 17, 2000 7:39 PM
can
once
special
> Eric
> From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bsW1H_M1Hpg0NvmrDD1rp9YaQ-AN0-RTGu588O7noxXQda-qaxYSMqoIrjc5RI9gsfMlF21Zsg]victorf@g...[/url
> ever
> or the 9 v batt.
ever
> test
> went
stamp.
appeared
set
> in,
> what
> > Eric
> > ever
> > using the 9v
> > + to vin
> > - to vss
but
> > for
> purchased
AA
connector.
up
> to
> > serial
is
> > how
> advance!
> > > Eric
to buy a gender changer for the connection to match up with the stamp. I
have now tried both the Windows and the DOS software. (When using the DOS
software, I rebooted into DOS mode) Each time the program says it cannot
find the hardware. I have tried modifying the COM ports in my BIOS setup,
and still am unable to locate the Stamp 2 on the serial cable. I have tried
connecting the cable to both COM ports -- 1 and 2. I continue to receive
the error - hardware not found. Any other suggestions would be greatly
appreciated! It's hard to stay motivated for a project if you don't see any
forward movement. [noparse]:)[/noparse] Thanks in advance!
Eric
From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L4SOU95i59Y-aY5HyBzNnUhJoA5aY9Y8wfx9Juwm-e9uHvt--dd8PdDJ6UH6Dic-CSORY9naOyEsjA]victorf@g...[/url
Sent: Sunday, September 17, 2000 7:15 PM
ever
the cable should just be a mouse ext.
can
once
special
> Eric
> ever
> or the 9 v batt.
ever
> test
> went
stamp.
appeared
set
> in,
> what
> > Eric
> > ever
> > using the 9v
> > + to vin
> > - to vss
but
> > for
> purchased
AA
connector.
up
> to
> > serial
is
> > how
> advance!
> > > Eric
the stamp? I have the stamp connected to my own breadboard, and the serial
connection to my computer is build in to the OEM. All I need to know is how
Eric
3-3, 4-4, 5-5. You also need a short between pins 6 and 7 on the PC side so
the programmer will auto detect it (otherwise you have to manually select
the COM port).
Your file transfer cable is 2-3 3-2 etc. which will not work at all.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce/pak1.htm
> From: Eric Schettler [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8-lz9crpaKMqXN4xzT7d-fo17pyP4hPrwClLLEYyiofhEAFt1UoimS91GzqNdD-2edYwQ9PpRAl94_dcwnI]schettlee@p...[/url
> Sent: Sunday, September 17, 2000 7:50 PM
> ever
> The cable I'm using is a file transfer cable (a.k.a. serial cable). I had
> have tried
> don't see any
> Eric
> From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lVhm3Z9kGPf8KeMjndcZEQ9sDjBZadIyveWkCUgs41D_eheY5GPqd7zoR_2hiK8Gg3jZcSLsLw]victorf@g...[/url
> ever
> try the dos
> question ever
> can
> once
> between two
> special
> > Eric
> > ever
> > or the 9 v batt.
> ever
> to send a
> > test
> Stamp. I
> > went
> stamp.
> appeared
> was having no
> Receiving
> set
> typed something
> > in,
> someone tell me
> > what
> > > Eric
> simplest question
> > > ever
> > > using the 9v
> > > + to vin
> > > - to vss
> question ever
> but
> > > for
> > purchased
> AA
> connector.
> up
> > to
> > > serial
> need to know
> is
> > > how
> > advance!
> > > > Eric
program to the stamp, but the program says it cannot find the Stamp. I went
the connection to COM 2, I received no responce. When I typed something in,
I did not see the text echoing back to the screen. Can someone tell me what
Eric
From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=38mb6DsGZGV-9oWdVIBHECplVEoMAl9q_0rG6C3uHc70tzENN_Zkx56oD1owtyN4ZFBcWLE6K9Cg]victorf@g...[/url
ever
using the 9v
+ to vin
- to vss
for
serial
how
> Eric
Which Windows ??? 95, 98, 2000 ??
>Eric
>From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QScnZLk9jPQofT494_8tKN1ruBzpJMeSyDQiu66ZVcJPP3_OKapTFvmHGPXqoNWTPbgbyfT9Nw]victorf@g...[/url
>ever
>can
>once
>special
> > Eric
> > ever
> > or the 9 v batt.
>ever
> > test
> > went
>stamp.
>appeared
>set
> > in,
> > what
> > > Eric
> > > ever
> > > using the 9v
> > > + to vin
> > > - to vss
>but
> > > for
> > purchased
>AA
>connector.
>up
> > to
> > > serial
>is
> > > how
> > advance!
> > > > Eric
Parallax. It includes the PIC16c57 programmed by Parallax and the 24LC168
EEPROM from Parallax (If that 2nd number is wrong, it is because my roommate
is sleeping, and all the light I have is the light from my monitor!). It
should be just like a regular BASIC Stamp 2, except for the fact that I can
unsolder anything on this board and replace it if any individual part goes
bad. This is a nice feature, considering the fact that I don't know exactly
what I'm doing yet, and very possibly could burn something out. [noparse]:)[/noparse]
The serial cable I am using is what I believe to be a data transfer cable.
I was looking in Best Buy yesterday, and saw a cable identical to mine using
the name File Transfer cable. I suppose this means I need to get another
cable. I can do that... It's just for the fact that I go to school in a
town of about 1500, and only one computer store. I will be surprised if I
can find a serial cable here! As for the Ohm meter, it may be a while
before I get one of them, as my monitor blew up this morning, and I was
lucky enough to have an old 12 inch sitting around. I will probably be
spending my money on a new monitor first! [noparse]:)[/noparse] I REALLY appreciate all the
help. I kinda got into this robotics stuff about a month ago, and I'm
really getting pumped about it. The problem is that I don't really know
where to start. I figure I'm doing pretty good by getting the stamp. My
next goal is to get something on it. [noparse];)[/noparse] Thanks again for all the help
everyone has provided me thus far... I would still be lost as to how to
power the stamp if it were not for all of you. May all your roboting
efforts be successes! [noparse]:)[/noparse]
Eric
From: Dale Harwood [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tZBVKxRFJuG6LQoc5l5NzqLcc_DK1xdHthqy0-RFIgAZLhsyaoZjAsbM-wVLTdqVMbHc9NfsnkQ]dale@h...[/url
Sent: Sunday, September 17, 2000 11:06 AM
ever
can
once
special
> Eric
Several issues....
Hope this helps,
internet> dale@h...
using
If that store happens to be a Rat Shack, they might have a "DB9M-DB9F null
modem adapter", part #26-264. Use that between the "File transfer cable"
and the Stamp. Or get a straight-thru ("modem") cable, part #26-117 to use
instead.
Hope this helps
Vic
___________________________________________________
Victor Fraenckel - The Windman················ vfraenc1@nycap.rr.com
KC2GUI····················································· www.windsway.com
····· Home of the WindReader Electronic Theodolite
······························ Read the WIND
had to flash my bios and install some win98 patches to get the blame thing
to work. Why not try a simple pin for pin serial cable. Do you get other
devices to work on your serial port? I have had similar problems and know
for sure that they can be resolved.
Good luck,
Gary
g.shearer@v...
Free Electron Laser Research Center
Vanderbilt University
Nashville, Tennessee
tried
any
> Eric
> From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2c08nyiZ6jQKVEzgnfGxZsYpTzSI0NnvfKcJOJr6LljnSQL9_LxxL61M8AsST2ZepeFckOdlYgA]victorf@g...[/url
> ever
dos
ever
> can
> once
two
> special
> > Eric
> > ever
> > or the 9 v batt.
> ever
a
> > test
I
> > went
> stamp.
> appeared
no
Receiving
> set
something
> > in,
me
> > what
> > > Eric
question
> > > ever
> > > using the 9v
> > > + to vin
> > > - to vss
ever
> but
> > > for
> > purchased
> AA
> connector.
> up
> > to
> > > serial
know
> is
> > > how
> > advance!
> > > > Eric
of the OEM Stamp II kits to have a 50 MHz resonator insted of a 20 MHz
resonator rendering the the assembly inoperable. Parallax made a mistake in
the kitting Dept. and inadvertently included 50 MHz resonators. Check the
resonator and make sure it has a 20 on it and not 50. I had the similar
problem and Parallax is quite aware of the situation since I was the one
that notified them of the problem. If so, email them and ask for a
replacememt resonator. I had exactly the same problem on 4 out of 5 OEM
Stamp II kits I built. You will get the error message Stamp II detected but
not responding, check power supply. I am almost certain that this is your
problem. Let me know if it is so.
Good Luck,
Gary
g.shearer@v...
Sent: Sunday, September 17, 2000 11:31 PM
> By OEM stamp 2, I meant I actually purchased the OEM BASIC Stamp 2 from
roommate
can
exactly
using
> Eric
> From: Dale Harwood [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z4O0g9nycCbqVHAd0ituYH-niRlvIzO71dVQs_pYlJprhTEIG4fSPPt7GGEqv-xk8tURB1RjxOM]dale@h...[/url
> ever
> can
> once
two
> special
> > Eric
> Several issues....
> Hope this helps,
> internet> dale@h...
(Roommate is sleeping), it looks like 20.00X. I think this must be the
right one. I am having problems downloading information to the stamp
though. It sees the stamp, but now is telling me that it isn't powered. I
checked my power supply, but it appears fine. I know the stamp WAS working
for the most part, but this is a newly developed problem now. Just before
it started complaining about my power supply, I was trying to download a
complete program to it. It would never let me transfer the program if it
was complete. All it took to complete the program is the following code:
again:
goto again
If I tried to transfer that, it would have problems. HOWEVER, if I removed
the goto line, it would work fine. I could put in 50 lines of
documentation, and 6 variable declarations. It would never complain until
it found a piece of code it could actually use. I'm having tons of
problems, and I'm not liking it. This is my first stamp project. I have
great plans for the future, but for now, I just want to get an LED to light
up during a loop. I can't do that if I can't even transfer good code to the
stamp! I AM using Windows 98, and I have the latest BIOS upgrade. I know
for a fact though that this BIOS is horrible. My computer locks up
frequently, and it's all because of the motherboard video. Maybe it has a
problem with the serial ports as well. I guess I don't know about that. I
appreciate the message, as I'm still having problems. If anyone else can
throw a message my way about what I could be doing wrong, I would LOVE to
hear about it. Since I'm new to this stuff, I really have no clue. I'm
sure that if you've done ANYTHING with the stamp, you have more knowledge
than me. Thanks again for the note, and I hope to hear from you again soon
with a solution to my problem! [noparse]:)[/noparse]
Thanks!
Eric
From: G. Shearer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WO-QFei5I-nkJQB9uKO0rqSU4gVLyx6i6GHzFsF6EKp9GbB7TlJpvOgzMCUyLhCjjUJEhmEbtpPG2LfIJeUlAXg]g.shearer@v...[/url
Sent: Thursday, September 21, 2000 12:42 AM
ever
Forgot to tell you in an earlier message. Very important news. I found some
Good Luck,
Gary
g.shearer@v...
roommate
can
exactly
using
> Eric
> From: Dale Harwood [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ix6Bm8YbL-cFgyGPP_Nn5br-7PIlPcR6yHcRvNUaRyOUOPwPuBQtX7L0SFGdLs-e9MNPV7fO]dale@h...[/url
> ever
> can
> once
two
> special
> > Eric
> Several issues....
> Hope this helps,
> internet> dale@h...
function before downloading code. Otherwise it says it can not find the
stamp. Once I run the ID it locates the stamp fine.
-MH-
Sent: Thursday, September 21, 2000 1:22 AM
Subject: Re: [noparse][[/noparse]basicstamps] newbie asking probably the simplest question ever
> Are you using windows 98? There seems to be trouble with the serial ports.
I
> Good luck,
> Gary
> g.shearer@v...
ever
had
I
DOS
cannot
setup,
> tried
receive
> any
> > Eric
> > From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CAJu5ofpq0qkD7vaXheOWtuZq3XAPyB8jvo2HidL9B7a8qUXp_4Vry_N5GVPuQ74i9DUL-s]victorf@g...[/url
> > ever
> dos
> ever
the
I
> > can
programs
> > once
serial
> two
> > special
> > > Eric
question
> > > ever
> > > or the 9 v batt.
question
> > ever
send
> a
> > > test
> I
> > > went
> > stamp.
> > appeared
having
> no
> Receiving
I
> > set
> something
> > > in,
> me
> > > what
way!
> > > > Eric
> question
> > > > ever
> > > > using the 9v
> > > > + to vin
> > > > - to vss
> ever
website,
> > but
> > > > for
> > > purchased
4
> > AA
> > connector.
this
> > up
> > > to
the
> > > > serial
> know
> > is
> > > > how
> > > advance!
> > > > > Eric
download the code. Any clues?
From: Michael Hendricks [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iv-g2u7qNiS_UVcHxtIoUXLYtzX-xC0B8ev4k8SxPhP9o4cNgiDTNMi8m1O2XY0OVGCWQrsqx04s6g]mjh80@b...[/url
Sent: Thursday, September 21, 2000 1:15 AM
ever
I have noticed using the windows version often I have use hit the "ID"
-MH-
I
> Good luck,
> Gary
> g.shearer@v...
ever
had
I
DOS
cannot
setup,
> tried
receive
> any
> > Eric
> > From: victor faria [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hfu-QA7J_ZlIkgKgxW0zXlOHlSgg5jRnw8KwTWq1L03lFCCT0FGoN9ds55AHuFGRqDsUXSLIuA]victorf@g...[/url
> > ever
> dos
> ever
the
I
> > can
programs
> > once
serial
> two
> > special
> > > Eric
question
> > > ever
> > > or the 9 v batt.
question
> > ever
send
> a
> > > test
> I
> > > went
> > stamp.
> > appeared
having
> no
> Receiving
I
> > set
> something
> > > in,
> me
> > > what
way!
> > > > Eric
> question
> > > > ever
> > > > using the 9v
> > > > + to vin
> > > > - to vss
> ever
website,
> > but
> > > > for
> > > purchased
4
> > AA
> > connector.
this
> > up
> > > to
the
> > > > serial
> know
> > is
> > > > how
> > > advance!
> > > > > Eric
