Optical Switch
I ordered an optical switch from all electronics (www.allelectronic.com)
catalog number: OSU-35
I thought it would come with some sort of data sheet but it didn't. Since
I'm new to electronics, I have no idea how to hook it up. I have attached a
drawing of the part. It is U shaped and at the top of eash side it has a
scematic symbol. I'm still learning how to read scematics, so I'm not
exactly sure what they are or how to hook them up. One of them is an LED
(I'm pretty sure) and I know how to hook that to a stamp. But the other one
I'm not sure of. If someone could tell me how to hook this up, I would
greatly appreciate it. And it would be helpful if someone could give me a
code example. I don't know if this will cause a pin to be high/low and I
should check it that way. Or if it is an RC circuit and I have to use
RCtime.
I hope this works the way I'm thinking. Here is what I think will happen:
I turn on the LED side to activate the switch. When something passes
between the two posts it will activate the other side. Sort of a small
compact "electric eye" Is this correct?
Thanks in advance,
Shawn
PS I should mention that I'm using a Basic Stamp II.
RCtime.
Thanks in advance,
Shawn
To hook the
device up to a stamp:
1) Attach the emitter (leg with the arrowhead) to ground.
2) Attach a pullup resistor (about 10K ohms) between the collector (the
other leg) and +5V.
3) Also attach the collector to a stamp pin.
4) Drive the LED through a resistor from +5V or a stamp pin.
When there is nothing blocking the light path from the LED to the
phototransistor, the transistor will be turned on causing its collector to
be pulled to ground, i.e. a low input to the stamp. When you block the
light path the transistor will turn off causing the collector and the stamp
pin to be pulled to +5V.
As far as code is concerned think of this as you would any other switch.
Hope this helps,
Bob Baxter
>RCtime.
>Thanks in advance,
>Shawn
>Attachment Converted: "c:\eudora\attach\OpticalSwitch.jpg"
