DC Motor control — Parallax Forums
DC Motor control
edited 2004-03-03 02:10 in General Discussion
Hello,
I just found basicstamps - absolute newbie.
we are searching for a DC motor control to set the position of a
linear screw drive.
Has anybody done/tried this with BASIC Stamps ?
Our screw so far is driven by a Maxon DC Motor RE35 90W (12V) and a
HP HEDS 5540 Digital Encoder. A 0.52 volt output / 1000rpm DC tacho
is available too.
At least we want to control the bidirectional position not the speed.
The periodic movement of the
screw is a sinus over 0..50 cm. Motor needs average 200 rounds per
second.
We are connecting to a IBM compatible PC with RS232 and Visual Basic
program running,
so we need a speedy controller in between.
Thank you
Dirk
    edited 2000-09-01 06:37
    Dirk,
    I am using such a device to control a waveguide attenuator. The attenuator
    has a slug that is pushed in and out of the waveguide with a linear
    ball-screw positioner which is driven by a 12 volt motor. On the end of the
    shaft, I have a 10 turn potentiometer which is read by the control computer.
    Cheaper than the encoder method and easier to program as well with a stamp.
    We even do hysteresis to eliminate the backlash and play of the ball screw.
    Will maximum travel be reached within 10 rotations of the screw? If you need
    more rotations, then the encoder method would be the only way. If you want
    more info or ideas, please email back.
    Good luck,
    Gary
    g.shearer@v...
    Free Electron Laser Research Center
    Vanderbilt University
    Nashville, Tennessee
    To: <basicstamps@egroups.com>
    Sent: Wednesday, August 30, 2000 4:35 PM
    Subject: [noparse][[/noparse]basicstamps] DC Motor control
    > Hello,
    > linear screw drive.
    > is available too.
    > second.
    > program running,
    > Thank you
    > Dirk
    edited 2000-09-01 07:29
    Thanks Gary,
    unfortunately I need 200 rounds to the end of my linear
    ball-screw positioner and this 50cm long potentiometers are quite
    expensive.
    As I am no elektronik engineer but an IS guy must a regulator be
    realised for that or did you tried these third party products like Motor
    Mind B ?
    So far I got, that the memory of a stamp is low limited and I ask myself, if
    it's
    possible (memory and speed) with this nice part.
    Do you know how to put an encoder electronic to the stamp.
    best regards
    Dirk
    Sent: Friday, September 01, 2000 7:37 AM
    Subject: Re: [noparse][[/noparse]basicstamps] DC Motor control
    > Dirk,
    the
    computer.
    stamp.
    screw.
    need
    > Good luck,
    > Gary
    > g.shearer@v...
    > From: "Dirk Robert Kuhlmann" <kuhlmannd@i...>
    > > Hello,
    > > linear screw drive.
    > > is available too.
    > > second.
    > > program running,
    > > Thank you
    > > Dirk
    edited 2000-09-01 15:14
    >expensive.
    Can you replace the DC motor with a stepper? This would make very accurate
    positioning simple to do with a stamp. Then it's just a matter of saying
    "go 500 steps forward" and it will hit it's mark every time. Just a thot...
    Duncan
    edited 2000-09-02 06:25
    > linear screw drive.
    > is available too.
    The best option is probably the use of a dedicated chipset. Take a look at
    www.jrkerr.com , look under ic-products. They sell a chipset for this. You
    link the encoder and motor to the chipset and then you can control it using
    a serial link.
    edited 2000-09-02 07:23
    Hi Duncan,
    I also think that a stepper would be good, considering the ball screw has
    very little drag which would cause a stepper to skip. That aside, one could
    simply count and output steps to the stepper motor controller (clock signal)
    but one should also have some type of reference which could be an
    opto-interrupter at the end of travel. I have some circuits for driving a
    stepper motor and software too at:
    www.microcontrollertricks.cjb.net
    My example is for a PIC 16F84 but the same logic can also be used to write a
    stamp program ( I did all my original research on a stamp and will have to
    put the stamp program up on the web site as soon as I have time)
    Hope this helps,
    Gary
    g.shearer@v...
    Sent: Friday, September 01, 2000 9:14 AM
    > >expensive.
    thot...
    > Duncan
    edited 2000-09-02 07:27
    And you can do the same thing with a stamp. I am doing it now.
    Gary
    Sent: Saturday, September 02, 2000 12:25 AM
    > > linear screw drive.
    > > is available too.
    using
    > a serial link.
    edited 2000-09-02 12:18
    > linear screw drive.
    > is available too.
    For driving a DC motor with an encoder an excellent dedicated chip is
    national's LM628/629. This thing is basically a motion control system on a
    chip. You connect the motor and encoder to it, then send it data. It can be
    set up for position/velocity and does PID on the fly to generate it's own
    trajectory profile. I've never used this with a stamp, but it should be
    possible.
    Duncan
    edited 2000-09-10 17:46
    Well, I thought about it and think that your best course would be to use a
    stepper motor. The stepper motors cost $60 max each and it is easy for the
    stamp to control the stepper. Position is recognized by the number of steps
    and in which direction. There should also be a home position indicator ie.
    optointerruptor. You can get some ideas from my web site at:
    Let me know if you need any further help.
    Gary
    Sent: Friday, September 01, 2000 1:29 AM
    > Thanks Gary,
    > expensive.
    > Mind B ?
    if
    > it's
    > best regards
    > Dirk
    > From: "G. Shearer" <g.shearer@v...>
    > > Dirk,
    attenuator
    > the
    > computer.
    > stamp.
    > screw.
    > need
    want
    > > Good luck,
    > > Gary
    > > g.shearer@v...
    > > > Hello,
    > > > linear screw drive.
    > > > is available too.
    > > > second.
    > > > program running,
    > > > Thank you
    > > > Dirk
    edited 2000-09-10 19:38
    Great link! Some of those pages look like Forrest Mim's stuff, that's one
    format I like.
    Anyway, about the opto-interruptors described, what kind of positional
    repeatability do you see most often in such designs?
    Neglecting play and temp changes of the mechanical components of say a
    machine slide, what kind of signal repeatability could be expected out of
    it? (±.001"?, ±.005"?)
    Would the output signal repeat within ±.001 for 100,000 consecutive slide
    cycles?
    Best Regards,
    Mark
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Sunday, September 10, 2000 9:42 AM
    >Gary
    >From: "Dirk R. Kuhlmann" <kuhlmannd@i...>
    >> Thanks Gary,
    >> expensive.
    >> Mind B ?
    >if
    >> it's
    >> best regards
    >> Dirk
    >> > Dirk,
    >attenuator
    >> the
    >> computer.
    >> stamp.
    >> screw.
    >> need
    >want
    >> > Good luck,
    >> > Gary
    >> > g.shearer@v...
    >> > > Hello,
    >> > > linear screw drive.
    >> > > is available too.
    >> > > second.
    >> > > program running,
    >> > > Thank you
    >> > > Dirk
    edited 2000-09-10 22:14
    Under operating conditions, a stepper will hit the same mark every time,
    all the time (ie. unless it stalls, skips or breaks).
    This would depend on the steps/revolution of your stepper and the reduction
    on your linear (lead screw?) drive system. Certainly stepper based systems
    are capable of extremely accurate micro positioning. 200 steps/revolution
    bipolar stepper motors are common and cheap- with that figure and knowing
    the pitch of your leadscrew you can figure out how accurate your setup
    would be. ie. assuming a pitch of 10 tpi (threads per inch) on your lead
    screw a 200 step/revolution motor would give you increments of 0.0005"-
    half a thou. This of course, is an ideal mechanical system without any
    backlash or runout.
    Best, Duncan
    edited 2000-09-11 16:26
    To deal with any backlash, you approach the desired position from the same
    direction. This process is called hysterisis. You go past the desired
    position in one direction then return to it going the other. This will take
    out almost all of the positioning error. Secondly, you could use a
    microstepping driver which could give you a resolution of over 10,000 steps
    per revolution. The position indicator is just a home reference position.
    When in doubt, return to home and then go to the desired position. I have
    been able to do positioning with a stepper and micrometer drive (0.5mm per
    rev) with an accuracy of less than 10 microns. Remember, with a stepper
    motor, you get perfect positioning every 4 steps as the error evens itself
    out.
    Gary
    Sent: Sunday, September 10, 2000 4:14 PM
    backlash or runout.
    Best, Duncan
    edited 2001-11-17 21:31
    I want to be able to use a PIC or Basic Stamp to position two small
    (<1amp @ 28v) DC motors. The position feedback comes from a
    potentiometer attached to the gear train of each motor. I want to
    store up to 100 positions for each motor and then recall the desired
    position to move each motor to. Can anyone suggest the best approach
    for doing this? What hardware would you recommend etc.
    Many thanks
    Hal
    edited 2001-12-13 19:28
    This might be off the subject, but I'm looking for a DC motor at about 1/3
    to 1/2HP with a variable rpm control of 0-5000rpm. I'll probably need a
    power supply and controller for such a motor.
    If I can use a Stamp to use as a controller, it would be good too.
    Am I asking for something that doesn't exist?
    Paul Ko
    pko@m...
    edited 2001-12-14 20:36
    >Thanks,
    >Paul Ko
    >pko@m...
    >Hi Paul -
    I just ran across a 1/3 HP 90 VDC motor on sale. Here is the web link:
    http://www.meci.com/
    Right on the front page.
    Hope that helps.
    Bruce Bates
    edited 2001-12-20 00:07
    >Thanks,
    >Paul Ko
    Paul,
    These ideas are great, but be prepared to spend some $$$.
    To zero in on a good motor voltage should be included as
    part of your requirements although some motors have a RPMs
    per volt or maybe a torque per amp rating and work quite well
    in certain applications. A lot of DC motors in the .3 to
    1.0 HP range seem to be made for about 90 volts. Check
    Dayton motors and speed controllers from Grainger. Harbor
    freight and Grizzly mini lathes and mills have replacement
    permanent magnet DC 7000rpm motors for about $129. The mini
    lathes and mills are belted or geared down to 3/4 to 4/5 HP
    at 2900rpm. Without this gearing you'll probably be in the
    right HP/Speed range as you requested. Finally, check Ebay
    for DC motors. You might be surprised what you'll find.
    Last, check out BattleBots.com and follow the links related
    to building your own bot. Some of the teams are quite free
    about the components and motors of their bots. National Power
    Chair has DC motors from 12, 24, and 36 volts from fractional
    HP to 15 HP!!
    As far as the stamp controlling your motor, remember that
    depends on wether your output needs continuous PWM output
    or not. IF so, use the stamp with a PWM gate driver to a
    few high current/voltage FETS in parallel for single direction
    control or make your own H-Bridge from FETS for forward and
    reverse control. Check out www.irf.com for gate drivers and
    FETS. Check out this web site http://members.tripod.com/~divelec/
    for low cost ($40) high current DC motor controllers.
    Good luck!!
    Greg Hensley
    Lawrence Livermore National Laboratory
    Defense Sciences Engineering Division
    7000 East Avenue Mail Stop L-369
    Livermore, CA 94550
    Phone: (925) 423-4850
    Fax: (925) 422-2118
    Email: hensley1@l...
    edited 2001-12-20 03:16
    ...or do like I did and buy a wheelchair off eBay. $255 got me two 24-volt
    gear motors, some belts, two wheels, a screw-jack motor and a controller.
    1/3
    > HP to 15 HP!!
    edited 2003-02-28 18:00
    Hi
    I am in the process of using a stamp to sontrol 4 DC
    motors. I wish to have speed control and direction of
    rotation control. I need a chip that shall relieve the
    stamp of doing the speed control itself. The stamp
    just needs to send a command to the ship for amount of
    speed and direction and the chip should further drive
    the motors. Is there such a soln / chip available .
    Any help shall be appreciated.
    Thanks a lot
    __________________________________________________
    Do you Yahoo!?
    Yahoo! Tax Center - forms, calculators, tips, more
    http://taxes.yahoo.com/
    edited 2003-03-01 20:32
    --- In basicstamps@yahoogroups.com, harshit suri <suri_list@y...>
    wrote:
    > Hi
    > Thanks a lot
    Hi
    On day I salvage 2 LB1630 fron a robot toy.
    Low-Saturation Bidirectional Motor Driver
    for Low-Voltage Applications
    LB1630 is a 8 pins IC build by Sanyo
    With two signals you obtain forward reverse and stop .For the speed,
    (PWM) it will be necessary to construct your own circuit.
    Excuse my English.
    Alain Gauthier
    edited 2003-03-05 01:17
    Hello,
    I have a suggestion. Check out www.barello.net. This
    guy makes several small PIC based control systems. One
    device he sells for $30.00 called the RC4PWM board
    which takes four R/C servo signals and drives four DC
    motors. It will handel up to 30 volts and 1.1 amp per
    motor. It controls both direction and speed of the
    motor based on an input pulse that varies from 1 to 2
    mS with 1.5 mS being neutral/braking. The stamp should
    be able to output these signals and run the motors. If
    you need more current or voltage then things get a lot
    more complex.
    DrDiode
    --- harshit suri <suri_list@y...> wrote:
    > Hi
    > of
    > the
    > of
    > drive
    > Thanks a lot
    > Do you Yahoo!?
    > from the same email address that you subscribed.
    > Text in the Subject and Body of the message will be
    > ignored.
    Do you Yahoo!?
    Hello,
    I just bought a few L293D Motor Controllers (16 pin DIP) from
    www.HVWTech.com. I am looking at the datasheet and I was wondering
    if anyone has used this chip with the BSII? I want to control two
    beeper dc motors on a small robot. Any help would be great.
    Curtis
