robot navigation around clutter
Hi all: I have some questions on making a robot avoid clutter in its
navigation.I want to stay with Stamp based systems,even if I need 2 or 3 for
seperate tasks.I use servos for drive wheels with no feedback right now.
Currently I have my small robot set up with 3 IR sensors fwd,left,right
detection.
These work fine on walls and chairs. It also has 2 bumper sensors,left,right
for thin objects such as 4 leg chairs. Currently the robot can drive around
a room and stays out of trouble,but the problem is,when it gets itself under
a 4 leg chair,(clutter) it will bounce around for 10 minutes until it works
a path back out. In the open areas of a room,it just drives straight across
the open area,until it hits a wall,or clutter on the opposite
side.Ultimately the robot should stay in the open areas.
How would I go about making the robot stay out of those clutterd areas?
chair legs,tables,book piles,whatever?
A high resolution vision system would do it, but I can imagine the difficult
programming and expense.
I thought of dead reckoning such as Submarines,and aircraft use,with
inertial guidance, but,that requires high accuracy in drivetrain,no slippage
on rug,tile etc etc etc
I thought of an onboard compass and mapping its terrain into data tables,but
then again the robot needs to have 100% accurate positioning.
An onboard referance system to some known source in an X-Y format may work
with guidance beams.
I thought of a sharp sensor on board, and everytime it sees an object ahead
it sets a flag in a database table the robot builds up,however repeatable
accuracy worries me again.
What does everyone think? Any ideas are appreciated.
Sincerely
Kerry
Admin@M...
WWW server hosting
[url=Http://mntnweb.com]Http://mntnweb.com[/url]
Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
detection.
Sincerely
Kerry
Admin@M...
WWW server hosting
>for seperate tasks.I use servos for drive wheels with no feedback right now.
>detection.
Hi Kerry -
At what degree angles from the center point of the platform ?
>sensors,left,right for thin objects such as 4 leg chairs. Currently the
>robot can drive around a room and stays out of trouble,but the problem
>is,when it gets itself under a 4 leg chair,(clutter) it will bounce around
>for 10 minutes until it works a path back out.
The simplest answer at this juncture is - add a rear-facing sensor.
Add a "set of rules" -
rem WatchOut Subroutine
(pls forgive the on-the-fly spaghetti code, NOT complete !)
If I am about to go in reverse then 100 ' What have we done ?
Goto 200 ' Branch if we had gone FWD
Rem drop through We HAD BEEN in Reverse
100 Dir=rear : Gosub Scan_Directionally ' Generalized Scanner
' Front or rear
If Rear_scan > 0 then 300 ' Hit w/i distance ?
Dir=Clear ' Call to scanner w/ no direction is an ERROR
' Used for debugging
200 If Last_Dir = forward then 400
Move -1 * mm distance ' a short distance < =
scnr_range ' greatest dist you can
scan with Ir
Goto End_This_Decision
300 Dir=rear : Gosub Scan_Directionally
Rear_scan < Max_Move then WatchOut ' Check before traveling
WatchOut:
rem Potential for lock-up - BE CAREFUL and take precautions
reversals = 1
End_This_Decision:
rem mm is positive for fwd and neg for reverse
IF mm > 0 them Move_Fwd
IF mm < 0 them Move_BKWD
rem provision for a third case if necessary
rem If mm = 0 perhaps for initial state prior to collisions or
decisions
Move_Bkwd:
If Last_DIR = Fwd then 400
Reversals = Reversals + 1
400 Reversals = Reversals - 1
mm = mm * -1
Dir = REV
Gosub Move
Move_Fwd:
If Last_DIR = Rev then 500
500 Reversals = Reversals - 1
Dir=FWD
Gosub Move
Goto Check_For_Danger
rem Independent Routine - placed here only for convenience
Move:
blah, blah, blah
motivate using Dir (as set) and mm (distance)
Save_BUMP = BUMP_Indicator ' Prolly will be needed
Return
Check_for_Danger:
If Reversals > Max_Jerky_Moves then Stop_this_Nonsense
Goto Exit_Rtn:
Stop_This_Nonsense:
rem Do something about it
Exit_Rtn:
Rem End of this routine
If you intend to randomly rove (no charted course or past history to guide
you), then the matter becomes "how do I get OUT of a cluttered area IF I
get there" [noparse][[/noparse]see above for "WatchOut" ]. If you have a charted course, and
know in advance where your goal is - avoid any and all obstacles within an
xx degree arc from your last way point. A waypoint might be equated to a
navigational "bookmark". Personally, I had even considered mounting an
Irods on a servo - which I believe I saw implemented a few weeks ago, but
didn't keep the URL (sorry). So, by keeping a clear field ahead, you avoid
the problem.
The "charted course" and/or "past histpry" imply saving information. This
could be done in (1) EEPROM or (2) Flash; intenal (1) or eternal (1,2), as
may be required.
A mere grand or so <yikes>.
That's still your best bet - at least in the initial phases of implementation.
Build small - GR-OOO-WWWWW B-I-G <smile>.
>tables,but then again the robot needs to have 100% accurate positioning.
With a hobby robot and a limited budget, I would posit that 100% of
anything woiuld be darned near impossible. Other than IC chips (which are
generally cheap by comparision) accuracy and high resolution, generally
carry a hefty price tag. Just my experience - YMMV. The exception may be
high precision DC motors and high-rez steppers, to a limited degree.
That was my thought too. It becomes quite complex though - inre
communicating the info as req'd and on demand. Broadcast systems are
possible with a set and time spaced reporting cadence/sequence.
>ahead it sets a flag in a database table the robot builds up,however
>repeatable accuracy worries me again.
Saving all that data should concern you too. What of "sorting/arranging" it
also, a the write_time delays which STOP all processes DEAD !! That I had
considered as an off-board process for a PIC EEPROM manager. The PIC would
wait ONLY on the NEXT WRITE; thus achieving overlap with other processing.
The Stamp can not achive true overlapped processing, as it does
one-thing-at-a-time.
Stamp: a -> wait b -> wait c-> what d -> wait -> end
a \
PIC check c - ok - b > wait a -> check b -> wait a - > end
| c /
_ready
wait c
You've got'em - good luck
>Sincerely
>Kerry
>Admin@M...
>WWW server hosting
Bruce
