, NTE 956 voltage regulators
Hi all,
I am trying to control a 5v Mabuchi motor with an NTE956 voltage
regulator(1.5A rating from 1.2V to 37V).
Trouble is I can't tell from the data sheet how to control the output
voltage, e.g. for X volts applied to the adjustment pin what do I get for
output voltage.
Are voltage regulators controlled by voltage or current?
Anyway, the code below cycles the motor RPMs pretty well, I just wish I
could understand these voltage regulators a little better.
The hook up uses the PWM output circuit shown on p294 of manual v1.9
connected to the adjustment pin of the voltage regulator. The output of the
voltage regulator is then connected to the Mabuchi with an IN4001 with the
band toward positive connected across the Mabuchi as well. Also, with the
diode the motor runs faster for some reason.
'1 cycle=approx 1mS of PWM e.g. 100/255 duty=approx 1.96v
'duty 25 = .5, 50 =.98v, 100 = 1.96v, 200 = 3.92v, etc
duty var byte
top:
duty = 0
again:
PWM 0,duty,2000
pause 200
duty = duty + 25
if duty = 250 then top
goto again
Mark
output voltage.
duty var byte
top:
duty = 0
again:
PWM 0,duty,2000
pause 200
duty = duty + 25
goto again
Mark
Hmmm... I don't think a voltage regulator is quite the right approach.
As I understand how a voltage regulator works, the control pin is connected
to the center of a resistive network whose values determine the output
voltage.
To me, it would be simpler to bias a power transistor with the output
described on P. 294 to drive the motor.
The idea is that the transistor is rapidly switched on and off with the
change in the pulse duration providing the speed control. The wider the
pulse or higher the percentage of the 'on state' during the cycle, the
'faster' the motor turns. This process is used regularly in model railroad
power controllers. For an example of the process using a Stamp I (easily
converted for use with a Stamp II), see page 171 of the programming manual.
In this example, the track load is driven by a ULN 2803 which is an array
of darlington drivers. Hmmm. that IC seems familiar.....
Hope this helps!
Jim Cambron
NEH Technologies
To: <basicstamps@egroups.com>
Sent: Sunday, August 20, 2000 6:03 PM
Subject: [noparse][[/noparse]basicstamps], NTE 956 voltage regulators
> Hi all,
> output voltage.
the
> duty var byte
> top:
> duty = 0
> again:
> PWM 0,duty,2000
> pause 200
> duty = duty + 25
> goto again
> Thanks,
> Mark
So it seems like a voltage regulator just gets set to a fixed value and
stays there, just like the one on the Stamp.
I had the NTE956 sitting around so I was just trying to figure out something
to do with it.
Mark
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Sunday, August 20, 2000 5:24 PM
Subject: Re: [noparse][[/noparse]basicstamps], NTE 956 voltage regulators
>Mark:
>voltage.
>Hope this helps!
>Jim Cambron
>NEH Technologies
>From: "techno_masai" <plunkettm@e...>
>> Hi all,
>> output voltage.
>the
the
>> duty var byte
>> top:
>> duty = 0
>> again:
>> PWM 0,duty,2000
>> pause 200
>> duty = duty + 25
>> goto again
>> Thanks,
>> Mark
