4-digit LED display
I'm trying to determine the best way to drive 4 seven segment LED digits
from a BS2 with a minimum number of I/O pins. I know about the MAX7219
chip, but at ~$9 it seems awfully expensive. My gut tells me that with a
little ingenuity I can do it for much cheaper.
There's an example at
http://users.minet.ca/~tcumming/Electronics/circuits/thermostamp.html that
shows how to drive a single digit with a shift register and the text implies
that you could drive multiple digits by "...driving the Ground line of the
LED display high or low" but he hasn't tried it. Anyone know if this would
actually work with stock LED digit parts?
TIA for any suggestions or advice.
/* Andrew */
Andrew Tucker
Software Engineer
Aegis Software
mailto:andrewt@a...
/* Andrew */
Andrew Tucker
Software Engineer
Aegis Software
mailto:andrewt@a...
andrewt@a... writes:
If you (your power supply) can afford the current, you could use a 74x595
shift register for each digit (no multiplexing).
While you can multiplex four 7-segment displays with PBASIC, you'll have
little time to do anything else. Using the option above, you can drive the
four displays using only three I/O lines (clock, data and latch).
-- Jon Williams
-- Dallas, TX
writes:
> little ingenuity I can do it for much cheaper. >>
you could always ask the fine folks at maxim for a free sample. thats how i
got my max7219
just a thought
jeff
i
> got my max7219
> just a thought
> jeff
chaining together multiple 74HC595 shift registers, one for each digit. If
that works it'll be less than half the price (for 4 digits) and more
flexible as well.
From: BlitzK / Xenu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wu0KKMTC1cf9zYiyfgAJufbVusKa7wBwV1fCzlatbR153vvVQSjg7MzYplscj2R7NxmGHF_HZX3O17g]xenu@t...[/url
Sent: Wednesday, August 30, 2000 4:10 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] 4-digit LED display
...But it usally takes a month or two to receive it.
i
> got my max7219
> just a thought
> jeff
How about a '7447, a BCD-to-Seven segment driver. 3 I/O pins will give you
0-9 on the display. If you only need 0-7, 3 pins will do. This part is
"generic" and would be less expensive than the Maxim part.
Steve
Steve Roberts: sroberts@s...
the way the 74x595's can. That means I'd need 3 I/O lines per digit or 12
of the stamps 16 I/O pins to drive 4 digits. Using 74HC595s I can get 4
digits for 3 I/O lines total instead of per digit.
From: Stephen Roberts [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vQxlP-zZ14aXUc2yHfcv0z_WzayQeyXw7xEojYHXB61Of2_uj465V8gWBs6f27aw0iGbzALuCerBuvRpyCRB0ZiL2kE]sroberts@s...[/url
Sent: Thursday, August 31, 2000 10:13 AM
Subject: [noparse][[/noparse]basicstamps] Re: 4-digit LED display
Steve
To save some 595s... and a lot of programming, you may use one 595 and two
BCD to 7-segment decoder (like 7447). That way, you send 8 bits to the 595,
and the decoders will do the job of setting the segments on or off on the
two displays . This will be far more easy to program as well.
So you need 2 times 595 and 4 times 7447, I think this will remain a cheap
solution.
Best regards,
Philippe Derenne
To: <basicstamps@egroups.com>
Sent: Thursday, August 31, 2000 1:42 AM
Subject: RE: [noparse][[/noparse]basicstamps] 4-digit LED display
> And I wouldn't learn much. I'm currently planning on using the idea of
If
> flexible as well.
> From: BlitzK / Xenu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z_dnleVog_p7O_ixebXd17fq58sTLfzaSkY8kpUhBgSrSb1GkcrSR-sKJrhNQ7a1pTeGNu6-krnIPSiY7A]xenu@t...[/url
how
> i
> > got my max7219
> > just a thought
> > jeff
From: Philippe Derenne [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bJFDvSEt5e0AcwNFJtwAjS7Sn2chjc6cFy21Nhe0JI2dbGDcuSeOI6Qb0eEeLLNkSWGosvAdeImNlz8]derennep@s...[/url
Sent: Sunday, September 03, 2000 2:22 AM
solution.
Best regards,
Philippe Derenne
If
> flexible as well.
> From: BlitzK / Xenu [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4nSDnJ7FMoaQiBO71G1_P7S84PfxmZlfdrV0y8gbLC82vFVB9FX9OE5vkUwC42ciLnrHk3uRnBC_KrghwQ0N]xenu@t...[/url
how
> i
> > got my max7219
> > just a thought
> > jeff
> solution.
What this doesn't solve is the multiplexing problem -- and chews up a lot of
board space. With all of the above, it's about a wash (in parts and time) to
use a 7219 that takes care of the multiplexing for you and vastly simplifies
your code.
I agree that this is more work than the MAX7219 and takes up more space, but
it's worth IMO since I've learned about a bunch of alternative methods for
accomplishing this task and it's still about 2/3 the price.
From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XkIrIOoOLHFCAnTM5_cJMhQtTUms7kQD0xkvJYSBX9Awo-jECLxOZe8hzZ9e2YcJexiZ98c]jonwms@a...[/url
Sent: Tuesday, September 05, 2000 9:24 AM
In a message dated 9/5/00 11:20:54 AM Central Daylight Time,
595,
cheap
> solution.
to
your code.
> What multiplexing problem are you referring to?
but
Perhaps I missed part of the discussion -- and keep in mind that "best" is
whatever works. The thread refers to four digits.
From my point of view, time and board space aren't free. The board space
issue is obvious. On time: Unless you've got a really big power supply that
can handle all the segments of four displays (at least 28, more with decimal
points), you need to multiplex the displays. That is, select a digit (pull
it's common-cathode low) then place the segment data out (the segments of all
four displays are tied to a common bus). You need to wait a millisecond or
so before moving on to then next digit. If this (multiplexing) is done
correctly, the persistance-of-vision of the human eye will not detect flicker.
Multiplexing can be done with a Stamp (yes, I've done it -- but only as an
exercise) but it doesn't leave a lot of code time do much sophisticated
processing. This whole discussion is moot with a big power supply and your
595-to-decoder solution is excellent.
And the 7219/7221 will do more. It multiplexes REALLY fast (ie. 800hz)
so it's completely undetectable and the rate won't vary with other demands
on the processor. You can also vary the brightness of the display in
software, which is pretty neat. And Maxim has an extremely generous sample
policy. You should also know that it will only work with common cathode
displays.
As to "not learning as much". Why will you learn less by correctly
interfacing a special purpose state-of-the-art chip?
Just my 2 cents, Duncan
ways of doing this(4 595s or 2 595s and 4 7447s). Using the MAX7219 as a
black box would certainly have solved the problem but I wouldn't have been
aware of these alternative (and cheaper) solutions. For me as an
electronics hobbyist, the entire point of the exercise is to learn as much
as possible thus non-7219 solutions are time and effort well spent.
