BSII-SX and SMPTE time code
Hello all,
This is my first post to the list, so bear with me. [noparse]:)[/noparse]
I'm trying to figure out a way to make a BSII-SX generate SMPTE time
code. From what I can figure out (without having the SMPTE time code
documentation), it is a modulated 1200 Hz audio signal... I dont see any
reason why a BSII couldn't produce such a signal, or at least control the
modulation of an externally generated 1200 Hz signal.
Has anyone ever made a BSII generate or read SMPTE time code before?
I'm sort of curious as to whether it's been done or not...
Thanks in advance,
Brad Stockdale - brad@g...
Thanks in advance,
> Hello all,
> Thanks in advance,
Shouldn't be too hard to make a timecode _generator_.
I've been thinking of doing the same thing.
You should find out a bit more about the coding of the signal though.
It is a bi-phase mark pulse train with a polarity inversion at every bit
transition, and a polarity inversion in the centre of the bit that
repesents a one.
There are many examples and referances available on the web.
Reading is a different matter though, I suspect that the Stamp is too
slow to do the job without some external help, particularly at spooling
speeds.
Cheers!
Alan.
