Problems with servos
Hi there,
I'm having a stupid amount of trouble getting the back of the Futaba S148 servos
off. I've
bent two screwdrivers and given myself a massive blister in the process...any
tips? [noparse]:)[/noparse]
This is for the Growbot package, by the way.
James.
- James Matthews
Generation5: http://www.generation5.org/
"...At the forefront of Artificial Intelligence..."
off. I've
James.
- James Matthews
I've not had a chance to investigate the Allegro stuff from your last
email, however, this appears to be a LIFE SAVER! Hopefully, this can
free-up my BS2 from controlling the servo and allow it to accomplish other
things. (HORRAY!!!) As for the problem with disassembling the servo motor
(not sure if mine is the same, however, know it is a Fubata model from
Parallax) make sure you remove all four stainless screws completely from the
bottom, then make sure you remove the black screw from the opposite side
(top) and remove the "plus shaped dog" so the top of the case can come off.
After looking at mine it occured to me that you might be trying to
disassemble it about 1/4" from the bottom (stainless screws) and instead
mine comes apart about 1/2" from the top (black screw and plus shaped dog).
If I'm of no use and eventually you do figure it out, please let me know
what the problem was.
Sincerely,
David Fixemer
From: James Matthews [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kbTl4o333KER52jtfZioQ3UeJJixo5FTOlscSkLYy9IkBdqvOOeSLRtXiFzKWGupxYoJJxvHoiI7AU25gwNFALF9mA]jmatthews@g...[/url
Sent: Thursday, August 24, 2000 8:32 AM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Problems with servos
Hi there,
servos off. I've
process...any tips? [noparse]:)[/noparse]
James.
- James Matthews
servos off. I've
Make sure the servo horn is off (unscrew it) and the four screws holding
the case together are out. It should then come apart very easily.
Duncan
The servo
horn is no trouble to get off, but the back four are impossible!
James.
To: <basicstamps@egroups.com>
Sent: Thursday, August 24, 2000 3:05 PM
Subject: Re: [noparse][[/noparse]basicstamps] Problems with servos
> servos off. I've
> Duncan
ACJacques
James Matthews wrote:
> Hi there,
servos off. I've
> Regards,
> James.
> - James Matthews
What do I
have to do to get them out?
James.
> Some FUTABA servos have special screws with a very high pitch threads.
> ACJacques
Use a new, sharp screwdriver. There is stuff called "Screwgrab", or
something similar. It is just a water-based suspension of carbide particles
in a container like Elmers white glue. You apply it to the stubborn
screwhead, and it provides great improvement in gripping the screw without
the screwdriver slipping . Sears Hardware, (and probably others), has it.
I have used it often with great success.
HTH,
Ray McArthur
Sent: Thursday, August 24, 2000 2:56 PM
> Does that mean they are *really* hard to get out? [noparse]:)[/noparse]...mine simply don't
budge. What do I
> budge. What do I have to do to get them out?
At this point, I guess it's worth checking: You are trying to turn the
screw *counter-clockwise* -right ?
Mark Hillier
President, HVW Technologies Inc.
Mark@H...
Tel[noparse]:([/noparse]403)730-8603 Fax[noparse]:([/noparse]403)730-8903
Visit our web site: http://www.hvwtech.com
> the servo. The servo horn is no trouble to get off, but the back four
> are impossible!
> James.
Japenese + head screws use a different angle which often cause
common US Phillips screw drivers to not get a good grip or strip
the head. A Hobby store will have correct fitting
screwdrivers(Tamiya) or better hardware stores.
Mike DeMetz N9GEZ
Elkhart, IN
mailto:miked@e...
http://www.elkhart.net/~miked
them. The pitch on the thread is a turn ot two per inch. If you put much down
pressure on them when trying to remove them you cant unscrew them because of the
screw pitch. I got all but one out by finding a screw driver that fit tightly
and turning and putting as little pressure downward as possible. I replaced them
with some standard ones from an old servo. This may be the same problem you
have.
Mark Hillier
Mark@H...
know these servos.. ] try some heat - the issue being
to soften but not melt the plastic - soldering iron
tip set to below sodering temp heat sometimes works.
This can help with Loctite in brass inserts as well.
[noparse][[/noparse]Mark: Counter clockswise? I thought we all had digital
displays... :-) Counter digital...]
Good luck - don't get mad and hurt something...
________________________________________________________________
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
I bought my screwdriver set in Japan, so...[noparse];)[/noparse] ¥96 for 6 small screwdrivers, what
a
bargain! Probably why they're bending under pressure too.
Too late for that. Haha, my index finger has swollen up to some stupid size.
I'll try your
heat suggestion, thanks. I'll get the little bastards somehow.
James.
- James Matthews
Sent: Friday, August 25, 2000 4:51 PM
Subject: [noparse][[/noparse]basicstamps] RE:Problems with servos
> Assuming the screws are into plastic casings [noparse][[/noparse]I don't
If you're going to use heat to soften the plastic, do it heating
the *screw* itself. You could likely get it hot enough to yank out by
putting the tip of your soldering iron against the head of the screw for a
minute. This way, you'll only melt the plastic that's right against the
screw, not the whole case.
Duncan
have an
effect on the servo casing, but doesn't do much to remove the screw. My hands
are a
wreck...makes playing my guitar *quite* painful.
I'm gonna go play with my AIBO instead.
James.
- James Matthews
Sent: Friday, August 25, 2000 6:53 PM
Subject: Re: [noparse][[/noparse]basicstamps] RE:Problems with servos
> James,
> Duncan
pull the stub with a vise grip plier when you can get at it.
Heat the screw till it melts out... re-thread for different
screw later or use hose clamp around casing...
Take Dremel tool and excavate screw head until you can
get small vise grip plier on it. If you do get just one
out, you may see how to get others without messing up the
rest.
Some of these fasteners are not screws but spiral press
pins - you have to grip, twist and pull.
If it turns out they are _long_ screws with a nut on the
far end it can be a problem.
Occasionally you'll run into a screw with a hole in the
shaft with a push pin through that to keep it from turning.
Heat on the screw usually melts out the plastic around without
distorting the whole case. And perhaps the sticky screw
secret is then revealed.
To save your fingers trying to turn the screwdriver clamp
a vise grip plier to the screwdriver shaft and turn it
with the vise grip plier as a lever. While holding
pressure on the screw with screwdiver handle. [noparse][[/noparse]wrecks the
screwdriver shaft some].
NOTICE - Any of the radical suggestions above can result in
damage to the device and you'll like regret you did it once
you see how you could have gotten them out some other way!
On the other hand you will have learned something...
What goes in comes out - persist [noparse][[/noparse]I've conquered thousands
of screws!] some of the hard cases snap off the screwhead
and leave the thread embedded. Software is so much less -
_physical_ - good luck :-)
>> Date: Sat, 26 Aug 2000 23:30:00 +0100
Any other tips?...I've tried heating them w/my soldering iron,
which seems to have an effect on the servo casing, but doesn't
do much to remove the screw. My hands are a wreck...makes playing
one to modify. All this frustration isn't worth the price of a single
replacement servo. [noparse]:o[/noparse])
Shawn
From: James Matthews [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xaE8nC8aybuW6hsDt9ZfXWiDG_usQNVS9zTEgTu0mrWvWPrCpCZHk6orCiR32VevJ1ZQelwt6sopcfcofo0NCSE]jmatthews@g...[/url
Sent: Saturday, August 26, 2000 3:30 PM
Any other tips?...I've tried heating them w/my soldering iron, which seems
to have an
hands are a
James.
- James Matthews
> James,
> Duncan
