Wav Files...
Hi all of you!!
I'm interested in that project
First of all, how the @#$@ can we download the wav file to the stamp
byte by byte. Which methods exists for this purpose. (how can I dissasemble
the file)
One method is downloading the file via VBasic but I don't know yet
how to grab files and transmit them, maybe a few more weeks and I'll know
how to do this!!
Does anybody have a better idea??
Carlos...
the file)
how to do this!!
Carlos...
probably need to use some memory chip attached, or a flash/regular eeprom
perhaps (32k would be small, but good enough). As far as downloading is
concerned, it's really the same principal as serial communication via the
stamp. Serin, serout commands. If you're referring to a checksum check type
of download protocol (which I believe isn't necessary due to the nature of
the download (.wav), you can always right your own checksum procedure which
would involve set packets size being transmitted, with start & stop flags, a
couple byte header for it's parity or checksum number.
- Elie
> From: Carlos F. Rodriguez M. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0C3Vf649Ltty1ZT_C_MtZFQUqyGtvcjeYYma2wfnJ6ePDrjeRltXGQjsjHU6eKD5-5lX3eL_zIaaIA]ssjg2@y...[/url
> Sent: Tuesday, September 12, 2000 12:41 PM
> To: Basicstamps
> Subject: [noparse][[/noparse]basicstamps] Wav Files...
> Hi all of you!!
> dissasemble the file)
> how to do this!!
> Carlos...
COOLEDIT to convert it to a 6KHz, 8-bit, mono ASCII text data file. From there
it would need to be processed with the Stamp.
"Carlos F. Rodriguez M." wrote:
> Hi all of you!!
> the file)
> how to do this!!
> Carlos...
> winmail.dat Type: application/ms-tnef
> Encoding: base64
You need to remove the header of the .WAV file as well as the end (programs like
Sound Forge like to add a lot of comments, copyright info etc... at the end).
You just need the raw data: obviously you will know the sampling rate of the
file you will use so we can forget about that also.
So the easiest way is to open your .WAV in an audio shareware program such as
Cool Edit and save it in 8-bit raw format. You will have just the data. But to
store this data you will need an extra memory chip, even if you are using low
sampling rate, because the memory of the Basic Stamp is really too small for
that.
Nicolas
>>> Michael Picco <mpicco@j...> 09/12/00 10:02AM >>>
Some of the information I've seen involves taking the WAV file and using
> Hi all of you!!
> the file)
> how to do this!!
> Carlos...
> Encoding: base64
Would be so much easier to use a sound-storage chip from ISD, you can record
a lot of different messages and then control de playback via serial link
from the Stamp.
The IC is made just for this. Considering time and development costs, unless
you're retired or have plenty of, warrants use of such devices, rather that
to play raw audio data from the Stamp.
All the best,
Mensaje original
De: Nicolas Fournel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=N24ZHuCHLq5QPmRNzHbouk48lfyYWORvj_mpyDi85FwRWAxaO3XNocJaW5c9cs2H4-9MPHdfa847pJ_XvfT4kzU5PhQ8]Nicolas.Fournel@f...[/url
Enviado el: martes, 12 de septiembre de 2000 20:10
Para: basicstamps@egroups.com
Asunto: Re: [noparse][[/noparse]basicstamps] Wav Files...
like Sound Forge like to add a lot of comments, copyright info etc... at the
end). You just need the raw data: obviously you will know the sampling rate
of the file you will use so we can forget about that also.
as Cool Edit and save it in 8-bit raw format. You will have just the data.
But to store this data you will need an extra memory chip, even if you are
using low sampling rate, because the memory of the Basic Stamp is really too
small for that.
Nicolas
there
> Hi all of you!!
stamp
dissasemble
> the file)
> how to do this!!
> Carlos...
> Encoding: base64
You are right. For a 5 minute song as a .WAV file you will need a lot of memory.
Of course it always depends on the resolution (8-bit or 16-bit), the sampling
rate, and the number of channels (mono or stereo).
Example, for a 5 minutes song in 8-bit mono, at 22050 Hz:
you need 5*60*22050 bytes, about 6.3 Mb
Nicolas
>>> "Chee Sze Keat" <szekeat@h...> 09/13/00 06:54AM >>>
Hello Mr Nicolas
Thanks for your reply on MP3.
I would like to ask anwother question.
Normally, the size of a .WAV file is big,
is it possible to store those data in eeprom?
I think the eeprom must be a least 2,3Mb to keep
a .WAV(let's say a 4 to 5 minutes song).
Please correct me if I am wrong.
Thank you.
sze keat
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
You are totally right. However it seems better suited to record small vocal
notes.
From what I read on their FAQ, it seems its a liitle bit difficult to avoid plop
and clicks in the recordings.
By the way, are you familiar with these chips?
Because it seems to me that it's not possible to send data in the ISD without
recording live with the microphone (at least with the low-cost chips). So you
can't have exactly the same data in 2 chips. Is that correct ?
Nicolas
>>> "Miguel Puchol" <mpuchol@w...> 09/13/00 02:23AM >>>
from the Stamp.
All the best,
Mensaje original
De: Nicolas Fournel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=P5DN0T0cdA1e_llVqqu1dNVAofRoIFNUDlnLAf7UGluPQjbzt_xS2LUk0LBz7ZH1Dj_ZALOcOP2jBZCSuKIbLF8E2A]Nicolas.Fournel@f...[/url
small for that.
Nicolas
there
> Hi all of you!!
stamp
dissasemble
> the file)
> how to do this!!
> Carlos...
> Encoding: base64
Thank you.
sze keat
Thank you.
sze keat
I see.Thank you.It means if we can build a
player, the flash memory won't allows us to
cost our "hand-made"player cheaper than any other
MD player or walkman or CD player.
Thank you.
sze keat
>From: "Nicolas Fournel" <Nicolas.Fournel@f...>
>To: <basicstamps@egroups.com>, <szekeat@h...>
>Subject: Re: [noparse][[/noparse]basicstamps] Wav Files...
>Date: Wed, 13 Sep 2000 12:19:35 -0700
>Hi,
memory.
sampling rate, and the number of channels (mono or stereo).
>Nicolas
> from the Stamp.
Would you happen to have a URL for 'ISD' ??? I'm interested in
putting the vocabulary of R2D2 on my robot. Figured about 16 memories
each playing about 1-5 seconds would be enough to do the job :-)
> All the best,
> Mike
--- Jay
| Jay Nugent jjn@n... |____|
| Nugent Telecommunications www.nuge.com |
| Web-Pegasus www.webpegasus.com |
| ISP Monitoring www.ispmonitor.net |
| LinuxNIC, Inc. www.linuxnic.net |
| (734)971-1076 (734)971-4529 /Fax |
| (734)649-0850/cell |
| ISP & Modem Performance Monitoring Svcs. |
| Discount Reseller of 123.Net ISP Services|
| Internet Consulting / Linux SysAdmin |
| Web Hosting / DNS Hosting / Shell Accts. |
| Embedded Controllers / Engr. & Design |
| Registrar of the .linux TLD |
\_________________________________________\__/
8:00am up 126 days, 14:13, 7 users, load average: 0.04, 0.04, 0.00
Date: Thu, 14 Sep 2000 08:36:02 -0400 (EDT)
Look at www.quadravox.com - they make a chip that makes addressing
and storing files on the ISD chips much easier... they sell their
chip with an ISD chip if you want - up to 2 minutes play time....
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
