printer problem
Hello,
I am using version 1.096 of the bs editor with W95 and an
HP882C printer.
When I try to print from the editor window, the printer
goes through the motions but nothing is printed. I just
end up with a blank piece of paper.
I can print to other 'printers' from the bs editor (fax
program, for example) with no problems.
What am I missing here? Has anyone else run into this
problem?
Adolph Stumpf
astumpf@u...
HP882C printer.
problem?
Adolph Stumpf
astumpf@u...
Does your printer work with other programs ?
Phil.
To: <basicstamps@egroups.com>
Sent: Thursday, August 31, 2000 7:32 PM
Subject: [noparse][[/noparse]basicstamps] printer problem
> Hello,
> HP882C printer.
> problem?
> Adolph Stumpf
> astumpf@u...
The printer works perfectly with all other programs.
I contacted HP tech support and the answer was "If the
stamp editor is the only program that causes a problem then
the stamp editor is the problem".
I appears that there is some incompatibility between the
stamp editor and the HP882C printer.
As I mentioned, there's a way to get around it but I'd like
to find out why I have such a strange problem.
Adolph
--- In basicstamps@egroups.com, "Philippe Derenne" <derennep@s...>
wrote:
> Hi,
> Phil.
> From: Adolph Stumpf <astumpf@u...>
> > Hello,
> > HP882C printer.
> > problem?
> > Adolph Stumpf
> > astumpf@u...
I use the 1.091 beta version of the Stamp editor, and I don't have any
problem to print on a HP 880C.
It seems strange to me that only the Stamp editor is causing trouble,
because the editor is printing thru the windows driver, which is working
fine with other programs...
When I got this problem, I first look at the ink cartridge, but if it's OK
with other software, I don't have any answer for the moment...
Maybe you may try to force the printer to print grayscale, just to be sure.
I've noticed that sometimes the printout color is a kind of dark blue, not
really black.
I'll let you know if I got more information.
Best regards,
Phil.
Sent: Sunday, September 03, 2000 6:17 PM
Subject: [noparse][[/noparse]basicstamps] Re: printer problem
> Phil,
> Adolph
> wrote:
> > Hi,
> > Phil.
> > > Hello,
> > > HP882C printer.
> > > problem?
> > > Adolph Stumpf
> > > astumpf@u...
Open your programs with notepad and then print them.
David
Sent: Sunday, September 03, 2000 5:26 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: printer problem
> Hi Adolph,
sure.
> really black.
> Best regards,
> Phil.
> > Phil,
> > Adolph
> > wrote:
> > > Hi,
> > > Phil.
> > > > Hello,
> > > > HP882C printer.
> > > > problem?
> > > > Adolph Stumpf
> > > > astumpf@u...
The print problem has been solved!
After some experimenting and headscratching I came to the
conclusion that the font color setting in the stamp editor
must be black in order to print.
I used yellow text on a blue background and for some strange
reason the HP882 didn't like what it was getting from the
stamp editor.
I'm back to black text on white background and everything's ok.
Adolph Stumpf
