Protecting a ADC pin.
I am using a MAX ADC to read the voltage from a vehicle and I know
that this is a hard environment. How can I protect the input of the
ADC from spikes and other problems?
I will be using a simple voltage divider. I have seem other people use
OP-AMPS on the input, but I don't understand why. Can someone explain?
Should I use some caps in the input to the resistor network? Would
that help?
Thanks for any suggestions.
-jr
that help?
-jr
OP amps generally are used to amplify small signals. For higher voltage
signal values the resistor dividers are fine.
Capacitor in the input will act as a low pass filter, blocking the short
term changes.
ACJacques
> that help?
> -jr
