macintosh serial port connections
hello all:
i would like to use my BS2 connected to my mac for communication
during runtime (i.e. not for programming -- i've read the pdf at the
parallax site, etc. about using virtual pc).
however, i can't seem to find the pin diagram for the mac's serial
port and for diagrams i find that *might* be right, i'm not sure
whether DTR would be connected to ATR or would it be DCD, etc. etc.
so, i'm sure someone must have figured this and i would be ever so
grateful if someone could fill in the blanks for me:
mac mini-din female pin number to basic stamps pin
? sout
? sin
? atn
? gnd
also, on the pc diagram provided by parallax, pins 6 and 7 (DSR and
RTS) are connected. is this necessary for the mac?
thanks so much for any light you can shed on this matter.....
chund
? sout
? sin
? atn
? gnd
chund
However here is some info from (http://csgrad.cs.vt.edu/~tjohnson/pinouts/):
mac serial port:
(printer end)
Connector: mini-circular-square-din-type connector
U
8 7 6
5 4 3
2 1
1 handshake out (DTR?)
2 handshake in (RTS?)
3 TD-
4 GND
5 RD-
6 TD+
7 GPinput (NC on Mac plus and earlier)
8 RD+
This is an RS-422 interface not RS-232, hence the paired IO pins (+ and -).
To connect to an RS-232 device: attach the - pins to the RS-232 data
pins, and RD+ to ground. The handshake in and out are the hardware flow
control, GPinput is carrier detect.
So you'd need a converter.
Here is another pinout from
(http://www.hut.fi/Misc/Electronics/docs/lan/mac_serial.html)
Macintosh (DTE) Modem (DCE)
DIN-8 DB-25
Pin Signal Signal Pin
3 TxD-
TxD 2
4 GND ----+
GND 7
8 RxD+ ----'
5 RxD-
RxD 3
6 TxD+ (nc)
\ 1 HSKo Output Handshake
/ ### \ (Zilog 8530 DTR pin)
/ \ 2 HSKi/CLK Input Handshake *OR*
/ [noparse][[/noparse]|] [noparse][[/noparse]|] [noparse][[/noparse]|] \ External Clock
/ 8 7 6 \ 3 TxD- Transmit data (-)
| | 4 Ground Signal ground
| 5 4 3 | 5 RxD- Receive data (-)
| | 6 TxD+ Transmit data (+)
\###| 2 1 |###/ 7 N/C (no connection)
\| |/ 8 RxD+ Receive data (+)
However, I have also heard this:
The serial ports use the EIA422 standard which is a 'differential' system
using 5 volt outputs. It is possible for the Mac to accept 'single ended'
RS232 data (on pin 5) by grounding pin 8 at the Mac end. You can usually
send 5 volt data (from pin 3 on the Mac) to a RS232 input but the noise
immunity will be reduced.
That corresponds with the pinout above.
So to summarize, ground pin 8, RX on pin 5 and transmit on pin 3.
Hope that helps.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
you want.
> ? sout
> ? sin
> ? atn
> ? gnd
> Subject:
> Disclaimer: I know nothing (and I mean nothing) about the Mac.
> and -). To connect to an RS-232 device: attach the - pins to the
> RS-232 data pins, and RD+ to ground. The handshake in and out are the
> hardware flow control, GPinput is carrier detect.
They use the National DS8925(as does some of the Kodak digital
cameras) which is a TIA/EIA RS422 driver/receiver chip that runs +
and - 5V differental signal. The RX has a range of +8 to -8V
