MC14553 counter problem
It is likely that you are experiencing a voltage surge when
connecting and or disconnecting your supply. Try adding a resistor
in series with your power supply and a decoupling cap across the IC's
power and ground. Try 10 - 100 ohms. BCS
--- In basicstamps@egroups.com, "Mohamed REFKY" <refky@h...> wrote:
> Hello,
> I have built a counter circuit using MC14553 (3-digit BCD counter)
with 9v
> NI-CD rechargeable battery to retain count in the event of power
failure.The
> problem is that some times the counter is reset with disconnecting
> reconnecting the main power.Any help would be appreciated.
> Thank You
> Mohamed Refky
______________________________________________________________________
___
> Get Your Private, Free E-mail from MSN Hotmail at
http://www.hotmail.com.
> Share information about yourself, create your own public profile at
> http://profiles.msn.com.
> Hello,
with 9v
failure.The
> Thank You
> Mohamed Refky
___
I have built a counter circuit using MC14553 (3-digit BCD counter) with 9v
NI-CD rechargeable battery to retain count in the event of power failure.The
problem is that some times the counter is reset with disconnecting or
Thank You
Mohamed Refky
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
