Winscope
Hoi ik heb winscope gedownload maar ik krijg hem niet aan de praat
moet je een probe gebruiken of kan je hem ook testen met de speaker
draden??
Met vriendelijke groet .
Willem.
draden??
Willem.
can you translate please
> draden??
> Willem.
the soundcard must i use a probe or can i try him using the wires from the
speakers to test??
Kind regards.
Willem.
To: <basicstamps@egroups.com>
Sent: Sunday, August 20, 2000 1:27 PM
Subject: Re: [noparse][[/noparse]basicstamps] Winscope
> dad:
> > draden??
> > Willem.
I've seen something about a scope program for a sound card, and I think you
must connect the signal to the line input of your soundcard. It's a stereo
input, so you should get 2 channels. Be sure not to overload your card's
input !
Where did you get Winscope ?
Best regards,
Philippe Derenne
Sent: Sunday, August 20, 2000 5:49 PM
> ok i try i have downloaded winscope but i dont know how to wire him using
> speakers to test??
> Kind regards.
> Willem.
> From: will <kiddies@t...>
> > dad:
> > > draden??
> > > Willem.
you did it..
Thanks..
Willem.
Sent: Sunday, August 20, 2000 5:54 PM
> Hi Willem,
you
> input !
> Best regards,
> Philippe Derenne
> From: Willem <willems@c...>
using
the
> > speakers to test??
> > Kind regards.
> > Willem.
> > > dad:
> > > > draden??
> > > > Willem.
the line in on the sound card and used a 10K pot to adjust the line level.
Start with the pot cranked to the full resistance and then back it down
until you get the signal level you want.
You have to make sure that the line input on your soundcard is enabled in
the windows mixer also.
Tim
[noparse][[/noparse]Denver, CO]
> From: Willem [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3cSqxP4dYK-dE59WT921zBE6MODn4mdFazYFJ0ikcjF0FOCrTgTn0q7ZN7_Ydc911fdQGfRzOLfKog]willems@c...[/url
> Sent: Sunday, August 20, 2000 1:02 PM
> To: basicstamps@egroups.com
> From a friend he send it to me wen you get it working can you tell me how
> you did it..
> Thanks..
> Willem.
> From: Philippe Derenne <derennep@s...>
> > Hi Willem,
> you
> It's a stereo
> > input !
> > Best regards,
> > Philippe Derenne
> using
> the
> > > speakers to test??
> > > Kind regards.
> > > Willem.
> > > > dad:
> de speaker
> > > > > draden??
> > > > > Willem.
I have just built a osscilisope for my PC
It uses a sound card pre amp which I plug cro leads into BNC plugs (left and
Right channel on sound card)
This then uses winscope to display two waveforms
Works great and at a fraction of the cost of a "real" scope
Check out :-
www.dse.com.au for Soundcard pre amp Kit - K7347
www.jaycar.com.au for Kit KA1811 (same as above)
Does any body know of a PC controlled (windows) adjustable wave form
generator?
Hope this helps
Wayne
sound
Sent: Monday, August 21, 2000 1:54 AM
> Hi Willem,
you
> input !
> Best regards,
> Philippe Derenne
using
the
> > speakers to test??
> > Kind regards.
> > Willem.
> > > dad:
> > > > draden??
> > > > Willem.
folder called Sweepgen.zip.
It is a windows based signal generator. You can use it to drive Winscope or
to inject a signal into your circuit.
Tim
> From: Vegman@I... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VZKBbjj_3Uw2TrI5o6cxwYLcR9101H1BbtGOJs1C1kzhd1TrLkn01tGDp1mtlR8o5TNXT6PMWRMcbyG0]vegman@i...[/url
> Sent: Sunday, August 20, 2000 7:07 PM
> Guys
> plugs (left and
> Check out :-
> or
> generator?
> Hope this helps
> Wayne
> sound
> > Hi Willem,
> you
> It's a stereo
> > input !
> > Best regards,
> > Philippe Derenne
> using
> the
> > > speakers to test??
> > > Kind regards.
> > > Willem.
> > > > dad:
> de speaker
> > > > > draden??
> > > > > Willem.
I tried the winscope, only with a stereo microphone, no aditional hardware.
It works great!!
BUT pay attention to WARNING´s! Specially if the sound card is integrated to
motherboard, it can be fried if signals inputs are greater than 2 Volts.
Good practice: Use a potential divider made with a 10 K pot for each
channel, same ground for both pot´s and start with a minimum output voltage
from pot, as Tim posted in their mail.
TIM:
After half an hour of surfing at mntnweb.com, looking for their FTP site, I
could´n found it. Neither the ParallaxStamp folder. I would appreciate if
you can send me (off the list) the Sweepgen.zip file.
Thank you very much
Jorge
Sent: Monday, August 21, 2000 1:55 AM
Subject: RE: [noparse][[/noparse]basicstamps] Winscope
> I just put a file onto the FTP site at Mntnweb.com in the ParallaxStamp
> Tim
ftp://mntnweb.com/parallaxstamp/
Tim
> TIM:
I
> Thank you very much
did get the site once but wouldnt load a directory. I am going to try from the
house tonight to see if it may be something with the network here.
>>> "Tim Goldstein" <timg@k...> 08/21/00 12:07PM >>>
Try:
Tim
> TIM:
I
> could n found it. Neither the ParallaxStamp folder. I would appreciate if
> Thank you very much
Jorge
Sent: Monday, August 21, 2000 2:07 PM
> Try:
> Tim
> > TIM:
site,
> I
if
> > Thank you very much
Good site!!
Jorge
Sent: Monday, August 21, 2000 2:25 PM
Subject: SV: [noparse][[/noparse]basicstamps] [noparse][[/noparse]OT] Winscope
> Here's another site that may be of interest:
> http://w3.pca.net/~cpclark/SBTESTEQU.html
> /Henrik Olsson.
