Help please - Problem reading Serial pulses with clock pulses
I wonder if anyone could offer any advice with a problem I am having using a
BS2 to read data from a thermometer, please?
The thermometer device measures the temperature every 10 Seconds and outputs
the data as serial data as 13 pulses on two pins as follows:
Thermometer Pin 9 (Data out):
16 mSeconds
_____________________________________________________
| D01 |D02|D03|D04|D05|D06|D07|D08|D09|D10|D11|D12|D13|
_____|_____|___|___|___|___|___|___|___|___|___|___|___|___|______
Thermometer Pin 10 (Clock Pulses Out):
____ _ _ _ _ _ _ _ _ _ _ _ _
_____| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |________
|1mS |
With the exception of the first clock pulse (which has a duration of 1mSec),
the clock pulses occur 0.125 mSec after the start of the data pulse and last
for 0.125 mSec.
The data bits have the following significance:
D01 - Degrees Celcius Polarity
D02 - 80
D03 - 40
D04 - 20
D05 - 10
D06 - 8
D07 - 4
D08 - 2
D09 - 1
D10 - 0.8
D11 - 0.4
D12 - 0.2
D13 - 0.1
I originally planned to read the data using Shiftin, but I have not been
able to get this to work and I believe the problem is due to the device
generating it's own clock pulses and not accepting clock pulses from the BS2
while the BS2 expects to be generating the clock pulses.
Does anyone have an idea as to how I can use the BS2 to read this data?
A secondary question is whether the BS2 could read the data electrically
inverted (i.e. 0=5V and 1=0V)? I am currently adding inverter circuitry but
would like to eliminate this circuitry if it can be done in software.
I would greatly appreciate any assistance.
Thank you
Regards
Richard Norman
16 mSeconds
|1mS |
for 0.125 mSec.
D02 - 80
D03 - 40
D04 - 20
D05 - 10
D06 - 8
D07 - 4
D08 - 2
D09 - 1
D10 - 0.8
D11 - 0.4
D12 - 0.2
D13 - 0.1
Thank you
Regards
Richard Norman
The clock for the Stamp's shiftin command must come from the stamp itself,
not from the external device. The only way to get the stamp to receive this
data would be by means of a program loop, and the stamp2 is simply too slow
to react to 125 microsecond clock pulses. It is just on the borderline for
the data stream as a whole. It looks like each data bit sticks around for
over 1.2 milliseconds. The Stamp2sx is faster, and could, I think, keep up
with the data in a program loop. The polarity at the input would not
matter.
An alternative would be an external shift register, set up so that the
thermometer clocks its own data in, and then after that the stamp clocks in
the data with shiftin at its own speed.
I'm curious, what thermometer is this? There are several digital
thermometers available that are more stamp-friendly.
-- Tracy Allen
Electronically Monitored Ecosystems
http://www.emesystems.com
---original message--->
outputs
16 mSeconds
|1mS |
1mSec),
last
for 0.125 mSec.
D02 - 80
D03 - 40
D04 - 20
D05 - 10
D06 - 8
D07 - 4
D08 - 2
D09 - 1
D10 - 0.8
D11 - 0.4
D12 - 0.2
D13 - 0.1
BS2
It looks like the shift register is the way I should go and I will probably
pursue this option - do you have any recommendations about which devices
would be best for this - bearing in mind the 13 bits it will need to store
and the speed?
In answer to your question, the device I am using is supplied by Maplin in
the UK as part (Maplin code) number FE33L - you can find the device on their
site at www.maplin.co.uk. It has the following information printed on it
'MB-TMB880CF-1 and 016-808440-111.
The feature I find most attractive about this device is that it has a LCD
dsiplay but it also has minimum and maximum temperature alarms etc. so it
should be very useful if I can just interface it to the stamp.
Thanks again!
Regards
Richard
To: <basicstamps@egroups.com>
Sent: Saturday, September 16, 2000 10:07 PM
Subject: [noparse][[/noparse]basicstamps] Help please - Problem reading Serial pulses with
clock pulses
> Hi Richard,
this
slow
for
up
> matter.
in
> -- Tracy Allen
> outputs
16 mSeconds
> |1mS |
> 1mSec),
> last
> for 0.125 mSec.
> D02 - 80
> D03 - 40
> D04 - 20
> D05 - 10
> D06 - 8
> D07 - 4
> D08 - 2
> D09 - 1
> D10 - 0.8
> D11 - 0.4
> D12 - 0.2
> D13 - 0.1
> BS2
but
probably
store
> and the speed?
Hi Richard,
Since don't need parallel in or out, a straight through shift register like
the CD4006 could do the trick. It has up to 18 stages, and I think it can
be configured for 13 stages.
http://www.ti.com/sc/docs/products/logic/cd4006b.html
I'm not sure if the part is still in production. It is clocked on the
falling edge. The circuit would also need to allow clocking from both the
outside source and from the stamp in turn, using a gate or some MML (Micky
Mouse Logic).
You could also use something like the 74HC595, but since it has 8 stages
you would need to cascade two of them to get your 13 bits.
The most elegant solution would be an 8-PIN PIC, programmed as a shift
register.
regards,
-- Tracy Allen
