Direct exe control of stamp>...
Archiver
Since your PC running program can access the COM port where Stamp is
connected and send a control command that can be recognized by the
stamp, this is straightforward.
ACJacques
Patel wrote:
> HI There all of you..
> I Have a question can any one help me out??
> Can I make a Basic Stamp 1 get connected directly to the computer and
> when i run an exe file or a VB file it will swith on a relay in the
> stamp and another file will switch it off,
> for eg relay1on.exe ---- will switch on the relay on the basic
> stamp 1
> relay1off.exe ---- will swith off the relay on the basic
> stamp 1
> as I'm new here Hope someone will help me out in the program and
> design of a simple circuit like that ,
> any one has any idea of speech control and the Basic Stamp???
> G.I.Patel
ACJacques
> stamp 1
> stamp 1
> G.I.Patel
technique with an SX-28 to control 8 relays. I wrote a client program which
runs on my PC that will send a single byte via the specified COM port. The
SX receives the byte and outputs it to RB which is ultimately connected to 8
relays. Each relay corresponds to a single bit in the byte sent. Using the
Windows scheduler, I scheduled several executions of this program at key
times and that now makes up my lawn sprinkler timer! <g>
If anyone is interested, email me off list, and I'll send you the program.
-- Mitch
To: <basicstamps@egroups.com>
Sent: Thursday, September 07, 2000 11:55 PM
Subject: Re: [noparse][[/noparse]basicstamps] Direct exe control of stamp>...
> ACJacques
> > stamp 1
> > stamp 1
> > G.I.Patel
Can I make a Basic Stamp 1 get connected directly to the computer and when i run an exe file or a VB file it will swith on a relay in the stamp and another file will switch it off,
··· for eg relay1on.exe ---- will switch on the relay on the basic stamp 1
·············relay1off.exe ---- will swith off the relay on the basic stamp 1··
as I'm new here·Hope someone will help me out in the program and design of a simple·circuit like that·,
any one·has any idea of speech control and the Basic Stamp???
G.I.Patel
